Like Tree352Likes
NOVAROSSI Engine thread....
Old 08-19-2012 | 10:46 AM
  #3706
Roelof's Avatar
Originally Posted by yollie
I'm sure novarossi wouldn't make that mistake (wrong size shimm). I think the Local Dealer tricked you for clearance item LOL
You would be amazed. If it is done by Novarossi it is not the first time.
But always use the solder trick if you are not sure of the headclearance.
Roelof is offline
Old 08-19-2012 | 12:37 PM
  #3707
houston's Avatar
Hes talking about the i.d. Of the shims
houston is offline
Old 08-19-2012 | 10:00 PM
  #3708
Tran901's Avatar
anyone ever run a dynamite 007 with a plus 21-4?
Tran901 is offline
Old 08-19-2012 | 10:18 PM
  #3709
houston's Avatar
dynamite 007ht pipe isnt bad , very flowing design , mucho bottom , ok mileage
pipe meant for larger displacement like .25 and .28 engines but works great actually
houston is offline
Old 08-19-2012 | 11:35 PM
  #3710
Lille-bror's Avatar
Anyone know when you can buy the new Novarossi 4,7 mm venturi?
Lille-bror is offline
Old 08-20-2012 | 06:36 AM
  #3711
Tran901's Avatar
thats what i heard Houston, i'm going to try it and see how much i like it
houston, do you do engine rebuilds? i need my speed rebuilt...piston and connecting rod
Tran901 is offline
Old 08-20-2012 | 09:02 AM
  #3712
Motorman007's Avatar
Novarrossi P8 XLT
195.00€
195.00 EUR = 240.686 USD
http://www.top-options.fr/product_in...oducts_id=2528
Motorman007 is offline
Old 08-20-2012 | 05:54 PM
  #3713
rsawyers9's Avatar
I'm going to order a P5 soon. Should I shim for 30% or just leave it and run 25%? My lhs can get either in Byron's.
rsawyers9 is offline
Old 08-20-2012 | 06:02 PM
  #3714
houston's Avatar
you're good
houston is offline
Old 08-20-2012 | 06:44 PM
  #3715
rsawyers9's Avatar
you're good
Old 08-21-2012 | 05:53 AM
  #3716
Maximo's Avatar
I Would like to introduce the CRE Proto 7 .......
custom built 7 port based out of a P5 case, full ceramic bearings..............Engine is fantastic with the strongest, most useable bottom end I have seen from a .21.....Exceptional runtimes and a fantastic top end...this engine is truly badass...... We will have 10 available this week
+ YouTube Video
Maximo is offline
Old 08-21-2012 | 10:26 AM
  #3717
mmmmmmmm you think so...LOL!! I think you have a really good idea who am I talking about....LOL!!
Uwiikz is offline
Old 08-21-2012 | 10:31 AM
  #3718
Originally Posted by savannahmick
All you probably did was loosen the motor up a little with the WOT and that made it easier to idle and run smoother but it only hurt the life because you need to slowly run-in the combustion seal between the piston and sleeve. Novarossi engine have a VERY tight fit when new and can be tough the first couple tanks to get it idiling but I always lean 1/2 turn or more on both needles before first start because factory settings are super rich since they have no idea what fuel, plug, pipe, etc. you are going to use so it is set so it will be rich enough for whatever setup you choose.
Yes I understand this and thank you for taking the time, but mine did not have problem with idling, I had problem with firing it up with other than factory setting or keep it firing with no plug heater attached which I find very strange...
Uwiikz is offline
Old 08-21-2012 | 10:43 AM
  #3719
Suspended
+ YouTube Video
What crank is that?
Engine looks awesome, might pick one up for my truggy.
How much is it gonna be?
rcuser567345 is offline
Old 08-21-2012 | 11:32 AM
  #3720
BradS's Avatar
I'm confused by this nova manual, is there anything special I need to do to turn the fuel intake to point down or do I just loosen and turn it?
BradS is offline
