Mugen MTX-4
Old 11-21-2005 | 07:30 AM
  #2236
rcfoolz's Avatar
Thanks....I'M OFFICALLY CRAZY!!!
Thats funny....I remember when running pan car, an engine that reached up to 340deg one time, lost the line back to the fuel tank and it leaned out. It was crazy hot! the carbon fibre didn't have any issues, that was ran it for another 5 months before it broke the T plate and shredded the chassis as it went though the wall at Rock Hill. I would say that the carbon should take the heat without a problem.
rcfoolz is offline
Old 11-21-2005 | 07:45 AM
  #2237
sohlman's Avatar
It shouldn't be a problem. Carbon fiber is used in many motorsports' applications (exhausts, manifolds, engine parts, etc.) to dissipate heat quicker while not sacrificing strength. Nice work, rcfoolz. How thick is the chassis?
sohlman is offline
Old 11-21-2005 | 07:49 AM
  #2238
Jea3's Avatar
Great job on the chassis, but don't you think that the aluminum chassis helps draw heat away from the motor mounts, which in turns pulls heat away from the engine block?
Jea3 is offline
Old 11-21-2005 | 07:51 AM
  #2239
asw7576's Avatar
I guess it's 4mm thick.
How much did you spent for that ?
asw7576 is offline
Old 11-21-2005 | 08:42 AM
  #2240
rcfoolz's Avatar
I kept the chassis at 3mm. The 4mm chassis is too thick for the other componets and it is the same thickness as the stock one. I wasn't aware of the carbon fiber disapating heat, so I just did an experiment using a blow torche a chunk of aluminum and a my exergen temp gun. GUESS WHAT!!!
The aluminum that was on the carbon fiber cooled from 380-200 faster than on the aluminum one 3 seconds faster in the 3 times I did it. So the heat issue won't be a problem. Now, I have this one on Ebay for sale, and I just cut another one for my car. Don't know if I will run it, but I will have fun when people look at it. Also, I have addressed the issue of the exaust side chassis brace. The only proplem is that if you are running an engine that has bolt heads sticking out of the back of the engine, like the mugen engine -vs- a normal novarossi engine, the brace won't work. I have to test this before I show my design, I have already been copied for my work on the TC3, and several tools that I came up with.
rcfoolz is offline
Old 11-21-2005 | 08:44 AM
  #2241
rcfoolz's Avatar
So, now I guess someone will copy me again
rcfoolz is offline
Old 11-21-2005 | 08:47 AM
  #2242
sohlman's Avatar
You DO have too much time on your hands.
sohlman is offline
Old 11-21-2005 | 12:51 PM
  #2243
I will be interested to see how well that chassis works. I will reserve comment.
Steven. I will have my 4 at the T4T race. I raced it once at Revelation and did a half day test session on my home track yesterday. I have been told that the setup for Crystal and Vegas is basically the same so I shold be pretty close now. I may go back out there tomorrow to try a few other things.
Scott Fisher is offline
Old 11-21-2005 | 02:46 PM
  #2244
Originally Posted by rcfoolz
check this out. 52 grams lighter than stock chassis. 20% more rigid! I cut 2 of these. I did this because the stock chasis of my car warped after 4 races. stock chassis is about 100 grams. this is just 48 grams. I cut 2 of these, added weight till it snapped and did the same to the other stock chassis that warped till it bent. This one took 20% more weight till it snapped -v- bent the aluminum. Now my car is WAY under and still have not put titanium hinge pins in.
After I am done with my club track car, my goal is to have the car at 1600 grams race ready.
Why.......I don't know...because I can.
my friends say I have way too much time on my hands
Somebody needs to give me a job.
i think the chasis looks cool as shit. but i wonder how it will handle, it might be way too stiff??? let us know, but tight work!!!
Joe Chaplow is offline
Old 11-21-2005 | 04:33 PM
  #2245
FF25510's Avatar
Agree, cool finished. let us know about the test run...
FF25510 is offline
Old 11-21-2005 | 04:53 PM
  #2246
ogreasurada's Avatar
Why not to engrave your signature onto the chassis so no one else can take the credit.
ogreasurada is offline
Old 11-21-2005 | 04:59 PM
  #2247
What are the differences between the Urethan and Rubber belts besides the material?
Old 11-21-2005 | 05:14 PM
  #2248
rcfoolz's Avatar
I delete this post........
rcfoolz is offline
Old 11-21-2005 | 05:52 PM
  #2249
Racing4Evo's Avatar
The new Mono Tuning hop-ups for the MTX-4 are now available. Skyline Racing is the distributor. Visit the Skyine R/C Racing thread or http://www.skylinercracing.com for more info and pictures.
http://www.rctech.net/forum/showthre...65#post1952365
Racing4Evo is offline
Old 11-21-2005 | 06:15 PM
  #2250
GrandeGixxer's Avatar
Some one needs to hurry and come out with the front sway bar mounts with the cams on both sides so we can set the droop easier. I had the rd logics ones on my -3 and it was awesome.
GrandeGixxer is offline
