Serpent 710
Old 03-27-2004 | 11:37 AM
  #7006
clmbia45's Avatar
Originally posted by Sow&Steady
D, please change your avatar. Much as I like our national flower, it doesn't look right ... in fact in looks like it belongs to a xxx site.
It looks like a very SORE hemorrhoid!
clmbia45 is offline
Old 03-27-2004 | 11:47 AM
  #7007
clmbia45's Avatar
Default Re: Re: DOG BONES
Originally posted by GoldFinger
With Ellegy rims, you can make 197mm trackwidth pecisely using Impact FR Dogbone.
But your tire cannot go bigger than 63mm, very close to hit the axles when you press down the car.
I understand your point here; I'm working on a project and I need the shorter dogbones: 61-62.5 mm long.
InitialD: please check that big box of old parts you have under your bed and see if you can find something, BITTE' !
jack
clmbia45 is offline
Old 03-27-2004 | 11:51 AM
  #7008
Marcos.J's Avatar
Super Moderator
is that what that is?
Marcos.J is offline
Old 03-27-2004 | 12:24 PM
  #7009
Sow&Steady's Avatar
clmbia45's imagination is runnig wild!
Sow&Steady is offline
Old 03-27-2004 | 12:32 PM
  #7010
Marcos.J's Avatar
Super Moderator
Marcos.J is offline
Old 03-27-2004 | 05:03 PM
  #7011
cox049's Avatar
Originally posted by markp27
Hey Cox049, old buddy Hope you don't mind, but I liked you paint scheme so much, I pinched it I've used a more serpent friendly colour of course
I don't have my Digi cam at the moment, but here's what it looks like.
Cheers, Mark.
Haha You know at first I didn't recognize it was my car!! I was focused only on the car and didn't look the mess around it!! lol And it looks great! I'll do my next just like that.
Anyone know what orange name is "serpent" orange for lexan?
cox049 is offline
Old 03-27-2004 | 06:29 PM
  #7012
teammpp's Avatar
Default Re: Re: Rain Tires
Originally posted by Marcos.S710
as far as water proofing all i do is the receiver i wrap it with a ballon and clear silicone, and thats it servos are usually water tight i took my sterring servo appart one time after a run and it was completly dry in the inside.
I personally run 2 balloons. Problem is little pebbles or debris can be kicked up and tear the balloons. To be totally sure you are completely waterproof, open up the receiver and completely coat the circuit board with red candlewax. Once the leads are in I normally run somemore down in the from the outside of the receiver.
Servos do keep a lot of the water out but after a short time the o-rings wear. I personlly advice people here to use a silcone seal on the servo case at all the joints for extra precaution (we get a lot of rain here in the UK - never had radio problems in 10yrs).
teammpp is offline
Old 03-27-2004 | 06:31 PM
  #7013
cox049's Avatar
Wut ya think of my avatar?
Clue: Its NOT Binladen
cox049 is offline
Old 03-27-2004 | 06:41 PM
  #7014
cox049's Avatar
Default Re: Re: Re: Rain Tires
Palmaris, and how do you manage the frequency changing ?
cox049 is offline
Old 03-27-2004 | 07:03 PM
  #7015
teammpp's Avatar
Default Re: Re: Re: Re: Rain Tires
I never have had to deal with that problem luckily. I have only used the one frequency and never had to change it in 14yrs. I have only seen my frequency once last year here in all that time. 14yrs ago my dad put out a lot of money to ensure I was the only one with my frequency in the country for 10yrs.
But in saying that changing crystals here is a real nightmare. Everyone runs 2 balloons and the Servos on most cars are strapped to the receiver mount by lots of insulation tape. Takes a good 5-10minutes to change frequencies over here. But its better than changing receivers every other week due to water (which we see a lot of ).
teammpp is offline
Old 03-27-2004 | 08:30 PM
  #7016
clmbia45's Avatar
LOOKS LIKE SATURDAY NIGHT IN D.C.
clmbia45 is offline
Old 03-27-2004 | 08:59 PM
  #7017
Marcos.J's Avatar
Super Moderator
thanks im going to try that on my servos next time!!
Marcos.J is offline
Old 03-27-2004 | 09:11 PM
  #7018
Default tyre sizes
hi, can someone tell me what is the effect of using larger tyres in the front than in the rear (overdrive vrs underdrive?)
I was quickly ready an artice on RCx Mag, and it talked about the drive train radio? I guess people play with that stuff . or not? (by changing the pulleys and tyre size?)
Profoxcg is offline
Old 03-27-2004 | 09:17 PM
  #7019
Marcos.J's Avatar
Super Moderator
Default Re: tyre sizes
i usually run the front about 1mm smaller than the back , i never run the front bigger than the back my car tends to push alot that way, i get better steering response cutting the front tyre
Marcos.J is offline
Old 03-27-2004 | 09:41 PM
  #7020
markp27's Avatar
Jesus Cox, you look scary!!! I shouldn't have messed with you I used the flourecent Orange, as when it is backed with Silver it tones down the colour. Also I used a Blue Sunstripe on the windscreen just to finish off the Serpent/Dutch colours - looks really good.
markp27 is offline
