Old 05-29-2005, 09:21 PM   #15211
gonzoY5's Avatar
Originally Posted by Seisick
sorry guys for this question off the topic but I'm in need of a backup receiver for my airtronics mx3 radio, I was thinking for the Hitec HIS-03MK Receiver Single Conversion 75MHz, but I'd like to know if my cristals from my mx3 fm radio will work fine on this receiver since it is universal, also anyone has tried performance products crystals?
Don't know about the Hitec. But as an FYI, I know a Futaba receiver will work with your MX3. Good luck
gonzoY5 is offline   Reply With Quote
Old 05-29-2005, 10:00 PM   #15212
PROVK's Avatar
Trader Rating: 14 (100%+)
Hi
When rebuilding your shocks how much rebound should you get?
Thanx
PROVK is offline   Reply With Quote
Old 05-29-2005, 10:48 PM   #15213
asw7576's Avatar
Originally Posted by PROVK
Hi
Thanx
about half piston out after compression.
Old 05-30-2005, 01:29 AM   #15214
PROVK's Avatar
Thanks for the shock answer
got another , querey ,,
whre can i buy
Kfactory Part no K1319T mtx-3 5th middle body post.
Cheers
Old 05-30-2005, 01:43 AM   #15215
Electrolabs's Avatar
Hi you can find it here:
http://www.the-border.com/search.php?mode=search
[Kyosho Ultima RB6 - Team Orion - LRP] - [Kyosho Inferno MP9 TKI3 - Werks] - [Futaba]
Electrolabs is offline   Reply With Quote
Old 05-30-2005, 03:41 AM   #15216
reng67's Avatar
so if there is only little movement? thanks can't see no leak anywhere though...
reng67 is offline   Reply With Quote
Old 05-30-2005, 02:50 PM   #15217
Bandeira's Avatar
Send a message via ICQ to Bandeira
I use 3x10 cap screws for the engine and 3x10 countersunk titanium screws for the mounts, it works fine and you'll never strip a gear again.
The problem is between the mounts and the main chassis...
The steel screws aren't doing the job... I guess the Ti ones won't either..
I was thinking of something heavier...
I'm gonna try swapping engines... as the JP maybe vibrating too much on the looooong 285ft straightway
But thanks for the input...
Bandeira is offline   Reply With Quote
Old 05-30-2005, 10:28 PM   #15218
rcabj's Avatar
so if there is only little movement ????
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 05-31-2005, 05:59 AM   #15219
Few answers to some questions in the last few pages:
Springs:
Purple - Light Blue - Blue - Grey - White
(Softest) to (Hardest)
Rear Blocks:
A Block is more for high bite tracks. It has Lower Rear RC which gives more roll ensuring better traction.
C Block is more for low bite tracks. It has Higher Rear RC which gives less roll and therefore making the car more stable in low traction conditions.
Use B blocks if you're uncertain.
Ackerman:
Have found that 'A' gives more on-power steering whilst 'C' gives more off- power steering. And again 'B' is the safest choice if you're unsure. Personally i find 'C' superb for my driving style. This is really a driver preference and how are the other components of the car setup. i.e. caster, shock positions, damping, etc.
Hope this helps.
coldfusion is offline   Reply With Quote
Old 05-31-2005, 06:02 AM   #15220
Just another point...on rebuilding shocks and rebound rate from the dampers.
Generally the left and right should have the same rebound rate when compressed whether for the front or rear.
The faster the rebound = the faster the reaction of the dampers.
The slower the rebound = the softer the reaction of the dampers.
THis is determined by how fast you screw the shock caps at the top after refilling with oil. Faster screwing motion = faster rebound rate.
Old 05-31-2005, 06:07 AM   #15221
Bandeira, I have a racing pal who had similar problems to yours, for months. He checked eveything but couldn't find out what was causing the spur to strip. Finally he found out that the pinion was actually worned and was too sharp for the spur. You should also check you 2-speed shaft if its bent. this might cause inconsistent meshing between the spur and pinion.
Hope you can solve this.
Old 05-31-2005, 06:09 AM   #15222
This mainly depends on the viscosity of the shock oil and piton holes. Otherwise is could be because there is something binding un-naturally. check the internals of the shock.
Old 05-31-2005, 03:31 PM   #15223
Bandeira's Avatar
Thanks for the input...
The pinion is brand new!
and so is the shaft...(My last steel one bent, this one is Titanium, even though I don't like very much Ti things...)
I'm really desperate... For next race i'm getting the mtx2 mounts... 1.0 module(even if my ratios get kind of tall) and changing engine...
Old 06-01-2005, 12:58 AM   #15224
asw7576's Avatar
Rear Blocks:
Hope this helps.
I think you got it wrong for low bite and high bite track applications:
A rear block = give you the most body roll = more grip possibility
B rear block = pick this one
C rear block = give you the least body roll = slightly less grip.
Generally A block is preferable for drivers who want the most rear grip, while C block is suitable for drivers who want rear tires to slide at medium or low speed corners. B block is neutral.
Old 06-01-2005, 02:13 AM   #15225
You have just repeated what i had said in essence!
I've also given the application of blocks as guide (low bite vs high bite application) - go try it out and you'll know.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
