Serpent 710
#1381
Originally posted by InitialD
You need the following parts;
808150 Bodymount-set rear GTP EV2
808121 Bumper Set 705 CanAm / Group C
You will need to trim the excess bumper's width according to the Lola body used. With the 808150 Impact floating rear body mount style, you cannot use the 7 mm spacers (808313) on the upper rear hubs. You can substitute different size spacers but in my experience, a 2.5 to 3 mm spacer is the max you can go with the 808150 body mount. For the shock tower, you may not use the stock rear of even the front one. If you want to use a rear shock tower, you can use the 808138 shock tower meant for the Impact. Else, you can also use without shock towers and mount the rear and front shocks on the bearing blocks. Incidently, this is what I run (and what a lot of others run this too) on my 705 with red springs all around.
Before this 808121 came out, we were using the 808120 Impact bumper. I felt this bumper was better and toughter as the body mounts on the 808121 (integrated onto the bumper) breaks easy. With the 808120 Impact bumper, you need to modify and trim the nose of the upper body mount bumper plate 801115.
I have attached a top view sample pic of my Impulse PRO (now already 90% converted to a 705
) with the 808120 Impact bumper to give you an idea about the 801115 upper body mount bumper plate.
Using Lola body on the 705 does have it's advantages in the cornering speed and stability. Engine cooling is also better. But that is the least that you would be interested in doing to your car because the faster you go, the more parts you break !
Best for you right now is to use the stock TC body. The foam bumper on the TC shell will be easy on the chassis and will provide enough protection to the shocks.
Observe on the track how the others are driving at your track. Watch how the good drivers are taking the correct and fastest lines in the corners and the bends. Then on your own, TRY to go easy on the throttle and slowly round the track without hitting anything. Drive as many times around the track as you can. The thing is to get a lot of track time. That should be your primary goal. Never mind about people saying you're slow on the track. Somebody has got to start somewhere. I did the same thing too.
For me, I find no difference in the challenge using TC body and Lola body. Some of the cars on the track where I race use Lola bodies too and I would humbly say that it does not make me at a disadvantage using a TC body anymore on the track once you can master the car setup. Of course, the person behind the Tx must be up to it too !
Yes, I do notice this too... Of course only when I clip the front wheels hard enough. I guess if you look the other way around, if the pivot balls do not pop out, you may end up breaking the steering knuckles or worst still, breaking the aluminum pivot balls.
So, I would say leave it as it is. The only solution to this is to drive carefully and slowly first around the track and avoid clipping and hitting the steering blocks hard. Like I said, drive slowly and get familiar with driving the car around the track.
) with the 808120 Impact bumper to give you an idea about the 801115 upper body mount bumper plate.Using Lola body on the 705 does have it's advantages in the cornering speed and stability. Engine cooling is also better. But that is the least that you would be interested in doing to your car because the faster you go, the more parts you break !
#1382
Originally posted by Fernando_M
The rear tower 808138 in not optional. It is needed as it holds the pin that keep the rear body support in place. I don't know the 808139, it is not in mytsn.
On my Impulse PRO (now already converted to 705), I use a different way to keep the pin in place to help keep the rear floating mount mounted correct. Please see pic attached. I use part of the Streetspec Shock Support mounting 808137 as I do not use any rear shock tower.
Yes, 808139 is not mentioned and listed on mytsn but Serpent does sell it separately. Don't know why. I have and use this on my 705 with TC body but actually never had the opportunity to test it nor the need to use the alternative shock hole mounting.
#1383
Originally posted by utopian
I prefer to invest on new cars, like the 710 and team magic G4 instead of converting my old Impulse.
So my Impulse PRO now is almost fully converted to 705. Just less the LC gearbox and Centax II.
#1385
Originally posted by S710_Nut
Thats what i have been hearing as well... Hope so!
Also, Are the hobby stores open after Christmas in Hk up till the new year?
Let me know if anyone wants me to get it for them.
I won't charge extra, so 360USD plus whatever shipping, probably 40USD for shipping...
You might ask why would I do that? Not charging extra? Well I am new to nitro, and have been crashing a lot.. so the more I buy from the store, the more they'll remember me and hopefully give me discount on parts someday!
#1386
Well, I got a 705 convertion kit for very cheap from a good friend of mine who resides in Nuremberg, Germany !
Don't be going telling everyone
#1387
Originally posted by ammdrew
wow that is a ton of broken stuff for 10 minutes of run time.. my recomendation take some throw out of your throttle so it does get going as fast, put more brake in so it slows faster and get use to it.. usually the serpents are the most durable.. ouch .. sorry to hear that.. you could mount a 235 bumper on the bottom of the foam, do not cut it out and you will gin some front side protection, not acceptible to race with but would be good until you are not clipping the corners with the front end...
Yes yes, everytime my car goes BANG! And the people around goes WOW!
I am thinking about sticking ping pongs around the body of my car....
#1388
You are right Fernando. It was an oversight from my part. My apologies to lawndoggie.
I found this approach to work very well. However, the best result was when I adapted a Serpent Excel front body mount. Though, it is hard to get.
BTW, this was done when the Serpent front bumper for the Impulse/705 was not available.
#1389
Hey guys, thanks for all the help... perhaps I should stick with the TC bumper for now.. it probably gives more impact resistance..
I noticed that when my making hairpin turns, if I slam on the brake, the wheels lift off the ground... I am using yellow spring, 30W oil and 40F 42R tires.... if there something I can do to fix the problem?
Does my car have too much grip?
Thanks!
Thanks!
#1391
Lawndoggie:
Try putting in about -30 to 50% steering exponential, and reduce your steering throw so that full lock steering just gets you through the tightest corner on your track; and relax. Don't worry about the other guys, if they're going faster than you they're probably better and can take care of them selves.
#1392
Originally posted by clmbia45
InitialD:
Clever re-inforcement to the exhaust stinger!
InitialD:
Most racers here do this on their pipe.I guess when you're breaking and denting a lot of stuff, you'll try every ways and means to make the car parts stay in one piece.
#1394
#1395
We have very small tracks here, which means there is less space between cars, which tranlates into more running into each other...
