Houstons Engine Service H.E.S.
#5779
Ok..I just bought a BONITO for my STRR Evo. Do I want to run the 2096/21 combo or the 9853/21 combo. Which pipe is better for that engine and truggy combo. What are the advantages and disadvantages of each pipe.
#5780
the 9901ss seemd to work great on the boneytoe in the truck also either 41021 or 41020 headers
#5786
Houston, I know you got to be tired of pipe/header questions "but", setting up my spare dirt oval car for someone to use this weekend. Always ran a plus 4 on it with 9901/41021 but it shat its guts thru the exhaust after 10+ gallons last weekend. Going to have to use a N21R purple head 3 port that Jim worked on a few years back. Problem is the pipe header combo. What i always used with it has disappeared out of the box.
Track will be short, most likely around 150 ft run line. Car is setup to drive thru the corners and power off, not do the drifting stuff.
Pipes available are:
9901 41005 - 41020 - 41021
Dynamite platinum 053 MR stk header
JP 3. Stk header
JP 4. Stk header
normally I would just test, but since this is a bigger race time will be limited. Can ya help a guy get his oval fix?
JP 3. Stk header
JP 4. Stk header
#5787
JP 3. Stk header
JP 4. Stk header
JP 3. Stk header
JP 4. Stk header
9901ss /41021 would be my next choice
For overall grunt and rpm I would recommend putting the 41005 on the 053mr though , probably what I would use
Fyi , check the rod in that n21r limited
#5789
For overall grunt and rpm I would recommend putting the 41005 on the 053mr though , probably what I would use.....
I put that combo on my FMS and it was reeeeally nice, in buggy....
The Mugen Levitated....
#5790
Rock n Roll !
Trying a .23 novarossi configuration I came up with in truggy this weekend , got high hopes for this setup
What do you guys think about if I spec out an X3 race ? Pretty much what I have been building for a lot of guys but prebuilt from the factory
22Likes
