Like Tree1Likes
Sirio engines thread
Old 09-21-2009 | 11:36 AM
  #2686
Default What is really Sirio XXX?
May be it is wrong question, but I had no luck to find something more on internet. I got chance to buy new Sirio XXX (package with pipe, manifold) It costs 229 Euro.
My problem is that I can not find any official information about this engine. I also visited "star-motor" Sirio page, but they are silent about XXX model. I found only few info about parameters (but not about revolution range or possible reached power output!), but they were distributor pages only.
Do you have some relevant source from manufacturer?
What do you think about price?
Thank you in advance.
olap is offline
Old 09-21-2009 | 11:42 AM
  #2687
Here are the spots i found to order from!
rctorco.com sirio s12 xxxv $350
ebay.com sirio s12 xxx $280
rcmarket.com sirio s12 xxxv w/ pipe $350
amainhobbies.com sirio s12 xxx $270
as for your question though, i am not able to ind anything either!
LAM3SAUCE is offline
Old 09-21-2009 | 12:22 PM
  #2688
Suspended
Because the support sucks! Kyosho is not the US distributor anymore.
the_geeky is offline
Old 09-22-2009 | 09:52 PM
  #2689
Anybody know if the .12 EVO4STI rod is the same as the XXX rod. (or does somebody have the part number for the XXX rod?
Scott Fisher is offline
Old 09-23-2009 | 02:47 AM
  #2690
batto's Avatar
Scott I am using one of the above mentioned rods in my XXX actually I have two XXX's with these rods in them. I am yet to rebiuld my XXXv's so I dont know if they are the same in these.
Noel
batto is offline
Old 09-25-2009 | 08:01 PM
  #2691
GMartinez's Avatar
Scott I think there the same When I was testing out for the other manaufacturer they sent me the xxx liner set & it was identical
try www.the-border.com they might have it
GMartinez is offline
Old 10-14-2009 | 11:17 AM
  #2692
Seisick's Avatar
Factory needle settings for the 12 evo 4?
Seisick is offline
Old 10-14-2009 | 02:43 PM
  #2693
afm's Avatar
afm
Sirio .12 Evo 4 General Carburetor Settings
High Speed – 4 to 5 turns out
Low Speed – 2 to 2.50 turns out
Mid Range - Flush then ¼ turns out
Otra cosa muy importante, el Sirio se regula en caliente y no en frío, lo normal es que el motor en frío tienda a pararse y joder, y en caliente sea estable, esto debido al cuerpo de composite del carburador.
saludos
afm
afm is offline
Old 10-14-2009 | 05:01 PM
  #2694
Seisick's Avatar
saludos
afm
copiado gracias, para marco, no se que hizo a las agujas
Seisick is offline
Old 10-14-2009 | 05:17 PM
  #2695
afm's Avatar
afm
lo mismo de siempre, joder todo lo que toca y despues hecharle la culpa a quien lo ayuda........quiero que le digas que yo te di los datos...
bye
afm
afm is offline
Old 10-15-2009 | 02:45 AM
  #2696
Hi, i have some questions about sirio s.12 xxx.What is the default setting of this screw? Αnd last one, what it will happen if i turn that screw clockwise?
cr0c0dil3 is offline
Old 10-15-2009 | 10:12 AM
  #2697
afm's Avatar
afm
That brass screw, is actually the main jet of the carburator, commonly called mid range needle. In Sirio engines the default position is 1/4 of a turn opened from closed.
The dimensions of the this main jet (brass needle), its position relative to the venturi dictates the fuel curve of the carburetor (or how much fuel enters by each cfm of air drawn into the engine at a relative carb opening).
At idle speed, the engine is controlled by the low-end needle, and how much air passes into the engine via the position of the barrel. But when you start to move the barrel to allow more air to pass, in fact, you're moving the low-end needle too, allowing at the same time more fuel to pass too.
Depending at which opening of the barrel the main jet (brass needle) is totally uncovered, and the carburetor starts being mandated by the adjustment of the high-end needle, and how much fuel this last adjustment permits to pass can be varied, and the power band of the engine too, but slightly, by screwing or unscrewing the main jet (mid range needle) and readjusting the low-end needle.
But be careful, screwing the main jet too further into the venturi can lead to mix and temperature problems, in fact, you're leaning the mid rpms, where the engine operates at partial opening of the carb, this can lead to problems and erratic operation.
This is why, on almost all the engine booklets they warn you about not touching this adjustment, because it comes factory tuned to it’s ideal average.
The position of the main jet, relative to the venturi also changes the position on where and how much the vortex of air that enters into the carb varies how finely the fuel is sprayed into the air that enters (fuel is converted into a mist to be burned), a drop, no matter how little it is, doesn't burn and can create many and serious problems. This last can lead up to a conrod breakage (common) or piston breakage (not common but seen some) due to hydro lock.
Hope its clear
AFM
afm is offline
Old 10-15-2009 | 10:26 AM
  #2698
AFM enough said! i was also working on responding, but my computer turned off low battery ...
Old 10-15-2009 | 01:56 PM
  #2699
Hope its clear
AFM
AFM, that was very clear.Thanks a lot!!!
Old 10-15-2009 | 02:15 PM
  #2700
AFM you said ''In Sirio engines the default position is 1/4 of a turn opened from closed.''
Is that correct because i though it was from flush.
