Old 10-19-2004, 01:09 AM   #17866
Default Fuel tank
Hey guys i have just replace the foam around the fuel tank lid and now it wont shut properly because the foam is too thick. Do i have to leave them to settle before use?
Brett.w is offline   Reply With Quote
Old 10-19-2004, 01:23 AM   #17867
InitialD's Avatar
Default Re: Fuel tank
I thought Rene or Julius posted some kind of instructions on the mytsn 710 forum. But yes, just let it settle. But before settling, make sure the foam is very well centered in the cap so that when it closes, the foam piece is spread out evenly and equally around the tank hole opening.
I changed mine some time back DIY. Cut a piece of foam a friend passed to me which actually came from inside a cigarate box !
Old 10-19-2004, 01:29 AM   #17868
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Mysterious 17T copper gear!
Originally posted by markp27
Ok, mystery solved - somehow the 17T copper coloured gear simply doesn't fit together with the 22T gear (or anyother for that matter). Check out the pic:
See how there is a built in shim on the copper coloured 17T, but also how it can't be screwed down sufficiently onto the other gear, therefore leaving a gap!
This leads to the bearings being too deep into the bell housing and the clutch gap being too small.
Report on its way to Serpent
Problem solved First class customer support at Serpent, means a new 17T gear is on its way already!!!
markp27 is offline   Reply With Quote
Old 10-19-2004, 01:39 AM   #17869
Default Re: Re: Fuel tank
Thanks for the reply
Old 10-19-2004, 01:43 AM   #17870
crashed_1's Avatar
Default Re: Re: Re: My Winternats Weapon!
And why haven't we seen any pics of Lock&Loaded?
...coming soon...
crashed_1 is offline   Reply With Quote
Old 10-19-2004, 01:44 AM   #17871
crashed_1's Avatar
Default Re: Re: Re: Re: My Winternats Weapon!
BTW: Nice Avatar!
Designer...www.tokidoki.it
Old 10-19-2004, 01:46 AM   #17872
InitialD's Avatar
Default Re: Re: Mysterious 17T copper gear!
Hey Mark, did you exchange your "faulty" rear shock tower too?
So you had a lemon 17T? Is this isolated or are all bronze 1st gear pinions like that? I have never bought a 17T bronze pinion. Only a 16T if I recall and did not have any installation problems like you described...
Old 10-19-2004, 01:48 AM   #17873
InitialD's Avatar
Default Re: Re: Re: Re: Re: My Winternats Weapon!
Oh my goodness gracious... What ever happened after being a father?
Old 10-19-2004, 01:49 AM   #17874
InitialD's Avatar
...coming soon...
I think Uncle Crash is trying to touch up that not soo blue JP FX engine heatsink.
Old 10-19-2004, 01:58 AM   #17875
markp27's Avatar
Default Re: Re: Re: Mysterious 17T copper gear!
Oh man! I forgot about the faulty shock tower which refuses to break as it is suposed to!!! And now I've got another one on my second 710
Not sure what the problem was with the 17T, Ronald simply said he would send me a new one.
Cheers, Mark.
Old 10-19-2004, 08:42 AM   #17876
rcpanama's Avatar
Hi D I have a Set Up question for you, we are going to race next week in the longer & lest technical track of the Club and also with less Traction. This track has to big sweeper’s first one going in to the long straight and the other going out.
The Set Up I have which has work OK; is for a small very technical high traction track, which is the following:
SPUR: 60/55 – 17/22
DRIVE TRAIN: Ball Diff front Medium Soft – rear Medium
SHOCK: Front & Rear Alu with Red Spring / 35 front 3 holes --- 45 rear 3 holes
ANTI ROLL BAR: Front Flat Rear 2mm in (2.5mm)
TYRES: Front & Rear 40 Shore New Elegy
ROLL CENTER: Front 1mm under - Rear UTI / LT
DOWN STOP: Front 0mm – Rear 7mm
CAMBER: Front L 2 R 2 - Rear L 3.5 R 3.0
TOE: Front -1 Rear +2
CASTER: 3mm in front
Appreciate any comments
rcpanama is offline   Reply With Quote
Old 10-19-2004, 08:46 AM   #17877
Sow&Steady's Avatar
You've probably forgotten by now, but that's its natural colour
BTW: Nice Avatar!
Let it be known that this is his SECOND Full Option JP-FX.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 10-19-2004, 08:47 AM   #17878
Sow&Steady's Avatar
Ceramics are fine for the Winternats *phew* Don't worry, that engine is going to be run it Slow&Steady
I was just about to say the same thing.
Old 10-19-2004, 09:16 AM   #17879
Suspended
Default PRICES ON NEW MEGA ENGINES
.21 MEG 201500 M21 Sport $253.37, MEG 201501 M21 Race MS $307.97
.12 MEG 201000 M12 Legal Sport $198.07, MEG 201001 M12 Legal Race MS $230.97, MEG 201003 M12 Outlaw Race MS $230.97
THESE ARE THE PRICES.....CHOCO
SERPENTFREAK69 is offline   Reply With Quote
Old 10-19-2004, 09:45 AM   #17880
Sow&Steady's Avatar
Default Re: PRICES ON NEW MEGA ENGINES
The stuff is available in Houston now Choco?
BTW, you coming to the WinterNats?
