Like Tree1Likes
Sirio engines thread
Old 02-21-2009 | 06:35 AM
  #2551
GMartinez's Avatar
Originally Posted by NitroWD
anyone tried using their sti with picco pipes like 2607?
If tried it but felt a huge loss in power mostly topend
GMartinez is offline
Old 02-21-2009 | 10:30 AM
  #2552
DogboneS's Avatar
Do LRP turbo plugs fit Sirio turbo heads for the .21 size motors?
LRP Turbo = Picco Turbo = Sirio turbo?
DogboneS is offline
Old 02-23-2009 | 02:01 PM
  #2553
The sirio plugs are probably the least expensive glow plugs available. Stock up on them when you can find them.
Also, I just ran my second race on my XXX. It is still breaking in so I am periodically still having the engine "go rich" on me. Overall I am quite happy with the engine.
Now I have two good choices with the IDM and the Sirio engines.
Scott Fisher is offline
Old 02-23-2009 | 03:09 PM
  #2554
GMartinez's Avatar
+1 there was a slight price increase& even with that there still the least expensive plug available
Old 03-03-2009 | 06:54 AM
  #2555
diesel's Avatar
Default XXX bearing size
Anyone got the front and rear bearing sizes for the XXX engine?
Cheers.
diesel is offline
Old 03-03-2009 | 08:30 AM
  #2556
Speyederjedi's Avatar
Try the Novarossi 2630 with the medium header. Works great on my modded Evo 4 STI. Motor is much better off the bottom and still has plenty of top-end just keep an eye on run time cause it does like to burn some extra fuel.
Regards,
Speyederjedi
Speyederjedi is offline
Old 03-03-2009 | 11:44 PM
  #2557
blown sv's Avatar
Cheers.
its the same bearing as in the evo 4
blown sv is offline
Old 03-04-2009 | 08:08 AM
  #2558
diesel's Avatar
Default XXX bearings sizes
Got it. Thanks.
Here are the dimensions for reference if anyone needs it:
Front : 7 X 18 X 5 (mm)
Rear : 12 X 22 X 5 (mm)
diesel is offline
Old 04-04-2009 | 06:15 AM
  #2559
GREGORY!'s Avatar
Hi guys!
any feedback for the xxx?
does any one when the sti version will be available?
GREGORY! is offline
Old 04-04-2009 | 10:50 AM
  #2560
Originally Posted by GREGORY!
Hi guys!
XXX=good. I have three races on mine now and it seems to finally be broken in although it still locks up on the box every once in a while.
Old 04-04-2009 | 11:28 AM
  #2561
GREGORY!'s Avatar
scott you have the xxx or the capricorn version?
i have ready that the capricorn version takes more time to break in becauce of his excessive pinch.
do you use the 2611 pipe?how many minutes it can make?
did you changed the rod after the run in?
where is his power band?it is like the others sirios?high rpm style?
thanks !
GREGORY! is offline
Old 04-06-2009 | 05:41 PM
  #2562
dg8one's Avatar
i have a sirio evo2 WCR motor anybody know if i can used a conrod from a different motor
dg8one is offline
Old 04-06-2009 | 05:45 PM
  #2563
thanks !
I have the Sirio XXX. I have only run the 2611 pipe (older version). I am still using the orginal rod as they seem to last the way the Novarossi rods do.
I have not had a problem making 5 mins yet but it doesn't get the mileage that the IDM engine gets.
This engine seems to have a more broad power band. It still has good top end like what we are used to, but better bottom end than some of the earlier Sirio engines. I do have a good clutch setup that seems to work pretty well.
Old 04-06-2009 | 05:47 PM
  #2564
GREGORY!'s Avatar
nice scott!have you test the evo 4?how do you compared it with xxx?
GREGORY! is offline
Old 04-06-2009 | 06:08 PM
  #2565
If you are taking about the Sirio Evo 4, I do have one and like the XXX better. If you are talking about the IDM Evo 4, I just ordered one a few mins ago and should have it here in about a week. I want to give it a try at the Motonica Grand Prix which is in about 3 weeks.
