Like Tree2Likes
Go-Tech Engines Thread
Old 05-03-2009 | 07:08 PM
  #6616
max_chen's Avatar
Originally Posted by mtbkym01
Hey guys,
I'm grabbing a GO 5 port for my ST-RR truggy, I see GO have a new pipe, being the EFRA 2072, has anyone tried this pipe yet? I was originally looking at the 0801 pipe.
Also, what plugs do you guys run in your turbo head GO's?
Yesterday,The GO TECH team driver was TQ and top A-main final race in Taiwan,He was used GS CLX and newest GO EFRA 2072 tuned pipe.
The top B-main final just had used GO EFRA 2072 tuned pipe also.
max_chen is offline
Old 05-03-2009 | 08:22 PM
  #6617
Tabushi's Avatar
About life on go engines mhhhh ... right now for me :
- 7 port .21 on my buggy : 6 1/2 gallons and running strong.
- 6 port .25 on my truggy : 6 gallons and running strong (little bearing noise due i forgot to lube it and got packed and unused for 6 months, but the engine its ok).
- 5 port .21 on my 1/7 DM ONE : 5 gallons and running strong, and i lend the engine now to another driver wanted to try a GO.
Today i broke inn a 3 port on my 1/7 onroad DM ONE, after 10 tanks i tuned for hard racing and wow, that little beast its really strong !!! i was mistaken i though will be not enough power but people loved it at the track !!, i used the 2072 pipe on it ... all i can say is WOW.
WIll try to get a video on May 17th with this 3 port engine ...
cya,
Tabushi is offline
Old 05-03-2009 | 09:42 PM
  #6618
slumlord's Avatar
Russ call me!
slumlord is offline
Old 05-04-2009 | 07:25 AM
  #6619
keithw11's Avatar
whats the size of the front and rear bearings for 5 port go thanks
keithw11 is offline
Old 05-04-2009 | 08:03 AM
  #6620
I know the front bearing is 7x19 since I just installed one in my 3P-R.
http://www.amainhobbies.com/product_...oducts_id/4364
mthird is offline
Old 05-04-2009 | 08:17 AM
  #6621
The rear is 14x25.4x6mm, and the front is 6 mm thick also.
malik is offline
Old 05-04-2009 | 01:31 PM
  #6622
tagalong_74's Avatar
FINALLY my track is opening this weekend for practice. Should have been open over a month ago but thats ok. Get to try out this 28 6 pt that I have
tagalong_74 is offline
Old 05-04-2009 | 04:52 PM
  #6623
mtbkym01's Avatar
So, what plugs guys? O.S. or O'Donnell?, any others?
Cheers
mtbkym01 is offline
Old 05-04-2009 | 05:14 PM
  #6624
Last year I ran OS they work awesome P3-4, I am trying the OD77T now and like it too for 1/2 the price. Ok guys I got this modded 3 port I am about to break in, I know the 086 is what it calls for but the modder Powerhouse says to use something in the 053 range and found a 2047 GO pipe used for a nice deal. Anyone used the 2047 on the 3 or 5 ports stock and or modded??????
malik is offline
Old 05-04-2009 | 06:59 PM
  #6625
grizz1's Avatar
Hey Malik, I use the 2047 with the 0801 header on my modded 5 port and it rocks. I ran a friends lightly modded 3 Port R Spec last weekend (my motors were both having some TLC put on them ) and this pipe combo worked really well on the 3 Port too. I think it is the poor mans version of the new 2072 pipe just released
grizz1 is offline
Old 05-04-2009 | 08:09 PM
  #6626
Default thank you bigmatt,go tech, racefactor
everything going smooth. i mailed my GO to Russ today. THANKS GUYS, Russ had it handled before go tech could respond to him that's FAST. if you are thinking about a new engine go GO TECH
leapinglizard is offline
Old 05-05-2009 | 01:11 AM
  #6627
ConciliumDesign's Avatar
Default pIPES
Anybody try a 086 with a 0801 header on a 7 port? Would that be similar to a 2047 with a 0801 header? I don't have a 2047 pipe but I was curious about pairing up the top end pipe with the longer header.
ConciliumDesign is offline
Old 05-05-2009 | 02:33 AM
  #6628
grizz1's Avatar
I am guessing you would end up with a pipe very similar to the 0801.
The 086 is a true top end pipe. Short header and small chamber. Not sure how it would go with the longer header - only one way to find out. Give it a go and let us know what itīs like.
The 2047 is more of a mid - top pipe as opposed to the 086 which is really just a top end pipe, which is why it compliments the 5 port so well. The 5 has so much bottom it doesnīt need any help down low, and the top end 086 helps to ring a few more revs and power out of the top end.
The 2047 with the 0801 header just seems to be a nice blend of bottom, mid and top rolled into one, and performs good an all the GO Pro motors.
Best save your dollars and pick up one of the new GO 2072 pipes. They are looking like being the goods from what I have heard so far.
grizz1 is offline
Old 05-05-2009 | 02:50 AM
  #6629
Gizmatron's Avatar
Just waiting for my rods and wrist pins to arrive from massive along with my NEW 2072 PIPE..YAY!!! Can't wait to try this..was racing Sunday ..in 5th place overall going into the semi finals ..7 port performing flawlessly (actually 2 laps ahead of everyone else in the 1/4 final) then disaster struck..centre pinion had 2 screws loosen enough to let the oil out of the diff and the pinion move off centre..moments later it ate the internal gears in a big way..Totally ripped the satellite gears and their axles out of the slots in the diff housing..it was messy..needless to say not repairable in time to restart and finish anywhere useful...never mind there's always another race!
Gizmatron is offline
Old 05-05-2009 | 04:42 AM
  #6630
has anyone tried the ofna 086w/ L shaped header, the header looks to be a little longer then the dyn086 ?
rkhess is offline
