Old 05-19-2005, 01:08 PM   #15136
Derby Bros Racing's Avatar
fx5 is not a legal motor... another newbee motor
but hey, anything to get advantage right
they won't know
Derby Bros Racing is offline   Reply With Quote
Old 05-19-2005, 01:42 PM   #15137
asw7576's Avatar
Yeah.... what ever you called it, I have few boring legal motors like NSR12 S5 , RR12 L5, FX3,5 that are sleeping in tool box and only wake up on race day. The rest of calendar I'm having fun with more fun engines like V12, NS15 mod, and soon MX15 P7. Chasing friends or top speed racing at long straight, and we enjoy this hobby at top speed.
......btw, newbees don't cheat during national race, we use those boring motors above to earn honest lap one by one.
Old 05-19-2005, 02:33 PM   #15138
Old 05-19-2005, 03:38 PM   #15139
Send a message via AIM to NitroNubee
Hey Scott,
Where might one find a Nova NSR 12 hotmod?
Thanks and great review!
NitroNubee is offline   Reply With Quote
Old 05-19-2005, 07:20 PM   #15140
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I would call Fusion motorsports and ask jim as he is Mr. Hotmod. Tell him I sent you. He will be able to tell you where to purchase the novarossi hotmods. FYI: Fusion motorsports is the US importer for Novarossi. Jim Hottinger is the owner. He is the Hot part of the hotmod.
www.fusionmotorsports.com
951-361-3579
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 05-20-2005, 02:44 AM   #15141
BigBadJabba's Avatar
hi
i am new...
was wondering what width tires i buy for my mtx3? also is there a offset i have to consider?
thanks
BigBadJabba is offline   Reply With Quote
Old 05-20-2005, 03:38 AM   #15142
Originally posted by BigBadJabba
hi
i am new...
thanks
I am assuming that you are running foam tires. Use 26mm for the front and use 30mm for the rear.
First, you could just purchase Fast Brand of tires on the spoked wheels. The wheels are made by Mugen and work perfectly on the MTX-3. If you purchase another brand, most people will tell you to purchase 2 degree offset. I am going to say use the 0 degree. What I have actually found is that the 2 degrees make the car so wide, that you can't get it to a legal width for racing. The 0 degree wheels you just have to space out the wheels a little.
If using GQ tires, get the zero degree wheels... you can get them from competion rc or winners circle.
Other choice would be to use Fast tires. Get these from Ace Hobbies... right now the price is buy any 3 and get a 4th for free.
Other people will recommend other tires, these are the ones I have tried and would advise for a new guy with an MTX-3.
Another economical choice would be twister tires, but I have not run them. I am sure they would be fine as well. All of these are good quality race tires.
Old 05-20-2005, 07:06 AM   #15143
thanks fish.
so is there handling difference between the 0 off set and 2mm offset? i asume 0 would be more twitchy steering.
Old 05-20-2005, 11:35 AM   #15144
thanks fish.
There would be a difference in handling if you do not adjust the width of your car accordingly.
For example:
When I run Fast tires on the mugen wheel (spoked, not dished) and I put my car on the setup board and set it up, I usually set the car width to 198-199 in the front, and 199-200 in the rear.
If I switch to GQ tires with the zero offset, the car gets about 1.5mm narrower, so you unscrew the pillow balls in order to get the car to the proper width. You of course also have to adjust the rear camber links and the front steering as well, which gets to be a pain.
Hope the above part answered your question.
Below is further clarification of my earlier post.
If you were instead to put on the GQ 2 degree offset, the car gets about 3 mm wider. The problem with them is even with the pillow balls all the way in the car is still to wide.
Old 05-20-2005, 12:22 PM   #15145
For example:
instead of unsrewing the pivot balls when running tires with 0 offset, put a 2mm spacer behing the pin and in front of the hub. also, if you ran 1 degree offset tires, you just need to add a 1mm spacer. hope this helps.
Joe Chaplow is offline   Reply With Quote
Old 05-20-2005, 12:31 PM   #15146
this will work for a quick fix. but i like fisher's idea better. putting spacers will make the wheel and hex contact patch smaller that may make the wheel break easily. just my opinion though
Old 05-21-2005, 03:12 PM   #15147
Bandeira's Avatar
Send a message via ICQ to Bandeira
Default Gears
Hello everybody....
Long time since my last post...
I'm having problems with my 52tgear...
1st: I do know how to set gear Mesh
I'm using 58t 1st gear...
When I get the 52t, it doesnt last a single qualifier, last time not even a couple of laps...
But When I use the 54t, no problems at all....
Maybe with a longer gear ratio the gear change punch is higher?
Anybody got any clues?
Bandeira is offline   Reply With Quote
Old 05-21-2005, 04:23 PM   #15148
afm
afm's Avatar
Default Re: Gears
Originally posted by Bandeira
Hello everybody....
What pinions do you have in your clutch??
I can see you have a difference of 6 teeth between spurs, and ideally you should have the same difference in teeth between clutch pinions.
AFM
afm is offline   Reply With Quote
Old 05-21-2005, 05:51 PM   #15149
Bandeira's Avatar
There is a difference in 5 teeth between the pinions...
But this difference is a must... The track I race has a 290~300ft straightway
Just something, beyond that, I don't remember for sure:
The A Ackerman gives me the most steering of all, doesnt it?
Old 05-21-2005, 06:39 PM   #15150
roadrage's Avatar
Trader Rating: 14 (100%+)
on a track like that i run: 20 27 pinions and 60 52 spur
Austin Wolfe
Serpent America-Trinity/Revtech-www.ActivRC.com
roadrage is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
