Like Tree2Likes
Go-Tech Engines Thread
Old 08-03-2009 | 05:10 AM
  #8071
mattwoodcraft's Avatar
Originally Posted by arizona82
Crankcases split in Mugen mbx5 buggies and truggies on a regular basis. I know someone that split 3 vspec cases in a month. What car are you running? A switch to differant motor mounts will cure the problem.
whats the clearance on the chassi and motor when bolted down ?
is the chassi milled out in the area the motor bolts down in , i would certainly look at differant mounts to try it will get expensive replacing motors all the time..
mattwoodcraft is offline
Old 08-03-2009 | 03:27 PM
  #8072
MassiveMods's Avatar
Originally Posted by Gizmatron
I agree don't mix the nitro but the higher nitro will make the engine run hotter not cooler which is why a cooler plug is recommended so it won't burn out..I'm prepared to be corrected on this by an expert but higher nitro%=higher combustion temp....as far as I know..
Yes correct , more nitro means hotter combustion temps however more nitro lets you run a tad richer which will cancel that out however ! if you run high nitro with incorrect shimming you will blow plugs and run hotter head temp with a cooler exhaust temp however if you run lower nitro with more shims you will get less torque but higher top end speed with hotter exhaust temps ! and a cooler head temp !
MassiveMods is offline
Old 08-03-2009 | 03:37 PM
  #8073
oops forgot to tell you MG66 on line wed ; 0 )
Old 08-03-2009 | 03:51 PM
  #8074
RETRO RC's Avatar
Originally Posted by racer-007
ok ill leave it and just lean the bottom abit so it at lest move a little
i also found the motor i was talking about
http://www.go-engine.com/in-products...15P-P820SG.htm
yeah its a bit differnt to my gen5 5 port but it will do for a spear.
the 1 your showing is a gen4 engine does it have that exact head or does it have this 1
http://carolinasrc.com/Webstore/Scri...idproduct=3886
the pic above is a gen3 or earlier, visiby the only difference is the cooling head.
Adrian
RETRO RC is offline
Old 08-03-2009 | 09:58 PM
  #8075
racer-007's Avatar
hi no im sure its not that one, its not a turbo head as well.
racer-007 is offline
Old 08-03-2009 | 11:45 PM
  #8076
RETRO RC's Avatar
sorry I didn't mean if it was exactly this model I was only trying to show the different cooling head
RETRO RC is offline
Old 08-04-2009 | 12:12 AM
  #8077
racer-007's Avatar
hmmm
well the cooling heads look the same to me so hopfully a pic will come up lol
so can anyone tell me what gen this is im going to use it as a spear as my gen5 5 port is nearly broking in
Old 08-04-2009 | 12:30 AM
  #8078
zJatoRad's Avatar
Looks like a Gen 4 to me.
zJatoRad is offline
Old 08-04-2009 | 03:20 AM
  #8079
grizz1's Avatar
+1 on that. Looks like a Gen4 with the cooling head on sideways
grizz1 is offline
Old 08-04-2009 | 03:22 AM
  #8080
racer-007's Avatar
Opps....
Welcome back Mate.....
Old 08-04-2009 | 04:31 AM
  #8081
Gizmatron's Avatar
yeh welcome back grizz1 been kinda quiet without you..hehe
Gizmatron is offline
Old 08-04-2009 | 05:00 AM
  #8082
GX-5R showing in stock here
http://rcmodels.eu/product-6888-1145.php
damo666 is offline
Old 08-04-2009 | 05:20 AM
  #8083
haya there grizz ... welcome back mate ......
well guys off to the nationals tomorro t orace my truggy i will speak with you all later
Old 08-04-2009 | 07:05 AM
  #8084
Guest
Default New motors
Hi guys does go tech have the new motors out??? 3 port race spec, 5 port, an 7 port?? And where can I see a pic of them?
LOSIRACER77 is offline
Old 08-04-2009 | 07:31 AM
  #8085
Gizmatron's Avatar
link to a site selling them in denmark 3 posts up.....
