Sirio engines thread
#1036
Originally Posted by jeffreylin
Gordan, if your crankshaft is okay you don't need to replace it. You MAY need to replace the conrod. You can get a conrod from tower hobbies or trinity online (shopatron).
If you are coming this Sunday bring your motor and we can take a look.
#1037
Originally Posted by Motorman
prepare to wait till hell freezes over. Just ask Ray.
On the track the engine is ballistick, have not noticed any performance difference. 3 litres of testing and engine running strong.
The latest engines fom Sirio should have these cranks.
Regards
Alex.K
#1039
Originally Posted by litespeed-dom
I was real worry about the crank breaking as people has said... I got mine, broke it in (heat cycles), ran a club race, ran an entire regional, then ran another race at a permanent facility where it's designed really for 1/5th and 1/8th... Still no problem so far. I'm beginning to think it might have to do with the break-in process people are using. Or am I just the lucky few.
Anyway, it's all torn apart now, checked tolerance with nothing out of ordinary, last club race coming up so I'm just strapping in a JP instead.
Dom
Dom
Well, broke the crank today, 5 mins into the Main.....
So what's the word on sending it to Trinity? Sure they know there is a problem with the crank!
Dom
#1041
Originally Posted by sniper_rc
Ive got a sirio bigblock .27, flames out toooooo much!!!! anyone here give me some advice on this?sirios are the fastest engines i have ever seen, especially after the owner lauches the engine out of a 20 story apartment block hahahahaha
#1042
But you have to describe how it die off... at slowing down or at high speed? would it die off if the truck is off the ground?
#1043
hey ppl, im getting to racing buggyCaster ZX-1 1/8th and need some serious suggestions on some engines that i may use, what are your thoughts on the 21 Kani evo 2? and the 21RE and what other off road sirio engine would you say is good?
#1048
The early cranks there were some failures but the latest ones are flawless.
The EVO 3s are awsome holding their tune and pulling crazy power.
I just finished running the SIRIO EVO 3 at the Aussie nationals and the engine is at least as quick if not quicker than the quickest and latest around.
Infact I was in the same qualifiers as the winner (LRP) and was backing off at the end of the straight as courtesy to him so as i would not clean him up.
And balls out of the corner, lots of them.
Any busted cranks should be replaced by your Sirio supplier but I can guarntee that the new engines are bullet proof.
Cheers
Alex.K
Cheers
Alex.K
#1050
Cheers
Alex.K
Cheers
Alex.K
Dom
1Likes
