Mugen MTX-4
#2087
ohhhh...ok. thanks
#2088
also... what tyres work good on the mtx-4 and what starter box will work (duratrax universal?). and what batery pack would you put in the car, that is good but not too expensive...the batery pack can wait, right, cause i can just use the duracil till i get one...i think
and what size body too?
#2089
Tires depends on the track. Until the 1mm offset becomes available get the Mugen/Fast foam tires. Almost any starter box will work as most can change between on and offroad. The starter box wheel has to be able to run parallel to the direction of the box.
Battery? I will assume you have a battery charger. Yo ucan't just use your AA regular batteries in the holder than came with the radio. You NEED to get a 5 cel 2/3rd AA flat receiver pack. This month promatch racing ( www.promatchracing.com ) has 1100 mah rechargeable flat packs (part number 1021) on sale for only $9.99 plus shipping. You can get it delivered to your door for under $14. If you don't have a normal charger, you can get a wall/trickle charger pretty cheap. Your radio may have come with one that will work.
Body size is 200mm. I don't know about your racing rules where you are. Either way, it takes 200mm bodies.
#2090
with that link what plug style on the batery do i want?
and do you have a link to the charger?...i might have one from my plane remote but im not shure.
#2091
Rx packs are all the way down the page, MTX4 uses the FLAT pack. Hope this help.
#2092
the universal plug or jst?
what shock springs will fit?
#2095
Originally Posted by Scott Fisher
The plug is determined by what kind of receiver and/or on off switch you have.
Mugen shock springs will work just fine.
#2097
i cant find them there either...this is the site http://www.rc-toro.com/index.php/cPath/3
http://www.rcmart.com/catalog/defaul...ort=1a&&page=2
#2099
the link i gave you want an HK web site...its located in cali.
