Like Tree2Likes
Go-Tech Engines Thread
Old 05-02-2009 | 07:55 AM
  #6586
Default GO great engines
it happen while racing. it was still driving but you could see the whole motor moving like a chevy 350 with a busted motor mount, and thats what i had broke mounts. i did not land hard or anything, just came in to pit and my car got pulled off the track, thought everything was fine, tell i looked more closely
leapinglizard is offline
Old 05-02-2009 | 08:07 AM
  #6587
Default race factor
if some one from race factor can email or call or something. Let me know where and when i can get a crank case so i can get back on the track. maybe there will be some warranty on the little GO i bought it in late feb. just got it broke in and it busted ????? is my case has r21 on one side and G on the other the GO TECH cases ive seen have B21 on one side and GO on the other. and if it is covered under some sort of warranty then that would be cool
Wesley Young
[email protected]
Old 05-02-2009 | 08:43 AM
  #6588
bigmatt's Avatar
leaping lizard, you need to go back about 6-10? pages and there is a phone# to get a hold of Russ Jones from race factor. also you will need your receipt. from what I understand if you bought it out of the united states there is no warranty. only the country in which you bought it in will it be covered. do not hold your breath waiting for Russ Jones to contact you through this thread, it will never happen. there is a gent on here that goes by tech22? or something like that. he is on vacation right now but when he chimes in he can probably help you. also I thought malik? was sponsored by race factor he can probably get you the phone number.when it comes to any dealings with the go tec line of motors I only really buy from massive mods. I live in California and he is in Australia but the service is second to none. it's worth the wait and he stands behind his products.I would imagine he would have already taken care of the matter.
bigmatt is offline
Old 05-02-2009 | 08:50 AM
  #6589
Thanks that helps a lot i will get everything together and contact Russ. i bought it from A-main hobby. in the US i live in Texas. I will call asap and send them the receipt again thank you
Old 05-02-2009 | 09:16 AM
  #6590
bigmatt's Avatar
I live 20 minutes away from amain. did you contact their costumer service and ask or tell about the problem? they are fantastic people over there, who I am sure would bend over back wards to help you.
bigmatt is offline
Old 05-02-2009 | 11:00 AM
  #6591
Russell's number 1-928-274-4017. Just call and see what he says. He may want you to send it to him. Dont quote me on that but I know that if he's going to help you out, then he is going directly to GO with the same thing so he gets re-embersed. The numbers on the side of the block I guess the part that broke off will have to have US as the 1st 2 letters then a bunch of number. Thats how they know where the mill came from all US ones from Racefactor ect ect. But he is an awesome dude and yes he dont come on here much I do though try to call and or e-mail him. If you have any issues let me know and I will try to help you the best I can.
malik is offline
Old 05-02-2009 | 11:01 AM
  #6592
will g's Avatar
Wesley Young
[email protected]
wesley you can get ahold of russell at [email protected] or phone him at 928-274-4017 thnx will g
will g is offline
Old 05-02-2009 | 04:40 PM
  #6593
touringdriver's Avatar
R/C Tech Elite Member
i got a go tech .21 5 port turbo engine. its been broke in properly by the book. my 1st race with it was today, my only problem with the engine is at topend on the end of the staraight the engine would die while on throttle. we tried leaning and richening the high side with no success. could i be fighting the wrong end of adjustments? should i be trying to adjust the low side? never been faced with this problem. i am running a o.s. p3 plug.
touringdriver is offline
Old 05-02-2009 | 04:55 PM
  #6594
bigmatt's Avatar
do you have at least 1 gallon of fuel through it? that's close to break in. also you are correct adjust low speed first. make sure your idle is set at .7mm-1mm then start with the lsn. also make sure car is warmed up at least 1 tank through it. also set the hsn back to flush then 1/2 turn in make sure you have a lot of smoke coming out when getting on the throttle. you will know when you are close to the sweet spot when you can idle for 10 seconds hit the gas and go.
bigmatt is offline
Old 05-02-2009 | 05:45 PM
  #6595
Touringdriver, I am sorry if this is a stupid question I havent seen you on here before do you know that the GO mills use a long LSN which in turn makes it tune kinda backwards from other mills? How much fuel do you have through it, and how did you break it in? What temp were you at when theis "dies at the end of the straight" happens?
malik is offline
Old 05-02-2009 | 07:26 PM
  #6596
2fst2c's Avatar
It would really depend on his carb. I have 3 Go motors and 2 have short needles in them and 1 had the long.
2fst2c is offline
Old 05-02-2009 | 10:21 PM
  #6597
Default thanks for all the help
i got a hold of russel from race factors. and you guy were right he is going to fix me up i will buy several more motor from these guys and tell everyone about my great exprince with GO TECH and RACE FACTORS and will let you guy know when i get it back thank again
Old 05-02-2009 | 11:22 PM
  #6598
22Racer's Avatar
What chassis was the motor in?
Rex
22Racer is offline
Old 05-02-2009 | 11:36 PM
  #6599
Default losi
It was in my losi 8ight 1.0.
I'm going to mail it to Russell monday and see where we go from there. When I talked with him he said he would switch the case for me. Now that is a company worth spending your money at talk about bang for your buck. Thanks for all yall's. Yep I from dallas texas and I said yall. I am completely new at nitro but have raced since 92 I took a brake and came back and there was nitro, so I went from a sponsered 1/10 stadium truck, to rookie 1/8 buggy guy. It will be fun and again that's for yall's help
Thanks Wes
[email protected]
Hey if I can help yall at all let me know I specialize in business funding,lines of credit,credit repair, and radio addvertizment for CBS let me know if I can help
Old 05-02-2009 | 11:53 PM
  #6600
22Racer's Avatar
Mak sure the case wasn't bottoming out on the chassis or it may break again.
Rex
22Racer is offline
