Like Tree2Likes
Go-Tech Engines Thread
Old 06-22-2009 | 06:42 PM
  #7366
JPierson's Avatar
Cool
That's what I need run time run time run time. Our track has 47 second laps!! Run time please!!!
JPierson is offline
Old 06-22-2009 | 07:00 PM
  #7367
tagalong_74's Avatar
like we have said before if your looking for run time get the 7port. Normally the more ports the better the fuel usage meaning better fuel mileage. You will definitly want the 7pt for longer tracks lol
tagalong_74 is offline
Old 06-22-2009 | 07:01 PM
  #7368
pantera nitro's Avatar
You'll love the 5 port JP!!!
our track is approx 340 metres and a lap will take you approx 45-50 secs averaged.
i've got 4 mates and myself all running Go's 3/5 and 7 ports and we all complete 10 minute heats with no fuel stops.
as grizz said before, if you adjust the Exp and Travel on the radio not only does it increase the run time but it also reduces your lap times through you being more consistent and controlled.
Mike
pantera nitro is offline
Old 06-22-2009 | 07:05 PM
  #7369
JPierson's Avatar
O.k. Thanks for the help!
JPierson is offline
Old 06-22-2009 | 09:33 PM
  #7370
grizz1's Avatar
So many choices JP
You won't go wrong with either the modded 5 or 7. The Stage 5 5 Port has greatly extended top end when modded to this spec. In fact, it is safe to say it pretty well has the top end of a 7 Port. I run both motors so can get a very good comparison. The other beauty of getting a modded motor (other than they go like stink ) is the increased economy. If you get a Stage 5 motor and run the 6.5 restrictor and set up epa and expo like described previously, you should be getting 12 - 13 min without running it on the ragged edge.
If you go ahead and get the GO, PM me for break in method and a few tips for care and maintenance. Hope you join the GO fraternity.
grizz1 is offline
Old 06-22-2009 | 11:41 PM
  #7371
spura's Avatar
Originally Posted by grizz1
Sure sounds like your really rich or you got an air leak somewhere. Check everything over and go back to HSN .25 in from flush and LSN 1.5 in from flush. Start tuning from here and see how you go. Dependant on ambient tems and humidity etc,you should end up with a race tune of around .5 in HSN and 2 - 2.5 in LSN (with the long needle carb). Also you might like to remove the HSN needle and blow out the HSN needle seat.
Grizz, again you was right
Removed hsn and blowed out some debris what I found+turned lsn almost 3in and hsn little more than .5 and got another engine yesterday was great also I changed pressure pipe to about 24cm(before I had about 21cm).
The truggy was running very well,power all around, only now it sometimes flame out when you push throttle at very beginning, (let say after few meters) after you have been idling for longer on track.
spura is offline
Old 06-23-2009 | 12:28 AM
  #7372
grizz1's Avatar
Hey, thatīs great news Spura
With the take off thing - sounds like it is a little rich on the bottom end (LSN).
The crankcase will load up with fuel when the motor sits at idle for a little while. The richer the LSN the more it loads up. Then when you go to take off this excess fuel extinquishes the glow plug.
Even a well tuned motor will load up eventually and stall on take off.
Just lean the LSN a little at a time until it will idle cleanly at the same idle speed (no sudden drop in revs as it loads up) and will take off clean and fast after sittng for 10 - 15 seconds.
You can use the pinch test also - bring the buggy in after a short burst. Pinch the fuel line about 1 inch back from the carb fuel nipple.
What you are looking for with a good bottom end tune is for the revs to rise up only slightly (about 500rpm) and the motor to cut out between 4 - 5 seconds after you pinch the line off. This means the LSN is pretty much spot on.
If the motor does not increase in revs and just dies quickly - the LSN is too lean.
If the motor revs up quickly to a fairly high rate, and/or takes longer than 4 - 5 secs to die, then the LSN is too rich. Cheers
grizz1 is offline
Old 06-23-2009 | 12:43 AM
  #7373
grizz1's Avatar
Spura - you got PM
grizz1 is offline
Old 06-23-2009 | 12:56 AM
  #7374
spura's Avatar
you mean with 6.5 restrictor to put lsn 3 turns in ( i think it will be about 3.25..)
isn't too far in?
spura is offline
Old 06-23-2009 | 01:02 AM
  #7375
spura's Avatar
Spura - you got PM
Thanks, got one
The info what really I have not found is what is "correct" lenght for fuel tube and pressure tube for Go engines for buggy and truggy. Some years ago I had fantastic OPS(Radical) engine, and when I spoke with some people from OPS factory in Italy, they said the lenght of tubes is very important...
So, what you have found for Go engines?
Thanks.
P.S. I found a post that pressure line would be about 7-9inches, that was one opinion...
spura is offline
Old 06-23-2009 | 02:17 AM
  #7376
grizz1's Avatar
isn't too far in?
Hmm - I didn't notice yur needle settings in your last post. They actually seem a little on the lean side. Does it splutter a bit when it stops or just cut out ?
Get your HSN back to .25 in from flush. The HSN setting is very sensitive with the long needle carbs. Once you go just a little too far it will lean bog and start cutting out. Take the LSN back to 2.5 turns in from flush and see how that runs. Make sure idle gap is correct too.
Never worried too much with fuel tubing length. It will change your tune settings because of fuel pressure differences, but as long as you tune the motor to suit the length of tubing I don't think it will make much difference, but I don't know for sure. Is there an optimum length, anyone ??
grizz1 is offline
Old 06-23-2009 | 02:34 AM
  #7377
looper's Avatar
Well i gave it an honest go and i can say that my first go engine ever purchased is my LAST go engine ever to be purchased.
14 tanks in and it would not tune, i asked numerous questions here about tuning this particular carb and got many thorough answers and i followed the advise to a t. yet this mill still would not tune at all.
The kicker happened just a few moments ago, removed the engine from my buggy and noticed the engine no longer had any pinch (14 tanks old) and the carb which i was going to replace with a os vspec carb is completely siezed in the engine, it will not come out or budge at all! i removed the pinch bolt assembly to make sure there was nothing holding it in place.
I gave it an honest go, i gave go engines a chance and they failed me miserably.
So now i have a very expensive paperweight, or i could recycle it and get .25 back.
looper is offline
Old 06-23-2009 | 03:07 AM
  #7378
grizz1's Avatar
BUMMER Sorry to hear that.
If you have followed all the advice given on here as regards break in, long LSN tuning, shortening LSN needles, etc, etc then there isnīt much more advice we can give you.
No pinch after 14 tanks would suggest something is not right, either with the motor itself, or it has been run very lean (not saying itīs your fault ) but if the long lsn carbs are not set right on the hsn, they will run very lean, and with a new motor you might possibly end up with that sort of result. Just my .02c worth. Itīs a pity it didnīt work out for you, because everyone else seems to have huge success with the GOīs. Seems you have made your mind up about them though, so not much point trying to convince you otherwise.
grizz1 is offline
Old 06-23-2009 | 03:19 AM
  #7379
mattwoodcraft's Avatar
i have read a while back the length is just around 12 inches as this affects the pulsing in the fuel tank and pressure i cant remember if its to short it can give to much pressure and cause flame outs after refueling something but around or just under 12 inches is what you want thats what i have read and told to hope that helps
mattwoodcraft is offline
Old 06-23-2009 | 04:34 AM
  #7380
spura's Avatar
Sorry, 12inches for fuel line?
spura is offline
