Like Tree1Likes
Sirio engines thread
Old 04-06-2006 | 11:38 PM
  #1186
Thybaut's Avatar
When I mounted the EVO 3 in my G4 I had to grind some material from the chassis because the bottom of the crankcase would otherwise touch the chassis, this would have caused a lot of stress on the crankcase.
Thybaut is offline
Old 04-07-2006 | 03:02 AM
  #1187
Originally Posted by wyl03
no disputing that.
it was absolutely screaming down the straight @ moorebank.
having said that, i saw NR LS3, max S3 (?), LRP z12r doing the same too.
was that lrp z12r by any chance driven by simon nicholsen ????
I think hes the only one ive ever seen racing with that engine.
ae_ntc3 is offline
Old 04-08-2006 | 07:58 AM
  #1188
MLCG4s's Avatar
NEED HELP
i have a sirio evo 3 , i use SH7 plug , 16% tornado fuel on a G4s gears : 19/24-51/46 , body blitz alfa romeo . surface temp 40C air 35-40 , the engine runs 120C with out the body and its too powerfull torg and speed , with body 150-160C and im loosing power torg and hi speed , by opening the main needle i loose more power , what should i do to have the same power and temp as with out the body
MLCG4s is offline
Old 04-09-2006 | 12:25 AM
  #1189
Slo-MTX4's Avatar
How big are the holes in the front and rear of your body?
Slo-MTX4 is offline
Old 04-09-2006 | 04:43 PM
  #1190
yup, his car
wyl03 is offline
Old 04-10-2006 | 03:49 AM
  #1191
hes pretty quick but you have to remember that hes probably got another 10 already run in sitting on the shelf!!!
some people are lucky!!
ae_ntc3 is offline
Old 04-10-2006 | 04:34 AM
  #1192
maskedrider's Avatar
waiting for my new Sirio engine
but still comfortable with my old Sirio
maskedrider is offline
Old 04-11-2006 | 09:21 PM
  #1193
shiston's Avatar
Hi,
Anyone using these new Sirio STI engines?
I've been out of the racing seen for over a year now, try to crawl back in slowly
shiston is offline
Old 04-11-2006 | 10:00 PM
  #1194
Killjoy's Avatar
Originally Posted by shiston
Hi,
Been waiting some time for the STI to get into Singapore. Seems that Sirio not interested in the Singapore market anymore.
If they make me wait any longer, I might have to jump ship.
Killjoy is offline
Old 04-12-2006 | 03:46 PM
  #1195
Corse-R's Avatar
Hi,
I have a pair of those 'Sti' puppies (the work on the innards are incredible), one ready to be mounted for break-in the weekend.
Corse-R is offline
Old 04-12-2006 | 08:35 PM
  #1196
shiston's Avatar
A pair of them You lucky man
Would be cool to know how they go
shiston is offline
Old 04-13-2006 | 12:05 AM
  #1197
i get mine in about 15 days!!!!!!
ae_ntc3 is offline
Old 04-13-2006 | 12:28 AM
  #1198
Corse-R's Avatar
They look really cool, but found some 'problems' with mine units when installing them on the motor blocks, the crankcase is too beefy (good!) and they were touching, needed to mill the engine mounts like this.
You can see more about the milling I needed to do here. Needed to done it on the two and was really quick to do with a Dremel and the almighty carbide bit.
Don't know if is that crankcase (my previous Sirios, were the first black ones the S12TRP ABC) or mine engine mounts (Mugen), but people should take care regarding this and n-check if the crankcase touches the engine mounts by other place rather than the mounting holes.
Is the seed for infinity of problems (bad gear mesh, stripped gears, up to a broken crankcase or worse... a broken crankshaft).
Corse-R is offline
Old 04-13-2006 | 01:36 AM
  #1199
I had the same problem with my Evo 3 going in the MTX4. I used Kawahara mounts and problem was solved!
Rody is offline
Old 04-13-2006 | 03:01 AM
  #1200
itchy b's Avatar
thanks for the tip! looks like kawahara mounts go on the shoping list!
itchy b is offline
