Old 11-21-2005, 07:39 PM   #2251
MAVICXXX's Avatar
last sunday club race,1st time X4 me and my D driver ran,the car was ez handled and speed just nice for d layout as it is stil stock ratio.
I faced problem 1st and 2nd hit wit tailing out at sharp corners that initialy i wana get more steer set up since mine got it understeer,but its kind of bit weird wit X4 coz it has more rear traction.stock 10K diff for our surface here cant coop nicely,its gota b 30K!anyway,i qualified 3rd A by 5secs behind current defending 3R champ,2nd also 3R.I got a better run in d 3rd hits where little touch should bring me good in d final but unfortunate it rains..,
well another 2weeks to go for another test if i wana test out again and this time its gona b more better set up..
but shocking for my D driver friend to qlfy A7th with difrnt driving style and attitude and for the 1st time he completed 3 hits wit clean run and beat/sit wit B drivers those lastime alwaz gona b 2laps front of him..
MAVICXXX is offline   Reply With Quote
Old 11-21-2005, 08:38 PM   #2252
Vinyard's Avatar
Originally Posted by joemugen
i think the chasis looks cool as shit. but i wonder how it will handle, it might be way too stiff??? let us know, but tight work!!!
Agreed! its the total coolest thing i ever see.
Just a tot about the rigidity of the chassis. coz somehow i read that the normal chassis will flex while running or something like.
Please do let us know how it performs.
Vinyard is offline   Reply With Quote
Old 11-21-2005, 10:09 PM   #2253
FF25510's Avatar
new overdriveratio
http://www.mugenseiki.com/mtx4-overdriveratio.pdf
FF25510 is offline   Reply With Quote
Old 11-21-2005, 10:38 PM   #2254
mistercrash's Avatar
R/C Tech Charter Subscriber
That CF chassis looks awsome. I have a question about the car's center of gravity. Won't taking off more than 50 grams off the lowest component of the car raise the CG too much?
No brain, no headaches.
mistercrash is offline   Reply With Quote
Old 11-21-2005, 11:48 PM   #2255
Roger's Avatar
Originally Posted by asw7576
What do you think Team Orion WASP engines ?? It's revolution of RC engines said Team Orion.
Quote from Team Orion Website :
""Developed in Switzerland and manufactured in Japan, this is a state-of-the-art engine for serious racing applications. Several innovations are patent pending.
Technical features:
- Integrated Compressor Crankshaft
- Typhoon Mixture Distribution
- Internal Mixture Centrifugal Power Pump
- No back plate back effect resonance
- Automatic Cylinder Conicity Adjustment
- Crankcase Side Intake Tunnel
- Lower fuel consumption by optimisation of the mixture management
- Dynamic Crankshaft Balancing
- Large heatsink for lower operating temperature
- Ultra precise high quality ball bearings
- Special carburetor with very fine tuning capability
- Turbo plug ""
Looks like Toki Engines in Japan are at it again. Toki engines is the main manufacture for all Peak, Orion, Team Infinity motors ( distributed by RD Logics ), and Fantom motors. They are mainly used for high production. I give them credit for trying though.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 11-22-2005, 01:49 AM   #2256
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I already thought about that, so the setup for the car will change, I'm starting out with making the setup to create a lower CG and working back from there.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 11-22-2005, 08:42 AM   #2257
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Wow, an overdrive ratio for a pulley that doesnt even come in the kit(25). What I would like to see is a chart for the 23t pulley. Anyone have one?
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 11-22-2005, 09:18 AM   #2258
Thanks rcfoolz. Let us know how it works out. Can't wait to see picks of your MTX4 with that chassis.
Old 11-22-2005, 11:35 AM   #2259
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
The chart for th 23t pulley came with the car. Bottom line is to acheive no under/overdrive you need to run you front tires about 6.5mm smaller.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 11-22-2005, 11:44 AM   #2260
burito's Avatar
@scott: it's actually 5mm split with the 23t pullie and not 6.5mm... Guess the 25t pullie is coming soon and meant to be used for the rubber tyre guys where no split is possible.
Regarding the "problem" with the position of the rear body posts and the PF Mazda6: I did just drill & cut some new bodies, which will be painted over the winter now, and the Mazda6 does indeed "just" fit with no modifications to the rear posts. Obviously the bumber needs major trimming, but that's necessary for all bodies anyway.
The posts are just "touching" the wing mounts and the wheels are exactly in the center of the arches. Quite perfect actually!
This is all when standard shock-tower is used with the posts on the regular (back) side of course.
Reto Koenig
burito is offline   Reply With Quote
Old 11-22-2005, 12:26 PM   #2261
by the way, is that cut from a CAD drawing???
Joe Chaplow is offline   Reply With Quote
Old 11-22-2005, 12:40 PM   #2262
I don't know if the overdrive charts that came with the car are wrong, but I just went and found it (when I said 6.5mm I was using my failing memory). According to that chart you need about an 8mm split with a 23t pulley.
Old 11-22-2005, 01:10 PM   #2263
ira
ira's Avatar
Trader Rating: 18 (100%+)
Scott, check your PM
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 11-22-2005, 01:30 PM   #2264
I never got that one. Maybe cause I have a jap version car. Anyone have a scanner that can help me out?
Joe Cude
Old 11-22-2005, 01:51 PM   #2265
rcfoolz's Avatar
Default mtx-4 CARBO0N FIBER CHASSIS RESULTS!
First, the chassis is not cut from a cad drawing. (i've been asked for the program already) Scott Fisher, I need an address to send you something.
To switch the chassis over, I just took the car and placed it upside down on a towel, removed all the screws from the bottom and lifted the aluminum chassis off. I then overlayed the carbon fiber chassis and put the screws back in. EVERYTHING lined up perfectly! This took about 10 min.
I just ran the car. I am EXCITED!!! There is 5 pictures of the car. You can read the scales for yourself. The car, with the stock setup was INSANE!!! Running the body in the picture Mazda 6, after the tires wore in (fresh trued), the car was like driving my pan car all over again. I almost couldn't get the rear end to break loose, even when I stabbed the throttle wide open, it just took off! It was like driving a sling shot! Cornering....unbelievable! after a few laps, taking the turns faster and faster, I was hardly off throttle. I ran 5 tanks through the car, and the chassis never got over 120deg, and I was leaning the engine more and more to the point it started to have a lean bog, and the hottest engine temp was at 219deg.
Temp outside was 72. Track was cleaned, not sprayed. Tires:40 shore.
I never want to take this off my car, but I need to send it to somebody for thier test if they want to test it for themselves. I only want it back.
Mugen MTX-4-image001.jpg   Mugen MTX-4-image002.jpg   Mugen MTX-4-image003.jpg   Mugen MTX-4-image004.jpg   Mugen MTX-4-image005.jpg
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
