Like Tree352Likes
NOVAROSSI Engine thread....
Old 02-21-2012 | 09:04 AM
  #2206
Maximo's Avatar
Originally Posted by Chris Peralta
Ok smart guy, where did I say I had better info? I simply said he quoted a very experienced person in a thread that is not a clockwork racing thread. I asked him what his tests were based on and said I hope it's more than mod engines for him to quote Monty like that. Glad you and Neal touch pepes enough that you feel you need to stick up for him
I was simply replying to this statement in Monty's post, as I felt it was probably meant for me....
i have met well educated people in all different fields who thought they were the masters of what they studied in miss even the simplest of things looking a project over because they were too concentrated on the "deeply technical" aspect of the job
I am not offended or looking for a fight, nor am looking to discredit anyone...Just wanted to clarify that I wasn't talking out of my arse, that I actually did this specific testing, and I was not blinded by more technical matters...I specifically tested filled vs non filled on a Bonito !
Maximo is offline
Old 02-21-2012 | 09:05 AM
  #2207
hookem34's Avatar
R/C Tech Elite Member
From now on you will be referred to as "Classy" Chris.
Still waiting on your findings from your tests...Classy.
hookem34 is offline
Old 02-21-2012 | 09:17 AM
  #2208
Chris Peralta's Avatar
I was asking questions to Maximo. Which he answered, thank you Neal!!!
My findings... You like to but your way into something that never involved you. Pat yourself on the back!!
Chris Peralta is offline
Old 02-21-2012 | 09:47 AM
  #2209
kgombe's Avatar
Originally Posted by Maximo
I have no desire to discredit anyone else...what someone else believes has no relevance whatsoever to my own findings.....
I have most definitely tested several stock engines...as I already said, every engine is different... I gave a case study of a Clocked Bonito....as that was the engine we did the most in depth testing with......I do not see anywhere that I am discrediting anyone else....If their view doesn't match my own its not my fault , And I do not believe I should feel obligated to withhold my experiences because it doesn't agree with popular belief.....Sorry dude, but if anything you guys are the ones trying to discredit me, not the other way around......It doesn't bother me much what other people are doing, Someone asked in the thread what filling a crank does, I answered...then pretty much got told I was missing the boat, so I came back and clarified why I said what I said about crank filler being overrated ..... its nothing personal, nor a knock at anyone else...I just happen not to agree with popular belief is all !
your words tend say a different thing than what you are trying to get across.. maybe try to word your stuff differently and things maybe different... now this is just an example not a flame or me coming at you.. so don't take it the wrong way.. but when you say things like.. their beliefs and your your tests.... it sound like they have no data and they are only running their mouths... what i'm saying is that you have no proof that they haven't done any test.. but by saying their beliefs vs your tests you are implying this...
having said that ... disclaimer.. it was not an attack just an observation...
although we have had our differences i have never discredited your work.. so take this post as constructive criticism..
kgombe is offline
Old 02-21-2012 | 10:02 AM
  #2210
Maximo's Avatar
I can respect what your saying.. so don't sweat it any...
I basically felt I was being told that I couldn't see the forest for the trees, so I figured I would elaborate a bit more on why I originally said what I said...nothing more, nothing less...no hidden meanings or double talk....I just figured I should justify my opinion by describing as best I can the results of our testing here.... I do both, dyno and track testing and feel pretty confident in everything I have said...... I do not for a instant believe anyone is lying or being dishonest....But I most definitely have not missed the Forrest for the trees on this one, nor am I being dishonest, i did true double blind back to back testing..... If any of you do manage to come visit us at our track I would be tickled pink to have you take part is some of our testing..I am always looking for test pilots. !
Maximo is offline
Old 02-21-2012 | 04:36 PM
  #2211
People sure do get testy when questioned
Not everyone has to agree with you but they should respect you
Chris Reilly is offline
Old 02-21-2012 | 09:17 PM
  #2212
I have been meaning to comment on this one, but have been too busy to sit down and do it !
Anyways every engine is different in how it responds to having the crank stuffed.......some engines pick up power, some lose power....... I do not think the ramp itself has much effect on the mixture path and the differences we do feel are a response to the change in crankcase volume more then anything else...... But where I have seen the ramp affect the engine is when too much silicone is used to ramp the crank and it gets in the way of the mixture path...this hurts power, and I have seen it on the dyno......... If you think about it, the more places the mixture makes contact, the more separation it experiences ..just like sticking your fingers in the patch of a spray can.... The less we contact the incoming mixture the better the mixture flows with the least amount of separation.. All too often i see cranks that are over stuffed ..which not only causes a loss of power, it also reduces the engines mileage........Some factories cranks are actually over stuffed right off the bat, and can see noticeable improvements just by opening the channel up...they not only pickup power, they also usually pickup runtime.........In the end the crankfiller should not get in the path of the incoming mixture...filling a void in the nose of the crank is one thing, but partially blocking the intake path with a ramp of silicone is not a good idea. IMHO.....When I fill a crank I try to make sure my ramp will make as little contact with the mixture as possible....
This season I did a test comparing filled crank vs non filled crank using the Bonito...... Judging by whats written on these forums It seems stuffing the crank on the Bonito is believed to be the single most important mod that can be done to it.......As apparently this mod brings out the bottom end of the engine........... I actually ran a non filled Bonito vs half a dozen of the filled Bonito's all season long on the track.....During the season we all swapped controllers back and forth , and even did a few drag races.......You cannot tell which Bonito is filled and which one is not...these is absolutely zero difference on the track..... not one person could tell ..... The Bonito with the non filled crank had just as much bottom end as the filled crank Bonito...and whats really strange is the non filled crank engine actually was a little better on fuel.......
Anyways here is a video of the modified Bonito that does not have a filled crank.... It has massive bottom end and has no issues with idling down....so in the the end what was said/thought/sold to be the most important modification that can be made to the Bonito ended up being quite worthless for improving its performance.....And this is not just dyno testing, this is a pile of on track testing with some pretty skilled/experienced drivers....There are dozens of modifications that can be done to a Bonito that are a thousand times more effective then putting silicone filler into its crankshaft...Now of course I have not tested every engine out there in this manner...
sorry for the long post guys, but I figured I have some good insight into this, as I did do a pretty thorough test on this during the season....cheers !
edit: in no way am I implying anyone else info is wrong or false....i am just relaying what I found with my own Bonito and several other engines I have tested..
I didn't want to get into this one but your data and guessing is wrong. Do you know the difference between dynamic pressure and static pressure? Thats exactly what Monty was referring to. You are comparing a spray can blowing out pressure to a vacume pressure.
You may want to rethink your theory.
arm2storm is offline
Old 02-21-2012 | 09:27 PM
  #2213
Maximo's Avatar
Dude ! I am only giving a rough analogy, please don't read too deeply into it.....This is why I hate trying to give any sort of technical explanation over the internet..... This is also why I prefer to just shoot some video and let the engines do the talking for me.... I know very well what filling and not filling the crank does and does not do.....
Maximo is offline
Old 02-21-2012 | 09:55 PM
  #2214
Maximo's Avatar
In the end I have no beef with anyone...we are all entitled to our own beliefs, I respect others, and I feel they should respect mine... I Am not fancy with my words , but writing is not my specialty ! ......If anyone has any questions they would like me to answer feel free to hit me up in my thread.....
Maximo is offline
Old 02-21-2012 | 09:56 PM
  #2215
J.Sears's Avatar
I think we should have a good ole fashion show down! Clockwork vs. Houston drag race! I've got a clocked Bonito or P5 anyone up for the challenge? Lol
J.Sears is offline
Old 02-21-2012 | 11:53 PM
  #2216
houston's Avatar
Lifes not all about "heavy competition" for all
I believe Neal does great work and would never dispute that guys , he knows alot I am 100% positive of that
I wasnt really trying to "strike a blow" by that comment Neal , this got just a wee bit out of hand I would say , in case you didnt notice the "hefty" compliment in that same statement that you seemed to have found what you took as a strike at you , it was there
I consider your workmanship, dedication , customer service and product support on a great level of expertise man , sometimes we all just need to take a step back though
Viva la novarossi!
houston is offline
Old 02-22-2012 | 03:07 AM
  #2217
razzie's Avatar
Originally Posted by houston
Did you make sure to transfer all the head shims?
Sounds like youre in the ballpark with the needles so kinda interesting ,
outside temps are?
If its colder out you might try c5tgc instead
Yes bro, all the 3 shims are there..tts why im so confused..
Outside temps are about 30degC. Perhaps i will try the c5tgc plug when i get hold of it.
Lucky I have 2 Plus 4 engines..
razzie is offline
Old 02-22-2012 | 05:46 AM
  #2218
Maximo's Avatar
Viva la novarossi!
We must just speak a different language my friend ......Basically in Canadian your comment comes across as this " Neal you have your own head so far up your own arse you can't see the Forrest for the trees " ........ now if thats not what you meant then I am at a loss...
Good luck at the races, I really wish I was there
Maximo is offline
Old 02-22-2012 | 06:18 AM
  #2219
houston's Avatar
That was kinda more of a generalized statement of sorts and also very true as I work with quite a few technicians who install mazak,mori seiki, matsurra and a number of high end mills . It is true that many of those guys who get what seems to be PERCEIVED (not necessarily saying you are) as "full of theirselves" were too focused on certain aspects of a particular job that they would overlook a few simple things that were of great importance .
We are all our own people in this world and all have our own ways , its that simple
houston is offline
Old 02-22-2012 | 06:20 AM
  #2220
Maximo's Avatar
That was kinda more of a generalized statement of sorts and also very true as I work with quite a few technicians who install mazak,mori seiki, matsurra and a number of high end mills . It is true that many of those guys who get what seems to be perceived as "full of theirselves" were too focused on certain aspects of a particular job that they would overlook a few simple things that were of great importance .
Fair enough !
have fun racing !!!
Maximo is offline
