Like Tree352Likes
NOVAROSSI Engine thread....
Old 10-06-2011 | 12:07 PM
  #1531
PinoyCali's Avatar
Originally Posted by houston
C5g or c6g
How many shims for 30% nitro.
PinoyCali is offline
Old 10-06-2011 | 12:38 PM
  #1532
houston's Avatar
Stick with the .70mm that engine came with, I usually run .80mm during break then reshim to .70mm after the compression seal forms and metal "pinch" is gone
Break in setup
.80mm shimming
8mm restrictor
Pretty close to tune lsn
Pretty rich top
houston is offline
Old 10-08-2011 | 08:57 PM
  #1533
BIGTIME's Avatar
Ok..I just bought a BONITO for my STRR Evo. Do I want to run the 2096/21 combo or the 9853/21 combo. Which pipe is better for that engine and truggy combo. What are the advantages and disadvantages of each pipe.
BIGTIME is offline
Old 10-09-2011 | 06:46 PM
  #1534
megasaxon's Avatar
anybody know where i can find a new crankshaft for my FMS, or one that will work in it?
megasaxon is offline
Old 10-10-2011 | 05:19 PM
  #1535
PERROTTO's Avatar
How bad is it worn? I have a used one that still measures above 4.9 (not ideal but not bad).
PERROTTO is offline
Old 10-10-2011 | 06:49 PM
  #1536
houston's Avatar
plus 21-5 , plus 21-7 , plus 21-7bt , plus 21-5k and plus 2 367 cranks will work as well
lmk if you are interested in one
houston is offline
Old 10-10-2011 | 08:08 PM
  #1537
dhopkins8's Avatar
I believe the Toronto Nero crank will work too. Aren't they both 14.5mm?
dhopkins8 is offline
Old 10-10-2011 | 08:09 PM
  #1538
kgombe's Avatar
incorrect... TORO CRANK WILL NOT WORK... they are different stroke engines...
kgombe is offline
Old 10-10-2011 | 09:20 PM
  #1539
megasaxon's Avatar
mine is under 4.9 at the smallest point
Old 10-10-2011 | 09:38 PM
  #1540
dhopkins8's Avatar
Ok. Can you explain. I don't know what you mean by stroke. I have both and they look pretty similiar as far as fitment. It seems to fit in the case/rear bearing. The fms is double slugged, filled, and the hole in the middle is larger. While to toro is single slugged, smaller hole, and the scoop imseems to be in a slightly different place.
Sorry I am not an engine Guy. Put fuel in and go is as far as I go.
Old 10-10-2011 | 09:52 PM
  #1541
PERROTTO's Avatar
Well yours is probly in the same condition as mine then. 4.93 in the middle of the pin and 4.88 at the very edge, both measurements made at the smallest point of the circumference.
PERROTTO is offline
Old 10-10-2011 | 10:06 PM
  #1542
merdith6's Avatar
Default well
I'm no expert, but the difference in stroke if the diameter of ther crank is the same and the rods are both r7 then the difference is where the crank pin is. If it's farther out on the crank it's a longer stroke. I hope I'm not way off....
merdith6 is offline
Old 10-10-2011 | 10:33 PM
  #1543
dhopkins8's Avatar
Ok well that makes sense. I wonder how far off they arey are. I can't find anything on the stroke length of the fms only the toro.
BTW what would happen if they are not the same but really close
Old 10-11-2011 | 11:07 AM
  #1544
megasaxon's Avatar
the TORO is an Xtra Long stroke engine, with a smaller bore than the FMS. the FMS has the same bore and stroke as the P5, 21-7 series, 21-5 series, 21-4 series, etc.
The Toro has a 14.5mm crank, same with the FMS, 21-7, and 21-5 series. the P5, 21-4 series, N21s, etc are all 14mm cranks.
you could not put a toro crank in an FMS because the stroke it longer, and would push the piston up too far in the sleeve. Basically it wouldnt run right, if it even ran at all
Old 10-11-2011 | 11:50 AM
  #1545
chicky03's Avatar
I like the 2084 and 9901 in the bonito. The 2096 worked well in my BTT but didnt seem to work as well as the 2084 in the bonito.
chicky03 is offline
