Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-28-2016 | 05:18 PM
  #9181
Originally Posted by Perrydog
Plus 4 is not a monster on bottom. But if you feel u have your tune right may need to try a little more tension on your clutch springs still. I did the same with my buku
The only reason I referred to it as a monster on the bottom is because I drove one with identical pipe/clutch and car even an it had 10x the bottom
swayysta is offline
Old 09-28-2016 | 05:29 PM
  #9182
HaulinBass's Avatar
mine(both btt and keep off4) has a pretty nasty bottom end on that pipe combo running a werks 4 shoe set up how ron at werks says to with 2 carbon 2 aluminum with the standard 2 needle carb.
have you pulled one of your headshims?
HaulinBass is offline
Old 09-28-2016 | 06:21 PM
  #9183
I haven't pulled a head shim, is it recommended when running 30% ? An yea I have the 3 needle carb. I cant really find much about it for a starting point.
swayysta is offline
Old 09-29-2016 | 08:06 PM
  #9184
cczjordan's Avatar
Fot 4btt/kp4,is it ok to run 0.6mm head shim or wat is the minimum head shim?
cczjordan is offline
Old 09-30-2016 | 10:03 PM
  #9185
dmartin's Avatar
You can run 0.6mm but you need to run a colder plug like a #7.
dmartin is offline
Old 10-01-2016 | 09:14 PM
  #9186
cczjordan's Avatar
NitroPhene likes this.
Old 10-09-2016 | 12:38 PM
  #9187
My brother is picking up an Elite 5 for his truggy, is a 9901 and 41001 a decent combo for that? Or would a 9853 and some other manifold be a better fit?
The reason I ask is that I was thinking about replacing the 9901 on my buggy with a 2096 and I have a 41001 laying around he can use along with the 9901...and this gives me an excuse to pick up a 2096. He's on a pretty tight budget, so any money he could save would be great.
shearpin is offline
Old 10-09-2016 | 08:24 PM
  #9188
cczjordan's Avatar
9853 will focus on low end, 9901 good but less top, 2096 smooth low n better top. Manifold i personally run 41021/41033/41032 and can race at all tracks
Old 10-11-2016 | 07:50 PM
  #9189
Does anyone know where I can purchase a pullstsrt unit for this engine? My cord will not recoil back. Rex legend 28-8ps
lighttravler is offline
Old 10-12-2016 | 08:46 AM
  #9190
Your best bet when you're looking for parts is to find the engine on Novarossi's site: http://www.novarossi.it/2012/index.p...nd-28-8ps.html
Pull up the expoloded view: http://www.novarossi.it/2012/images/...END-28-8PS.pdf
And take the part number of what you're looking for (22812) over to Novarossi Direct: http://www.novarossidirect.com/22812_p_2398.html
I'd recommend you verify that is what you need before placing your order.
shearpin is offline
Old 10-12-2016 | 08:47 AM
  #9191
Thanks for the reply. He's decided, for now, to use a Dynamite 086 he has on hand. I'll loan him the 41001 to try on that pipe sometime.
shearpin is offline
Old 10-12-2016 | 01:56 PM
  #9192
Thanks shearpin for your help
Old 10-20-2016 | 10:25 AM
  #9193
Audiobahnaholic's Avatar
I just got a novarossi 4BTTA WC and I was wondering what pipe to run. I have the option of a reedy 2035 and reds 2104. What would each of these do?
Audiobahnaholic is offline
Old 10-23-2016 | 11:45 AM
  #9194
were can i get just the piston for a paloma limited novarossi direct does not sell it with piston only
BRYbeatoy is offline
Old 10-23-2016 | 12:14 PM
  #9195
HaulinBass's Avatar
if your starting off with a new sleeve get one of the domed "team" pistons for the motors with the same bore at stroke like the elite 5 comes with
