Like Tree352Likes
NOVAROSSI Engine thread....
Old 10-26-2011 | 10:32 AM
  #1681
BIGTIME's Avatar
Breaking in the Bonito as I type...Engine fired right up after a lil heat.
BIGTIME is offline
Old 10-26-2011 | 10:49 AM
  #1682
losi_racer's Avatar
Originally Posted by ABN Hoosier
Losi Racer,
I run the same two engines Bonito w/ NR 9853/41021 for Truggy & BTT w/ NR 9901/41021 for Buggy. I am breaking in the Bonito still and am going to start breaking in the BTT this weekend. Any suggestions?
What are you running/getting on each engine? I am in El Paso, so I was thinking the weather conditions are similar to AZ.
1) pipe/header
2) venturi size
3) fuel
4) glow plug
5) clutch setup
6) temps
7) run times
Thanks in advance.
Congrats on your Victories too.
Sorry bud i didnt see this post.
On the Btt in my Buggy im runnin a 41021/9901 for the header and pipe with a 6.5 mm venturi, a lot of people use the 6mm for better fuel mileage but i like how the 6.5mm feels. for the plug i use a C6TGC and byron Fuels 30/9. Im using the losi 4 shoe clutch with 2 alum and 2 comp with 2 green and 2 black springs with a steel flywheel My temps are about 240 and im getting about 10.5 min on the run time , i can get more with a smaller venturi and a smoother throttle finger. This engine is super smooth, best buggy engine out there IMO.
On the Bonito in my truggy im running the 41021/9853 combo with 7mm Venturi and C6 Plug,same fuel. Also using the losi 4 shoe clutch with 2 alum 2 comp with 2 gold and 2 green springs with alum flywheel. Temps are about 260 but its still tight and its breaking in still. i havent been able to really test runtimes and the engine is slowly breaking in and also ive been to a different track every time i have ran this engine but so far im getting aprox 10 min.
losi_racer is offline
Old 10-26-2011 | 10:50 AM
  #1683
losi_racer's Avatar
Originally Posted by houston
maybe you could show Troy how to tune
haha, what engine was he running. I would think nova since he has a serpent deal?
Old 10-26-2011 | 10:59 AM
  #1684
BIGTIME's Avatar
I ended up going with the 2096/21 combo with my Bonito. I hope this is the ticket
BIGTIME is offline
Old 10-26-2011 | 08:43 PM
  #1685
houston's Avatar
oh ya they were novarossi engines alright
p5xlt and plus 4
houston is offline
Old 10-26-2011 | 08:45 PM
  #1686
houston's Avatar
should work pretty good for ya
like mark @ powerhouse said , give the 9901ss/41021 or 41020 a try on the 367/toro nero/boneytoe a try , you will like it also
houston is offline
Old 10-26-2011 | 09:09 PM
  #1687
ABN Hoosier's Avatar
Losi Racer,
thank you for the info.
ABN Hoosier is offline
Old 10-27-2011 | 02:06 AM
  #1688
megasaxon's Avatar
9901ss/41020 FTW!
megasaxon is offline
Old 10-27-2011 | 04:51 AM
  #1689
pballer2777's Avatar
WILL A TURBO BUTTON FROM A TORO NERO FIT ON A PLUS4?
pballer2777 is offline
Old 10-27-2011 | 08:24 AM
  #1690
houston's Avatar
No
28002 for non team and 28028 for team and btt/s
houston is offline
Old 10-27-2011 | 08:34 AM
  #1691
losi_racer's Avatar
p5xlt and plus 4
What makes them so special you seem excited about these ? Or am I reading to much into it
Losi Racer,
any time bud
Old 10-27-2011 | 09:46 AM
  #1692
houston's Avatar
any time bud
Too much kittrell
houston is offline
Old 10-27-2011 | 09:50 AM
  #1693
losi_racer's Avatar
Too much kittrell
Ok . You coming for the nitro challenge warm up race ?
Old 10-27-2011 | 09:53 AM
  #1694
houston's Avatar
Probably not the warmup but maybe , dates?
Definitely NC though
houston is offline
Old 10-27-2011 | 09:56 AM
  #1695
losi_racer's Avatar
Next weekend practice 4th qual mains on 5th
