Like Tree352Likes
NOVAROSSI Engine thread....
Old 01-26-2011 | 05:44 AM
  #781
ANAKIN's Avatar
Default plus 4c loosing compression
guys, my plus 4c is somehow loosing its compression, the top end is gaining power but i am loosing too much in the low end. i though of removing 1 shim in the combustion chamber,(silver) just to regain compression(hopefully) and just re-tune it.
will it work?
pros and cons?
help guys!!!
ANAKIN is offline
Old 01-26-2011 | 06:22 AM
  #782
will it work?
pros and cons?
help guys!!!
Check your clutch set-up before you do anything else to it.
Weak or broken clutch springs, clutch shoes hanging up on
the flywheel pins, will kill the low end performance of any
engine.
rageworks is offline
Old 01-26-2011 | 03:39 PM
  #783
ANAKIN's Avatar
engine.
clutch setup looks fine. assembly looks perfect. 3 aluminum clutch shoe, 3 1.0 clutch springs stock gearing for the mbx6. i am bothered about the fading of the compression of the engine.
options are, removing 1 shim from the combustion head(silver)
or replacing my clutch spring with a harder set(1.1 springs)
ANAKIN is offline
Old 01-26-2011 | 03:55 PM
  #784
hambone's Avatar
Try getting it pinched.
hambone is offline
Old 01-26-2011 | 04:07 PM
  #785
Give RayA a call. IMO he has the best P/S re-sizing service
there is. Rely on the best, forget the rest.
http://www.rayaracing.com/
Old 01-26-2011 | 04:37 PM
  #786
tony montana's Avatar
ok guys Im all new to nova engines. I ordered the plus 4 2010 team version. I will be getting it tommorrow. What is the best way to break it in? I want it to last as long as possible. I have heard of nova engines going like over 10 gallons and that what Im after. I have been running the o.s. line of engines for a while now but they just dont seem to last more than 3-5 gallons before they start flamming out and all pinch is gone. One thing Im nervous about is its cold here in Maryland. Will this hurt the long term performance of my new nova If I break it in in the cold weather
tony montana is offline
Old 01-26-2011 | 05:11 PM
  #787
pickle311's Avatar
Follow the break in bible here and always pre heat your motor before starting it.
pickle311 is offline
Old 01-26-2011 | 05:30 PM
  #788
Always Pre-Heat!!!!!!
topcat-lll is offline
Old 01-26-2011 | 05:55 PM
  #789
houston's Avatar
will it work?
pros and cons?
help guys!!!
if you wanna do that only take the copper one out , DO NOT REMOVE THE SILVER!!!
houston is offline
Old 01-26-2011 | 06:27 PM
  #790
revo61's Avatar
What about the seals on the exhaust, are they in good shape?
revo61 is offline
Old 01-26-2011 | 07:09 PM
  #791
houston's Avatar
i think he is actually saying that the engine feels low in the compression department
flame outs? lack od low end punch? two tell tale signs of compression loss
houston is offline
Old 01-26-2011 | 08:43 PM
  #792
mmaattppllaayy's Avatar
Guys help me out Im trying to find out the size of the 4 head screws and the 4 backplate screws on my new toro nero team. Im replacing them with socket head screws no more flatheads. The screws are NOT 2mm, 2.5, 3, or 3.5mm they are in between 2.5-3mm for the head screws and 2-2.5mm for the backplate. The tonys screws kit for nova engines doesnt fit either. Could they be us standard sizes?
mmaattppllaayy is offline
Old 01-26-2011 | 08:48 PM
  #793
houston's Avatar
2.6mm and 3.75mm
Sure on the butt plate size and pretty sure on the head
houston is offline
Old 01-26-2011 | 08:55 PM
  #794
Originally Posted by houston
2.6mm and 3.75mm
Is there a way to confirm that? I have no special tools calipers or anything. I didnt bother contacting nova they wouldnt tell me a thing im sure and it would take a month for a response
Old 01-26-2011 | 09:18 PM
  #795
RB has the complete hex screw set pre-packaged.
Here is a link to the hex screw set,
http://www.amainhobbies.com/product_...ckplate-Screws
