Like Tree1Likes
Sirio engines thread
Old 02-14-2009 | 02:25 AM
  #2536
stefan's Avatar
I would be interested in how you guys would compare the XXX to the EVO 4 STI?
The reason I am asking is , that the EVO4 STI has a coated crankshaft which the XXX doesn't have. So if the performance is similar, I would personally rather stick with the EVO4.
I hate it when I have a great running engine and the crankpin is wearing down.
stefan is offline
Old 02-14-2009 | 02:52 AM
  #2537
Roelof's Avatar
You can alway send the crankshaft to a company specialized in DLC coatings....
Roelof is offline
Old 02-14-2009 | 02:58 AM
  #2538
stefan's Avatar
First of all, having a crankshaft coated is very critical. We have once sent 5 cranks for coating for €25 each. on 3 of those cranks the crank pin broke of within the first liter.
Secondly, if the performance of the EVO4 is just marginally lower than the XXX, why would I buy an engine that is €50 more expensive and then spend an additional € 20-30 to have the crank coated.
In this case, the XXX would have to be much much better than the EVO.
That's the reason I asked the question about comparison of EVO 4 STI and XXX
stefan is offline
Old 02-14-2009 | 03:53 AM
  #2539
GREGORY!'s Avatar
stefan what do you believe cause this break?
maybe they heat them very much to make the coat?
GREGORY! is offline
Old 02-14-2009 | 04:18 AM
  #2540
stefan's Avatar
the surface treatment is changing the crystalline (molecular) structure of metal.
It seems that the treatment, if not done correctly, is weakening areas that have been hardened during the production of the crank, i.e. the crank pin.
Just my theory though..
stefan is offline
Old 02-14-2009 | 04:26 AM
  #2541
Roelof's Avatar
The coating will make the pin a few microns thicker, you have to take away some microns from the pin or otherwise drill up the conrod. We keep it by a hard metal pin pressed in the crank, no wear at all.
Roelof is offline
Old 02-14-2009 | 05:19 AM
  #2542
stefan's Avatar
Roelof, no offence, but I have done this plenty of times. In the States I had found a galvanic shop that was able to hard chrome only the crank pin and this worked perfect.
It is absolutely clear that the pin has to be lapped after coating.
The problem is, that most coatings won't work.
I would like to get back to my original question, please!
stefan is offline
Old 02-15-2009 | 11:45 PM
  #2543
i was wondering if anyone could anwser my question about the xxx motor.cheers.
elche_83 is offline
Old 02-16-2009 | 12:38 PM
  #2544
I think Sirio is comming out with a new xxx in a few months.
NinjaRacer is offline
Old 02-16-2009 | 10:17 PM
  #2545
stefan's Avatar
XXX STI ?
stefan is offline
Old 02-17-2009 | 02:26 PM
  #2546
impalabob64's Avatar
Default lookin 4
Hey guys lookin for WCR s21 short stroke parts P/S let me know.Thanks Bobby Watson
impalabob64 is offline
Old 02-17-2009 | 02:56 PM
  #2547
20 SMOKE's Avatar
what glow plugs work in the 21 other than siro
20 SMOKE is offline
Old 02-17-2009 | 03:01 PM
  #2548
Default Picco
Picco or IDM work perfect
Old 02-17-2009 | 04:45 PM
  #2549
20 SMOKE's Avatar
standard plug, I thought the turbo's were
20 SMOKE is offline
Old 02-18-2009 | 01:18 AM
  #2550
stefan's Avatar
IDM plug = Sirio plug
stefan is offline
