Mugen MTX-3
Old 05-25-2005 | 03:31 AM
  #15181
THE DOCTOR
Registered User
Harwood, MD
92 Posts Since Nov 2003 Yesterday, 08:47 PM Bubbles in fuel line | Post #1
When I go out the engine runs fine for the whole tank. When I come in to refuel the engine will stall and I see bubbles in the fuel line. I have the fuel line going around the back of the engine as I have all last year and never had any problems. This year it is a spec. engine and I put new fuel line on it. I was wondering if I need to run the fuel line in front of the engine. Any thoughts? Thanks
THE DOCTOR is offline
Old 05-25-2005 | 03:46 AM
  #15182
teammpp's Avatar
Originally Posted by BundyMan
Fukuda's car in the recently concluded Asia Mugen Cup which was held in Malaysia from May 20-22. See any changes??
TM Springs on the shocks
New upper front wishbones
teammpp is offline
Old 05-25-2005 | 03:49 AM
  #15183
ilaybrk's Avatar
is their a real date for the mtx4
ilaybrk is offline
Old 05-25-2005 | 03:53 AM
  #15184
teammpp's Avatar
nothing official. It will be running at the European Championships in August according to Mugen Europe. Dont think it will be released before that.
teammpp is offline
Old 05-25-2005 | 06:21 AM
  #15185
gonzoY5's Avatar
Originally Posted by gentleman81
thanks alot, using the stock parts dont i need to loosen the spring adjust nut to get a snappier first gear?
i want to get the prospec clutch setup i've been looking at it for a while.
do u know the part numbers on the clutch shims that go by the bearing, i cant remember does the stock clutch have shims there or just by the thrust bearing?
No, loosening the nut will actually give you worse acceleration. The reason you tighten the nut and put the lighter weights and harder spring is to make the engine have to rev up higher before the clutch engages. Think of it like popping the clutch on a real car. Our engines have more power as the RPM's go up. So the later you engage the clutch, the "harder" it will engage. You of course can go overboard with it. Too tight and the engine is like an on/off switch, it might be hard to come onto the throttle smoothly coming out of turns.
Use the same shims like the ones that control the gap on the thrust bearing. It doesn't tell you to use shims before the inside bearing on the manual. If you go to the MyTsn site, there's a Centax 1 setup guide that tells you this info about the shims. Mugen has like a bag with all kinds of shims, you can find them there, but many other brands make these engine shims too, just check with your LHS. Remember you want them really thin, so you can fine tune it. Good luck.
gonzoY5 is offline
Old 05-26-2005 | 06:34 AM
  #15186
gentleman81's Avatar
so do u recommend the prospec style clutch parts? do they alow for better tunning options? and when i shim the bearing will i have to adjust the amount of shims by the thrust bearing?
gentleman81 is offline
Old 05-26-2005 | 06:58 AM
  #15187
gonzoY5's Avatar
Just think of it like another tuning option. I just think it's nice to be able to play with setups. Clutch setups are key for the really fast guys. I live in Miami and always see the Serpent USA guys messing around with different clutch options until they get optimum performance.
You will probably have to remove some shims from the trust bearing, just make sure you set the endplay accordingly. Hope this helps
Here's that link on MyTsn for Centax setup. THat's one thing that's great about Serpent that no one compares to. Their explanations and setup guides.
http://www.mytsn.com/publ/publ.asp?pid=10534
gonzoY5 is offline
Old 05-26-2005 | 12:00 PM
  #15188
Bandeira's Avatar
Hello there...
Havin Problems with the clutch springs...
From seeing them I can't tell which one is the harder or the softer...
They seem to have same tension(hand feel) and same colour...
About the Ackerman, is it right to say the A one gives the kmost steering?entry part? exit part of the turn?
thanks in advance...
Bandeira is offline
Old 05-26-2005 | 12:06 PM
  #15189
gonzoY5's Avatar
Originally Posted by Bandeira
Hello there...
The silver is the Hard, the gold is the stock.
I'm not so sure about the ackerman. A is supposed to have aggressive turn in, but I don't feel it, maybe it's my driving style, I don't know. I like the B the best. Never tried the C
gonzoY5 is offline
Old 05-26-2005 | 12:08 PM
  #15190
Bandeira's Avatar
About The colours... I do know that... I think my springs are just too old... I can't tell which one is the gold, which one is the silver...
As for the ackerman... I found the B smoother... But it seemed to lack in turning... I thing it would be nice in a track with not so many sharp turns
Bandeira is offline
Old 05-26-2005 | 08:00 PM
  #15191
mk2's Avatar
mk2
Talking
looks like you put 30mm tires in the frount insted of 26mm
mk2 is offline
Old 05-26-2005 | 09:14 PM
  #15192
do anyone have a good droop setting for the mtx3?
Old 05-26-2005 | 09:26 PM
  #15193
rocca30's Avatar
Thumbs up droop
1 in thr front
5 in the rear
rocca30 is offline
Old 05-26-2005 | 09:33 PM
  #15194
u must run a very low ride height?
Old 05-26-2005 | 11:39 PM
  #15195
bleach1's Avatar
Originally Posted by bleach1
Just a few quick questions.
I have asked this once before but i will ask it again. Im building a front diff and am just wondering what oil i should run in it. I am using 30,000wt in the rear and the track is tight with medium grip.
Also a question about the rear blocks. On a tight medium grip very smoothe track would the A block ussually be recommended? Is the A block generally used on smoothe tracks regardless of weather its high or low speed?
bleach1 is offline
