Serpent 710
Originally posted by Marcos.S710
i told him MONOTUNING
I'm waiting on a dealer packet.
A lot of the local hobby stores are already carrying them.
I'll try and carry them anyways.
Originally posted by InitialD
Sato/Monotuning tires are good. Another brand which he can bring in which I think is lacking in US is Speedmind dishwheel foam tires. Their rubber is the same as Sato/Monotuning except for the dishwheel. So you know what you get.
I'm supposed to call them back tomorrow.
How are their tires by the way?
Originally posted by cyba888
What does the newest batch of 710 have i compared to the older ones? The last time I remember when I bought my 2nd 710 was that the fuel tank had a internal filter and thicker shock towers. Im not sure but are there any other newer parts that are currently out that I might not know about?
OS carbs?
Why? I think they are they smallest carbs. Not enough for Nova based engines.
STS carbs are close to ideal because STS engines work about the same as Nova engines. But one thing I found about STS carbs are that they are composite and not aluminum like Nova.
OS carbs?
Why? I think they are they smallest carbs. Not enough for Nova based engines.STS carbs are close to ideal because STS engines work about the same as Nova engines. But one thing I found about STS carbs are that they are composite and not aluminum like Nova.
I have 2 Sirios, and those carbs have given me the worst time.
Originally posted by PSI Racing
Speedmind is being distributed by Magma International Ltd., right?
Speedminds are really good aswell Iwas running them om my impulse pro and loved them.
Originally posted by GoldFinger
If you have a chance to see Surikarn form below, when he is driving (like your picture). You will amaze with his finger, not only fast but seems like he has a positioner and step motor in his finger.
Another sesion at the track today and now I've put through about 2 liters of fuel through the 710 - the car just seems to get better.
I'm still using the one-way, which in the 705 seemed impossible to drive on my track - although my driving has improved a lot
Breaking is really not much of a problem - I still have to be careful not to put too much braking force on, but apart from that, the brakes stop the car nicely.
As long as I drive smoothly, then I see no hint of understeer and I can really "boot-it" coming out of the long left-hander onto the main straight.
The left flick is always tricky, due to the bumps at the entrance, but keeping as far over to the left and keeping the lines smooth make it no problem.
In terms of breaking bits.......ehm......
nothing! I even rolled the car today
first time I've really got the fast flick wrong and as normal through there, when something goes wrong, it goes wrong big time
But even though the 710 rolled a couple of time, I could drive away from the accident without any damage
Tyre wear is still really great and even - I started with tyres all around 62mm and now I have front 61.2mm and rear 60.8mm - and the runs today where pretty hard and fast. I had to run fast today, as there was also a Kyosho FW-05R on the track
but even though I wasn't at 100%, I was able to easily catch and pass him
A couple of pictures to show you what my car looks like now after the 2 liters have been used
Breaking is really not much of a problem - I still have to be careful not to put too much braking force on, but apart from that, the brakes stop the car nicely.As long as I drive smoothly, then I see no hint of understeer and I can really "boot-it" coming out of the long left-hander onto the main straight.
Originally posted by Proficar403
Hey man, if you want to bash the serpent all day, thats fine...just start a new thread. Meanwhile, let us talk about setups, parts, women, and other areas of true interest.
I am becoming annoyed, not just at the repeated comments, but at having to filter out all of the unneccessary posts when reading this thread.
I had a close look at the pictures and it seems to me the cooling head is 90 degrees off. The cooling slots in the head meant for airflow over the plug are not aligned front to rear....
