Like Tree1Likes
Sirio engines thread
Old 01-19-2009 | 05:21 AM
  #2506
M7H's Avatar
M7H
Update from RedRC....
UPDATE: Andrea Rossi has confirmed to us that Star Motor Engineering will produce the new line up of Team Orion engines, but he also assured us that despite continued ‘rumours’, both he and Sirio are staying put. Good news.
M7H is offline
Old 01-19-2009 | 07:50 AM
  #2507
stefan's Avatar
Originally Posted by M7H
unless there is still a contract for 2009....
There is...
This morning I called the German Sirio distributor about the article on RedRC. He turned around and called Andrea Rossi who in turn was quite surprised that he's supposed to not work in his company anymore.
He then contacted Eoghain to update the rumour
stefan is offline
Old 01-19-2009 | 01:39 PM
  #2508
GMartinez's Avatar
Originally Posted by stefan
There is...
The best rumor is when it has to be updated like redrc did
I was surprised myself that picco's would still in fact produce parts for the CRF & thought the same that a contract most likely has to be fulfilled 1st before it would be striclty be made @ Star Motors IMO
GMartinez is offline
Old 01-19-2009 | 01:41 PM
  #2509
GMartinez's Avatar
Originally Posted by Roelof
Can you explain to me why Orion is infiltrating Sirio (Star motors) and still let their top engine with all kind of innovations (whats left of it) produced by Picco? Sounds like a kind of odd to me......
Hostile takeover of one of the engine manufacturer that can make an engine faster than Picco?
Lets wait until the Neurnberg Toyfair.
+1
Old 01-19-2009 | 02:58 PM
  #2510
stefan's Avatar
Hi guys,
is there a simple way to put a Sirio EVO 4 STI in a Mugen MTX4????
I have tried to mount one in my car and the carburator slide is hitting my top deck completely.
Do I have to butcher the radio plate or raise the engine?
stefan is offline
Old 01-19-2009 | 05:32 PM
  #2511
occ
Hi guys,
Didn't the motor come with two different ball cup mounts for the slide? One was smaller than the other becasue of this problem on the MTX-4. I know on the EVO 3 STI, it came with two.
occ is offline
Old 01-19-2009 | 06:40 PM
  #2512
GMartinez's Avatar
Hi guys,
Stefan did you try to change the angle on the carb to clear the deck
Old 01-19-2009 | 06:46 PM
  #2513
GMartinez's Avatar
Originally Posted by NitroWD
what's the actual difference between evo3 and evo4 rods? i mean how to tell evo3 rod from evo4 rod? length, hole size or...
in addition, i noticed that evo and sti rods are of different p/n; what's the difference?
Evo3 has a smaller hole on the conrod that connects to the piston pin,smaller hole on the piston
Evo 4 piston hole,piston pin,conrod is larger than the Evo3 so you can not interchange certaun parts. I have used a Evo 4 piston & complete rod in a Evo 3 sleeve with an evo 4 crank & vice versa
Old 01-20-2009 | 02:13 AM
  #2514
stefan's Avatar
Yep! I have had many different engines in that car but never a Sirio. I angled the carb away from the tank as usual and I also rotated the uniball.
The entire carb seems to sit quite a bit lower than on Nova or Picco engines.
I guess I will have to take some material off the radio plate and also shim up the motor a tad.
stefan is offline
Old 01-20-2009 | 07:13 AM
  #2515
Osiris 75's Avatar
Yep, butcher the radio plate.
Osiris 75 is offline
Old 01-20-2009 | 10:33 AM
  #2516
stefan's Avatar
i love that particular radio plate
stefan is offline
Old 01-20-2009 | 11:00 AM
  #2517
SOLOARTIST 702's Avatar
hope its worth it let me know how you like the motor just curious
SOLOARTIST 702 is offline
Old 01-20-2009 | 02:11 PM
  #2518
blown sv's Avatar
wouldnt think you would have to change anything except the engine mount , are you sure its not a low profile engine mount?, ive seen many sirio's in mugens with out the radio tray butchered
blown sv is offline
Old 01-20-2009 | 02:20 PM
  #2519
GMartinez's Avatar
+1 that's was my next ? to ask LCG mount
Old 02-01-2009 | 02:29 AM
  #2520
keavze's Avatar
regarding sti4, other than the 2611 pipe set, which other pipes is good?
i'm intending to use the skyline pipe with either the 5 or 6fins manifold, any reviews/comments?
keavze is offline
