Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-04-2012 | 04:14 AM
  #3796
Maximo's Avatar
Originally Posted by jnorwood_losi
Piston and sleeve look fine (compression is low) but the engine has had probably 7-10 gallons on it this year. I pulled the bearings out and they look good (all races are there and they turn fine. I WILL for sure put a new front bearing in as I have one, but where do I get a good (but decently priced) rear bearing. There is NO WAY I am going to spend almost $100 for a rear ceramic! I will get the sleeve a pinch and see how it goes
TKO bearings...and 7-10 gallons is a dam good lifespan for a race engine, a new rod/bearingsand repinch and you are good to go.....
Maximo is offline
Old 09-04-2012 | 04:15 AM
  #3797
megasaxon's Avatar
Originally Posted by BradS
Are there any rods cheaper than the R7 that will fit in a P5XLT? I have an engine with about 8 gallons on it that needs a rod and I don't really want to spend $50 on it, would rather invest that towards a new engine.
You can run the rod that comes in the n21 engine #07001 or I think GO rods fit too.
megasaxon is offline
Old 09-04-2012 | 09:01 PM
  #3798
What glow plugs are you using with a plus 4 c ?
Twells is offline
Old 09-04-2012 | 09:54 PM
  #3799
aussies1129's Avatar
You can run odonnell 97t but there a bit hot so try 99t but I use
Novarossi 6tgc they last and are very consistent
Cheers
aussies1129 is offline
Old 09-04-2012 | 10:25 PM
  #3800
houston's Avatar
Default Os plugs in novarossi
Here is why os plugs deform novarossi head buttons , the tapered seal area of the os plug is shorter in length than novarossi style which pushes the aluminum seal area down , it will not seal properly now with a long taper plug which will now only touch at the upper part of the tapered seal area which is thick . the lower portion of the tapered seal area is fairly thin on the novarossi engines cause of the way they are shaped and machined , they are designed for a long taper not an OS style short taper
novarossi ,odonnell and werks plugs all work well with novarossi head buttons , they all have different characteristics of how they run but should all work as far as fit
houston is offline
Old 09-05-2012 | 08:46 PM
  #3801
anyone know where to start tuning 24065 carb 4btt with 6.5 venturi for 34 celcius ambient.
using 9901/41030>
where the LSN and HSN to start tuning it. i just bought a new carb since my old carb is damaged the HSN is broke . and i try tuning it and i mess with the needle i don't know where to start now any help will be appreciated
yollie is offline
Old 09-05-2012 | 11:11 PM
  #3802
houston's Avatar
using 9901/41030>
Had a very hard time leaning the lsn enough with the 24065 carb , it was at 1 1/4 turns from bottomed out and i gave up on the carb , 24069 back on engine now , all is well
houston is offline
Old 09-06-2012 | 04:36 AM
  #3803
chicky03's Avatar
using 9901/41030>
My btt is 2 3/4 out from bottomed on the low speed. The top I'd say is the same as my other carb. That's with a 6 restrictor and 41021 header 2096 pipe. If you run another pipe or bigger restrictor you'll have to turn it out more I'd guess. Maybe start around 3.5 out on the low and where it was on the top with the other carb.
It could also be different from engine to engine, like what Monty experienced so be careful!
chicky03 is offline
Old 09-06-2012 | 11:56 AM
  #3804
am
Hi, sorry but forgot abaout the Crono post.
All 2032 shoukd be the same hence the EFRA number but somtimes there are differences.
I have both the first gen. 2032 pipe witch is soft, this pipe runs the best but is fragile. I do not think thay make theee anymore.
The pipes are made by Hipex i belive and the pipes you get now is just as strong as the SS pipes from Nova. Actually, Crono had the SS type pipes way before Nova did. I have a brand new old style 2032 :-)))
How the prises are at the moment i do not know, since we stopped selling Crono here in Norway.
am is offline
Old 09-06-2012 | 12:25 PM
  #3805
Lille-bror's Avatar
No worries, Am. Thanks for the reply
Houston: For the last months I've been using your way of treating engines between race days. Stop the engine, empty the tank and let the front bearing be pointing downwards during storage. Works perfectly . No rust on the bearings.
Lille-bror is offline
Old 09-06-2012 | 12:32 PM
  #3806
houston's Avatar
houston is offline
Old 09-06-2012 | 02:05 PM
  #3807
WildManDriving's Avatar
I've just purchased my first nitro from a local race which came with two Toro Nero engines, one needing a new conrod. Can someone please point me in right direction? I can't seem to find anything googling 'novarossi toro nero'.
Thank you,
Michael.
WildManDriving is offline
Old 09-06-2012 | 02:08 PM
  #3808
houston's Avatar
Thank you,
Michael.
novarossi part # 07009
if you cant find one in australia lmk and i will see what i can do as far as reasonable shipping on one for ya , i have a few
houston is offline
Old 09-06-2012 | 04:28 PM
  #3809
Default TKO Bearings
Neil,
Can the TKO 7X19X6 front bearing be used in the BTT considering the Nova bearing is 6.3mm wide?
RandyJones is offline
Old 09-06-2012 | 04:43 PM
  #3810
kgombe's Avatar
sorry wrong thread
kgombe is offline
