Like Tree1Likes
Sirio engines thread
Old 01-11-2007 | 02:18 PM
  #1786
Sirio2127's Avatar
Thanks Joel J, for clearing that up I am shore the new sirio engines will be extreamly good i know fom the s21wcr and s21pr pro evo2 sti that the extra 0.3mm stroke made the pr pro very strong down low and in my running of it i don't think it ever stoped pulling I can not wait for them. Can you make a post when they are relised to distrubters. Best Regards Jeremy.
Sirio2127 is offline
Old 01-12-2007 | 04:07 AM
  #1787
Z00M's Avatar
Originally Posted by blown sv
skylines good too, bit shorter as well
The skyline pipes are not efra (or ifmar for that matter) legal.
Z00M is offline
Old 01-13-2007 | 01:34 PM
  #1788
GMartinez's Avatar
Originally Posted by Joel Johnson
To All,
I just got off the phone with Andrea Rossi at Sirio and they are not closing their doors. If fact they have two new .21 engines that I feel are going to make a big impact this year. R/C Car Magazine will have a review next month of the Kanai EVO III off road engine that we and Sirio are very proud of. The EVO III has different port and induction timing than the EVO II and it runs very strong. Check out the review when it comes out. Sirio will also be releasing a long stroke Off-Road and On-Road engine (CL7 line) in the spring. No test results on these yet, but the longer stroke will yeild more torque which is what some racers have been asking for from Sirio for a long time.
We should start seeing the new EVO III engines the first week in Feb and the CL7 should be released in April some time.
Joel Johnson
Kyosho America
What's up Joel look forward to trying out the cl7 line.
See ya @ the Winternat's & good luck
GMartinez is offline
Old 01-17-2007 | 04:54 AM
  #1789
kickass's Avatar
To All,
Joel Johnson
Kyosho America
Thats MAGIC
kickass is offline
Old 01-19-2007 | 03:07 AM
  #1790
dameetz's Avatar
Any body here using the STI 5 port version? Hows the performance compare to the 3 ports? can I use 25% nitro on this engine ? coz my 3 ports Sti somehow perform best when I use 16% nitro.
dameetz is offline
Old 01-19-2007 | 10:20 AM
  #1791
rmdhawaii's Avatar
There are two versions of the VR12 Plus pipe. One of which is labeled "Legal Stinger".
http://www.skylinercracing.com/store/c_19.htm
rmdhawaii is offline
Old 01-19-2007 | 12:35 PM
  #1792
afm's Avatar
afm
Rainer, I think what Zoom means is that eventhough it might have a legal stinger, Skyline pipes are no homologated either by EFRA or IFMAR...they don't have an homologation number printed on them...like for example Novarossi's EFRA 2630. I will send you a private mail regarding this issue.
AFM
afm is offline
Old 01-22-2007 | 12:53 AM
  #1793
nikoskar's Avatar
I have A Sirio PR PRo and there are some parts for the carburettor holes.(7mm,7.5 and 8mm)What these do?I have the default.What you prefer?
nikoskar is offline
Old 01-22-2007 | 01:09 AM
  #1794
twiggy's Avatar
these alter the size of the carby. if you go larger then you have to richen the motor to compensate otherwise your engine will be too lean. this also means runtime will decrease.
twiggy is offline
Old 01-22-2007 | 02:02 AM
  #1795
nikoskar's Avatar
Thanks Twiggy,
But what if you change from 7mm to 7.5mm.What are gonna get?More low end?
nikoskar is offline
Old 01-22-2007 | 02:08 AM
  #1796
itchy b's Avatar
i believe that the smaller diameter insert gives you more bottom and less top and the larger gives more top and less bottom
itchy b is offline
Old 01-23-2007 | 01:17 AM
  #1797
twiggy's Avatar
my guess would be the bigger the hole the more power you will have all around ( bottom and top end)
try changing the inserts at your local track and see what the difference is. if you don't like it you could always put the original insert back in, no harm done
twiggy is offline
Old 01-23-2007 | 01:56 AM
  #1798
Sirio2127's Avatar
Hi Guys, I'm shore stock for the pr pro is 8mm maby 8.5mm ristrictor the smaller you go the better fuel economy you will get but you will suffer at the high end of paformance and it should give a tiny bit more bottomend torque and the bigger you go 9mm you will lose fuel eco but gain more high end paformance. Also check out www.kyoshoamerica.com for pic's of the new soon to be relised K3 engine there are pic's and a litle right up about it. it looks difrent to the first 2 versions. Regards Jeremy.
Old 01-24-2007 | 11:39 PM
  #1799
nikoskar's Avatar
Why the Official Sirio Forum is down?Can't connect the last week
nikoskar is offline
Old 01-25-2007 | 10:40 PM
  #1800
nikoskar's Avatar
How do we set the Centax for the Sirio PR Pro.
Some guys said that the inside gap must be 0.5mm and the outside gap(thrust) must be 0.1mm.
But the manual sais that the outside gap must be 0.5mm.
I am confused.
The centax setup is the same for the 1/10 and 1/8 ?
Can you help he to learn how to properly tune my centax?
Regards,
Nick
nikoskar is offline
