Go-Tech Engines Thread
#6571
massive mods is listing new type O rings on his website..says new nitride material won't crack or split.. http://www.massivemods.com.au/produc...roducts_id=207 cheap too
#6574
3 Port - good all round motor. Smooth linear power curve. Nice buggy motor.
5 Port - Massive bottom end, good mid and top end. Best suited to truggy in standard form (modded motors can be made a bit smoother on the bottom)
7 Port - Good bottom end, great mid and massive top end. Great buggy motor.
Pipes
3 Port - GO 0801 or Dynamite 086
5 Port - GO 0801 or Dynamite 086 (2047 with long header on long open track)
7 Port - GO 0801 or Dynamite 053 (2047 with long header is very nice)
Check out the new GO 2072 pipe just released. This should work very nicely on all the engines, particularly the 7 Port. It is ¨basically¨ a top end (2047) pipe with a longer style (0801) header, plus it has a few more things going on to bring the best out in the GO range of motors. Can´'t wait to get my hands on one
#6576
#6578
Look up a couple posts.. Here it is
Hey Malik, I just checked out the MMods O rings - they look good. I went to the fuel tubing because the factory O rings kept drying out. Ended up with a blockage from all the shredded rubber sludge off the O rings blocking the needle jet. As far as size of tubing goes, I just get the standard tubing from my local hobby shop, I am guessing it is the thinner of the two sizes. I find it works really well, and gives a nice ¨tension¨ to the needles so they are easily adjusted but not too tight.
#6579
I will check out those MMods O ring kits myself though. Pretty swish
#6580
My GO Broke?
The engine mounts broke off the same on both side can someone from RACEFACTOR INDUSTRIES e-mail me [email protected] I really dont want to buy or go with another brand, well if i do it will be the novarossi or a OS V SPEC, but my GO was fast...
has anyone eles had this problem let me know Please.
#6581
My GO Broke?
Thats the first time I have heard of that happening. How and when did it happen, ie during a race or while the engine was out of the car etc etc.
#6582
how many guys run the 3 port combo in the buggy the motors seem really wel priced i will have to get one to try out im not sure just yet 3,5,or 7 port i the track i race at have some pretty big jumps just out of corners and i need th get speed up pretty dam quick at the moment im sure any motor will be better than then grp motor i have now
#6583
Value for money, you can't beat it.
#6584
Yeah the 7 is a beast but i feel if you dont have super long straights you really dont need it. I like it alot but dont need it where I am at UNFORTUNETLY, a 5 port will be very abrupt on bottum but if you had it modded to smooth it out for buggy its the bomb and the 3 port race will get the job done too.
#6585
2Likes
