Like Tree352Likes
NOVAROSSI Engine thread....
Old 08-27-2013 | 02:49 PM
  #5986
PERROTTO's Avatar
Originally Posted by am
Yes, i have not used theese many glowplugs in years, combined... The old one in gold would last a gallon, now sometimes it is two tanks and its dead. Mye engines are healthy and so is the fuel. I had a coupple of old ones in gold pack, and they last.
Yes I agree. The gold packaged nova plugs were the most reliable and longest lasting plug I have ever used. Got them overseas off of eBay. Can't find them anymore.
PERROTTO is offline
Old 08-27-2013 | 03:28 PM
  #5987
Retired09's Avatar
Use 97T's all the time in my BTT. Work great!
Retired09 is offline
Old 08-27-2013 | 04:46 PM
  #5988
houston's Avatar
tip: if you are trying to use a plug for a gallon you are seriously jeopardizing your engines internals (its not a "my plug lasted 2 gallons" contest) , plug filaments get very brittle , they are designed to, so as they heat up to pretty high temps and are subjected to high pressures being part of the combustion chamber . i would highly recommend utilizing cool plugs no more than half gallon and hot plugs no more than 1/4 gallon of fuel , leaving hsn just a touch on the rich side will keep plug cooler as noted by the "wet" plug when inspected .you will notice the tune fluctuating , sign plug needs to be replaced for optimal performance
i have personally not have had any problems with the c6tgc as of late but dont really recommend 97t except for break in plug as they are very very brittle , large air orifice and thin element provide for easy tuning but plugs dont last long at all , i would personally change 97t plugs about every 6-8 tanks of fuel (no joke)
take my advice for what its worth , its up to you , i am not really trying to sell anybody plugs as some have mentioned before but more so offering the advice based off of knowledge from what i have seen from customers engines and have personal experience with
houston is offline
Old 08-27-2013 | 05:05 PM
  #5989
beidle99's Avatar
words to live by. I change my c6 plugs on average every other race day or 3 times a gallon. Never a flame out in over 7 gallons. Knock on wood.
beidle99 is offline
Old 08-27-2013 | 06:16 PM
  #5990
Retired09's Avatar
Monty. Thanks for the info on hot plugs!!!!
Without knowing this, I have been doing what you recommend (shit ass luck lol!).
I put a new plug in for practice - say about 30 minutes - roughly 500cc approx 1/8 gallon.
New plug in for racing, 3 - 7 minute quals and 1 - 30 min main - roughly 60 minutes run time. 7 - 8 tank fulls - approx 1/4 gallon.
Bill
Old 08-27-2013 | 06:34 PM
  #5991
Jaz240's Avatar
Damn I guess I need to start doing this also. I've been trying to win the plug life contest! Guess its time to stock my box with glow plugs.. CHA-CHING!
Jaz240 is offline
Old 08-27-2013 | 06:55 PM
  #5992
Tyson72's Avatar
Regarding the 97t plug, I guess u get Wat u pay for. Getting more plugs cheaper, but then replacing them more often isn't really achieving anything more or less. I'm jut finding out as much info on the novas as possible for a friend that I'm helping out get setup for his first nitro 1/8 buggy. I'm very interested to see how this engine goes once we hit the track
Will still probably go the O'Donnell plug and replace it every morning before a new days racing at a minimum. Thanks a lot for everyones advice and tips, I've found this thread very helpful
Tyson72 is offline
Old 08-27-2013 | 07:25 PM
  #5993
houston's Avatar
Thats awesome
houston is offline
Old 08-27-2013 | 07:31 PM
  #5994
wingracer's Avatar
Another piece of plug knowledge. Do NOT use a brand new plug for a main. You want to put at least one good heat cycle on a plug before subjecting it to the abuse of a long main. I like to put a new plug in and run a few laps on it in practice. Just half a tank to a full tank. Pull it out, check it to make sure it still glows and isn't damaged, then save it for future use. Now you know it's a good plug and have toughened it up a bit for the main.
wingracer is offline
Old 08-27-2013 | 07:58 PM
  #5995
ABN Hoosier's Avatar
A few quick questions please:
1) A steel flywheel has what advantages in what circumstances?
2) An aluminium flywheel has what advantages in what circumstances?
I have stock, aluminum flywheels for my Team Associated cars.
I run the Novarossi BONITO.21-7XLB 7 Port .21 in my RC8T.
I run a Novarossi PLUS.21-4BTTA TUNED 4 Port .21 in my RC8.2
3) Is there a steel version flywheel comparable to the Team Associated Flywheel, Hard Anodized Aluminum (RC8) [ASC89136]? If you could answer and link, that would be great.
Thanks in advance.
ABN Hoosier is offline
Old 08-27-2013 | 08:09 PM
  #5996
rfleck's Avatar
Ok thanks a lot.
That is great run time! Would this pipe/manifold fit the mp9 ok?
NVR51020-21
Yes sir, I run Kyosho. Perfect fit. Smooth as butter too with this combo. 14/46 gearing. 1.0 springs and 20%nitro. Perfect dusty track setup.
rfleck is offline
Old 08-27-2013 | 08:25 PM
  #5997
So I am looking into a Keep OFF 4 Port or a 4 BTT. What kind of runtime are you guys averaging in each motor? Which pipe and header work best? My main goal is to get consistant fuel mileage. Which should I go with?
CBeeler46 is offline
Old 08-27-2013 | 09:20 PM
  #5998
Retired09's Avatar
Understand the logic but have never seen any body including the pros do this.
Rest of you on this forum do this?
Old 08-27-2013 | 10:01 PM
  #5999
I have a big assortment of plugs - NR, Picco, OS, and Odonnell. And the OD's easily last as long as anything else, if not longer. If any of them are suspect in terms of longevity, it's OS.
It's just an error to assume that because they are cheaper, they are not as good. (Same applies to engines of course....................................)
Herrsavage is offline
Old 08-27-2013 | 10:12 PM
  #6000
houston's Avatar
I personally am not assuming anything , I know for fact what is what
houston is offline
