Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 04-26-2012 | 06:20 PM
  #6526
houston's Avatar
Originally Posted by tallyram
Monty, how would an old mugen 1005 pipe work on a p5xlt or an x7 extreme? What type of powerband can I expect for both engines?
Msr/bullit 1005 was a very good pipe on novas
Never tried on X7 but i bet it would be a "prepare for flight" experience
Not too sure on mileage , pipes have advanced since then
houston is offline
Old 04-26-2012 | 06:30 PM
  #6527
tallyram's Avatar
Thanks for the info! Might be worth a try for my friend. He wants POWER!
tallyram is offline
Old 04-26-2012 | 08:15 PM
  #6528
joey91473's Avatar
Originally Posted by houston
p5xlt, silicone filling and bench break in , perrrfect , recdommend getting the 2096ss at some point though
Hell yeah. Can't wait for mine.
Monty, in the meantime before i get a Nova pipe I can run a 2058 right?
joey91473 is offline
Old 04-27-2012 | 10:12 AM
  #6529
do not use hobbico after run oil with filled cranks , you might as well go buy a bottle of marvels mystery oil anyway , same stuff
castor oil makes great after run oil , specifically byrons lube booster or u can use novarossi 1m2 or rbmods aro
odonnell is good fuel but please add castor oil for break in
Monty, I just saw this post about Hobbico After Run Oil, and I never knew. I have a few engines that have a filled crank and I used ARO in them, not a lot maybe 10-15 drops total. I usually put ARO in after a race weekend (usually 4-5 drops), but I have not ran the .821 with the filled crank much this year. I know now not to do it, but have I already damaged my motors? I take it by your post above that Marvels Mystery Oil and Hobbico ARO are basically the same thing, correct?
Will this ARO be o-kay, it is sold at A-main so I know I can get it.
This is a bottle of "Afterlife" after run engine oil with applicator from GMK Supply. Afterlife has a unique applicator which allows you to add after run oil at the end of the day without having to take off either the air filter or glow plug and expose your engine to dirt. You just inject the "Afterlife" thru the fuel line inlet. Instructions are included. The after run oil is high quality, will help prevent rust and corrosion, is completely safe for cranks that have silicone putty ramps and is easy on the glow plug the next time you start the engine.
Thanks, Mike
mikal is offline
Old 04-27-2012 | 10:36 AM
  #6530
bigjayjay1's Avatar
Thats whats one my P5 now with a 2060 header worked well on the bonito going to give a whirl this Sunday
bigjayjay1 is offline
Old 04-27-2012 | 05:22 PM
  #6531
I would like to thank Monty for his amazing service and professionalism. I was having issues with my P5 engines due to using bad fuel. Monty knew the problem immediately and solved the problem quickly. My two "new" engines are even better than before. My buggy now runs on a 13 minute tank and the truggy is close to 11 minutes, which is outstanding for a P5. The bottom end is amazing and the top end makes other engines like stock Bonito and Os Speed feel slow in comparison. I would recommend HES and Monty for all your needs on nitro engines.
Thank you Monty for making my racing experience with nitro engines a breeze.
Zuma/Mat R.
Zuma is offline
Old 04-27-2012 | 08:48 PM
  #6532
Losimoe's Avatar
Thanks, Mike
im also curious to know as what ARO would do to a silicone filled crank. i have been running HES P5 with filled crank and have been using Hobicco ARO for about 2-3 weeks before i got to know that the brand is a no-no. This was almost a year ago. never used any ARO since.
Maybe you can shed some light here Monty. Whats the tell tale sign that using the wrong ARO would look like if used with silicone filled cranks.
Cheers,
P/S: still looking for that review on the .25 Roma
Losimoe is offline
Old 04-27-2012 | 09:16 PM
  #6533
air8's Avatar
If you use quality fuel the ARO shouldn't be needed. Good fuels leave the insides coated with oil. I know that's not always possible though to get in some areas. Also if your engine will be sitting for a long, long time the ARO would be beneficial.
air8 is offline
Old 04-27-2012 | 10:48 PM
  #6534
houston's Avatar
Cheers,
roma seems to be a very nice engine , finished the in car break in on one today , very stable running engine , great feel and actually quite a smooth power delivery , best pipe was 9853ss/41021 , larger displacement likes a larger displacement pipeset as it moves more exhaust tried a few
houston is offline
Old 04-27-2012 | 10:52 PM
  #6535
houston's Avatar
Zuma/Mat R.
AWESOME Mat!
Appreciate the kind words bro , you got my number if ya need anything
houston is offline
Old 04-28-2012 | 02:57 PM
  #6536
ses601's Avatar
well, i guess i'll piggyback on zuma here......i grabbed a p5, exhaust, and some other important info from monty.i finally got my mugen together and long story short, my nitro days are back in full-swing! in fact, they will last as long as they are selling/running nitro my motor had the bench break in, so i just ended up running about 12-1300cc of fuel through it. started to tweak the tune a bit and it was still SUPER smooth and on point. as for mileage, i actually got jusssst over 13 minutes a few times (medium sized track, and running just about to what it would take to qualify for the a main). if i didnt have to leave early, i'm sure i'd have another line here about how well it helped me in that main! whatever monty does, he does it well!!! THANKS!!!
ses601 is offline
Old 04-28-2012 | 03:08 PM
  #6537
revo61's Avatar
Is the castor oil you get from a drug store similar to what is in fuel. I had 2 free quarts of powermaster and used it for break in my X3, but I won't be able to get more for a while. So I am going to keep using odonnell but add some castor oil. How much should I add to a gallon?
revo61 is offline
Old 04-28-2012 | 06:00 PM
  #6538
beidle99's Avatar
I can back up that claim, since I was pitting right next to Scott today. My Plus 4 ran pretty flawless today as well. I have a 11 to 11:30 minute pit stop motor on a medium sized track in my plus 4 and I tend to be very heavy on the throttle. Had some mechanical and fuel delivery issues today, but the motor worked its way through these issues. Pinched fuel line for one qualifier, motor temped 255 at end and beginning of the main pressure line came off nipple of tank, caused lean bog but problem was figured out pretty quickly in the pits. Motor ran great for the last 15 minutes of the main, my pit man checked temp at the pit stop and it was 219 with more then enough power for the track. Now if I could just keep the car together and a clear head i would be in business. One more plug...check out sweep tires, Tried a set of silver Square Armors today and with over a half hour of running time on them, they still look brand new!
beidle99 is offline
Old 04-29-2012 | 01:33 PM
  #6539
hookem34's Avatar
R/C Tech Elite Member
2oz will give you just a hair over 9% oil for the OD Speed Blend. Drug store castor is as good as it gets.
hookem34 is offline
Old 04-29-2012 | 01:50 PM
  #6540
Default motor
Monty, What motor and pipe would you recommend for a serpent truggy?
1airborne
1airborne is offline
