Serpent 710
#1411
Originally posted by ammdrew
okay if you want to make your tires smaller do it with a file from the side.. I have seen many xacto knife grab and go for a flight I would hate to see one of you most carefull rc racers lose sight in one eye because you were trueing a mm of tire width off.. yes you may have done it a hundred times but that one grab were the blade flies out of a 5000 rpm motor and hits you in the eye is the only one that matter, a rough grit file will quickly bing in the sides of your tires... with no ill effects to you your buddy or anyone...
Thanks for the info, and concern!
#1413
okay here is how it works to get even tire wear you will end up at 2- 3 deg camber and rear 2 deg front camber.... regardless of the track ... just what ends up working... you can try and analize it to death and experiment around all you like but you will just end up there... not to be harsh but that is were tire wear becomes more even and the car performs best... you also will find that you do tear chunks out of your rear tires often at 3 deg rear camber... also try 4 deg rear toe.. this will create a very stable car that jumps out of the corners, especially if you have corners that require you to piviot the car....
#1414
Question for the Serpent Team,
Is the 2 speed shaft on the S710 the same or interchangable with the 705 and vice versa? I had someone lighten my 705 2-speedshaft. So, I am hoping that I can use it on the S710.
Thanks in advance.
Thanks in advance.
#1415
Thanks in advance.
Thanks in advance.
Julius
#1416
#1417
Originally posted by chambalero
Hi everyone! when is the 710 gonna be available does anybody here have one already? seems like a lot of people ditched the r40 thread when news of the 710 came about
#1418
Originally posted by lawndoggie
Hmm so the amount of chamber angle is highly in related to the amount of corners then!? Because say if the track is dead straight 90% of the time, there won't be even turns to give the outside of the tire pressure, and the wear won't be even....?
i.e the more turns, the more chamber angle??
#1419
They might take one or two days off...
Let me know if anyone wants me to get it for them.
I won't charge extra, so 360USD plus whatever shipping, probably 40USD for shipping...
You might ask why would I do that? Not charging extra? Well I am new to nitro, and have been crashing a lot.. so the more I buy from the store, the more they'll remember me and hopefully give me discount on parts someday!
#1420
Originally posted by S710_Nut
Guys,
All this talk on Lola bodies... Whats the go on Lola Bodies and 710? I read on the FAQ page you could do it, but will it be an aftermarket option or an option in the kit?
Guys,
However, the new 710 rear upright does not have the mounting position for the existing GTP conversion........if Serpent is going to make one, that will be either a NEW GTP conversion kit, or a NEW rear upright....
I am not sure Serpent will do it or not, since running LOLA right now is still illegal for ROAR and most of the race. Beside, I found the LOLA conversion have about 1-1.5 second advantage over typical Touring car body.......that is an unfair advantage if someone is able to run LOLA but you could not.
Personally, I would like to pick up a dirt cheap Impulse PRO or 705 and do the LOLA conversion.........so that if there is a outlaw race, I can use that instead of the 710.
#1421
Originally posted by Rookie Solara
HSC "Lam Sir" gave me discount when I was in HK last summer, then I ordered my 3PK, 3 Nova Rossi engines and such and have him to ship to Chicago for me.......nice guy, and very knowledgalbe in Serpent car (even though they were running NTC3 most of the time...but I am sure 710 will made them JUMP the boat back to the Serpent Camp again...)
#1422
