Old 06-13-2005, 01:59 AM   #15316
Hoggy's Avatar
Trader Rating: 26 (100%+)
hey does anyone know the difference between the MTX-3 and the MTX-3 Prospect, thinking about getting one but the prospect is extra and i was wondering if there was much difference to substantiate the cost.
Hoggy is offline   Reply With Quote
Old 06-13-2005, 02:59 AM   #15317
rcabj's Avatar
the mtx3 is already race ready....if u r up to it, the prospec should be better with the extra hop up parts i.e. fro/rear universal , titanium screws & pivot ball,4mm chassis, . the rest is pretty much the same i guess...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 06-13-2005, 08:19 AM   #15318
performula's Avatar
How come the website says nothing about titanium screws?
performula is offline   Reply With Quote
Old 06-13-2005, 08:32 AM   #15319
Number 11's Avatar
Because Mugen needs a different promoter for their products. The website doesn't give much info on anything concerning their cars. But it is a good car.
Number 11 is offline   Reply With Quote
Old 06-13-2005, 08:35 AM   #15320
Don't use the bump stops, all they will do is make your car handle erradically when they hit. I've never seen anyone use them. I tried to use them once, and didn't like the unpredictablility of the handling when "bottoming" out on those screws.
The Prospec doesn't come with titanium screws. It is a bargain though with what comes on it. Titanium pivot balls, lay shaft (front shaft), tie rods, better clutch assembly (harder spring, lighten flyweights, grey clutch shoe), 4mm chassis, 0.8 gears, and .... I'm can't remember anything else. Just don't bust those titanium pivot balls, a pack of 2 will cost you $24 or a pack of 8 is $90.
If you can't afford the Prospec, the MTX3 is more than ready to race with any of the TCs on the market today.
darkangel is offline   Reply With Quote
Old 06-13-2005, 08:59 AM   #15321
kempower2000's Avatar
Exclamation CVD pins
Does anyone know where to find these pins? (the green pins in the picture)
These Mugen MTX-3 prospec CVD's are from such an excellent quality that I do not need to replace the complete CVD...only the pin has worn out...
Anybody tips or links?
thanks,
Maarten
kempower2000 is offline   Reply With Quote
Old 06-13-2005, 09:07 AM   #15322
JustRace's Avatar
[QUOTE=kempower2000]Does anyone know where to find these pins? (the green pins in the picture)
thanks,
Maarten
Serpent 801322 http://www.mytsn.com/products/product.asp?prid=2348
JustRace is offline   Reply With Quote
Old 06-13-2005, 09:53 AM   #15323
Serpent 801322 http://www.mytsn.com/products/product.asp?prid=2348[/QUOTE]
A very little bit shorter... Mugen pins are 9.53 x 2.97 Isn't that a problem? Did you try it already?
Anyway,
thanks for the quick response!!!
Old 06-13-2005, 11:57 AM   #15324
gonzoY5's Avatar
thanks,
Maarten
I don't know if you can just get the pin, but you can get just the shaft (t0250 on the picture) so that will save you from having to buy the whole set.
gonzoY5 is offline   Reply With Quote
Old 06-13-2005, 12:42 PM   #15325
performula's Avatar
I find that the car is a tad bit heavier on the side with the electronics; normal?
Old 06-13-2005, 01:22 PM   #15326
gonzoY5's Avatar
Hey bcquick, you got PM
Old 06-13-2005, 03:00 PM   #15327
JustRace's Avatar
Anyway,
thanks for the quick response!!![/QUOTE]
Kem...I've used the serpent pins without problem.
Old 06-13-2005, 04:14 PM   #15328
ROBBIE C's Avatar
Send a message via AIM to ROBBIE C Send a message via Yahoo to ROBBIE C
thanks,
Maarten
Those pins are fixed inside the bones, you can buy the bones if you like.
ROBBIE C is offline   Reply With Quote
Old 06-13-2005, 09:58 PM   #15329
gentleman81's Avatar
finally getting my mtx3 to hook up at my track. using purple rear springs dark blue fronts, stock sway bar softess settiing, front sway bar at flat setting. 37 rear-40 front shore tires. my rear end seems to handle better with less toe? is that strange. does droop play a big part in handling and if so what part?
and i thought we had put this to rest but i see other posts that have me confused again. the rear blocks are for what, roll center. A is for high traction tracks, or to give you high traction? C is for low traction, or to give you lower traction?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 06-14-2005, 08:03 AM   #15330
What do you mean by handling better with less rear toe? If it means your car rotates better, you are right. Less rear toe will lead to less straight line stability, but better rear rotation (going towards oversteer). I'm using 2 degrees in the rear and it seems to be perfect for me.
The rear blocks are for roll center changes. A block will lead to higher traction (the rear end is allowed to sway more (higher roll center)) while the C block will lead to "less" traction (the rear end is less sway happy (think stiffer swaybar) (ie lower roll center))
Droop does play a part in handling. More droop will give more responsive steering, but will not be happy under braking. If you run on a bumpy track, run more droop (lower #'s on the hudy droop gauges), on a smooth track, run less droop.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
