Mugen MTX-3
Old 05-24-2005 | 12:19 PM
  #15166
Are the housings and parts different from the regular 1.0 and .8 twos speeds, or is just the spur and pinions different?
Performula,
The housings are the same for both the 0.8 and 1.0 spurs.
Jamie Corrado is offline
Old 05-24-2005 | 12:21 PM
  #15167
Performula,
So everything is the same, just the actual gears are different? Thanks.
performula is offline
Old 05-24-2005 | 12:33 PM
  #15168
gonzoY5's Avatar
Yup, just the gears are different
gonzoY5 is offline
Old 05-24-2005 | 01:35 PM
  #15169
dg8one's Avatar
Originally Posted by evild
I'm just finishing up my MTX-3 Prospec and waited until last to put the tires on. I slid the front tires on and noticed they fit right up tight to the steering arm and linkage. What am I doing wrong here? I wanted to ask the forum before unnecessarily tearing it all down. I've followed the instructions and everything else with the front end looks to be in order. Here are some photos:
check your tire rear tires are wider than the front tires
dg8one is offline
Old 05-24-2005 | 04:34 PM
  #15170
evild's Avatar
@gonzoY5 & dg8one: As soon as I walked into the workshop I could tell that I had the tires reversed. :) It was a combination of a late night of building and being new to racing with foam tires.
Thanks guys.
evild is offline
Old 05-24-2005 | 07:54 PM
  #15171
gentleman81's Avatar
Default springs
what is the spring that is one step softer than the stock light blue mtx3 springs?
White or grey?
gentleman81 is offline
Old 05-24-2005 | 07:59 PM
  #15172
Default 1st gear selection
my mtx is a rocket and second gear is just like a bullet but i want to get a better acceleration in first, i am running the stock mtx gearing what should i do to my 1st gear to get more pop. adjust the centax or gear it differently?
Old 05-24-2005 | 08:07 PM
  #15173
gonzoY5's Avatar
White or grey?
Purple is softer than light blue. White is the Hardest I think.
gonzoY5 is offline
Old 05-24-2005 | 08:12 PM
  #15174
rocca30's Avatar
you r correct
rocca30 is offline
Old 05-24-2005 | 08:17 PM
  #15175
gonzoY5's Avatar
Clutch Settings makes a huge difference. I use the ProSpec Clutch setup (light flyweights, hard spring, grey shoe) Then I put enough shims before the inside bearing so the clutch bell spins free without rubbing the clutch shoe when disengaged. It takes quite a few, but it works. Then I tighten the nut until i get the right snap out of the engine. My typical starting point is like 9.25mm from the end of the Crankshaft, then I adjust accordingly. If you keep the stock clutch parts, Putting the shims before the inside bearing shoudl still help, you can try to tighten down the spring tension adjusting nut a little more, but tighten it too much and it might cause slippage. Good luck.
gonzoY5 is offline
Old 05-24-2005 | 08:27 PM
  #15176
thanks alot, using the stock parts dont i need to loosen the spring adjust nut to get a snappier first gear?
i want to get the prospec clutch setup i've been looking at it for a while.
do u know the part numbers on the clutch shims that go by the bearing, i cant remember does the stock clutch have shims there or just by the thrust bearing?
Old 05-24-2005 | 08:45 PM
  #15177
BundyMan's Avatar
Fukuda's car in the recently concluded Asia Mugen Cup which was held in Malaysia from May 20-22. See any changes??
BundyMan is offline
Old 05-24-2005 | 08:51 PM
  #15178
Redvet79's Avatar
Default Mtx-3 or 710
I need a new car Can you help me out
what makes the mugen better than the 710 (other than the driver)
Thanks In Advance
Redvet79 is offline
Old 05-24-2005 | 09:15 PM
  #15179
Thanks In Advance
as a novice driver i with let you know that the 710 is nice but with not take a lick like the mtx. its durable and easy to drive. the 710 parts are just too thin for me, its a nice car for someone who doesnt hit much but i couldnt finish a race with it.
Old 05-24-2005 | 09:32 PM
  #15180
Vinyard's Avatar
[QUOTE=BundyMan]Fukuda's car in the recently concluded Asia Mugen Cup which was held in Malaysia from May 20-22. See any changes??
[QUOTE]
pray do tell us..
Vinyard is offline
