Old 12-30-2004, 04:14 AM   #14416
Taylor-Racing's Avatar
You really need to talk to some Revalation guys but a couple of things that might help . . . .
Lose some rear droop - maybe even get it down to 2mm.
I would have thought 2mm of rear camber was too little, but if your tyres aren't coneing, then . . . OK.
Yes, smaller tyres help as does a stiffer set-up.
You need about 4mm of tyre split to run the 16/19 conversion.
Concentrate on driving smoothly, and even a bit slower in the traction roll prone areas . . . really!
One flip can easily translate to a loss of about half a lap.
Taylor-Racing is offline   Reply With Quote
Old 12-30-2004, 05:39 AM   #14417
MTX-3 Kid's Avatar
I had the same problem at this years nationals I was trying a harder spring, harder anti roll bars and it just kept traction rolling then I noticed that other MTX-3's in the pits were running a softer spring and softer anti roll bars than me so I tried it and it worked I still don't know why but it worked and thats the main thing
Hope this helps
MTX-3 Kid is offline   Reply With Quote
Old 12-30-2004, 05:58 AM   #14418
compaq888's Avatar
Send a message via AIM to compaq888
having a car too stiff sometimes is a bad thing. I went with my buddy to crystal park and all his car did was traction roll right after the straight, after like the 3rd lap he went home
compaq888 is offline   Reply With Quote
Old 12-30-2004, 07:02 AM   #14419
miniracer's Avatar
has anyone here, broke a radio tray? I have seen two cracked in between the tank and throttle servo already and would like to know if this is a common breakage part. wondering if there is a thicker radio tray available. I am a novice driver and would like to stock up on breakable parts for the mtx-3. thanks.
miniracer is offline   Reply With Quote
Old 12-30-2004, 11:26 AM   #14420
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default Nats
Hope this helps
I was there also and had the same issue. I was the guy runing with a pedal radio.
When you put on a softer set up, it makes the car less agressive , so the car will not respond as quick.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 12-30-2004, 02:23 PM   #14421
AMGRacer's Avatar
When you run a softer setup the car rolls more. As the car rolls it pulls the chassis closer to the ground making the car less likely to traction roll. A hard setting prevents the chassis from rolling over in the corner making it more likely to jack over the cornering wheel.
A mid corner traction roll usually means you are too soft. An immediate traction roll usually means you are too stiff.
AMGRacer is offline   Reply With Quote
Old 12-30-2004, 08:49 PM   #14422
BuggyMulisha's Avatar
Send a message via AIM to BuggyMulisha
For tomorrow.....
Happy New Years!
alots happend in 2004 hopefully 2005 will be even better....wink wink new mtx4 maybe? lol
BuggyMulisha is offline   Reply With Quote
Old 12-30-2004, 09:19 PM   #14423
MTX-3 Kid's Avatar
Thanks for the reply guys
AMGRacer this helps heaps
Hope you all have a happy new year
Old 12-30-2004, 09:41 PM   #14424
smracer31's Avatar
Send a message via AIM to smracer31
i run at revelation also, i wonder how traction will be on saturday... i plan on running but weathr permitting.
smracer31 is offline   Reply With Quote
Old 01-02-2005, 02:34 AM   #14425
asw7576's Avatar
Happy new year guys !!!
What do you suggest for this kind of problems: understeer and oversteer in one package
My car is not stable at high speed, the car seems not planted to ground. The car would easily get too much left or right after I made small correction from transmitter's steering at high speed.
In tight corner, the car have tendency to understeer if I enter that corner too fast.
Ditto in sweeper corner, I can't hardly full throttle while other could. The car would overshoot to grass area if I enter that sweeper too fast.
Exiting tight corner is another challenge because the car sometimes would spin out 180 degree at full throttle.
Please... please... please.... What would you suggest ? I don't have to explain my current setup because my setup is sux anyway.
My circuit condition:
medium and long sweeping corners, few tight corners, one hair pin, and one curve long straight.
Track temp: 41+ C. Weather temp: 33 C. Humidity: 78 %
Smooth asphalt track with medium to high bite if not dusty.
Old 01-02-2005, 01:42 PM   #14426
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
does any one have a site where i can get a receiver pack
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-02-2005, 02:58 PM   #14427
mckrooz's Avatar
Send a message via AIM to mckrooz
I have cracked a radio tray at the same place you mentioned. I just got a new one. I've seen other drivers with cracks in the same place. Maybe try putting CA glue along the edges of the tray.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 01-02-2005, 03:31 PM   #14428
serpentpro28's Avatar
you need to upgrade you side braces with alum,and also the radio tray support,if you using the stock plastic you have a lot of play on mid-part of the car'
Team bilis racing
serpentpro28 is offline   Reply With Quote
Old 01-02-2005, 05:04 PM   #14429
miniracer's Avatar
I already have aluminum side brace and radio tray support. I have repaired the crack and sealed all the edges with ca. Hope this last until I can get a replacement tray. Anyone use aftermarket trays from 3racing or Kai? Feedbacks? Thanks for your replies!
Old 01-02-2005, 07:29 PM   #14430
Default top plate
My stock one broke the first crash, 1.5 years ago, I still have it on the car no problems.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
