Serpent 710
#7156
Originally posted by Profoxcg
I think i am going to sell my HUDY gauges, because i dont thing they are very functional.. and I mistaken? I think a camber gauge is just fine. However how is toe in set with a reular camber gauge (front and rear)
A camber gauge is fine but you need to rely on good wheels to give you correct readings or you will need to use special setting wheels. The Hudy gauges are the most accurate. The normal camber gauge is useful for quick on the track adjustments.
You can use the camber gauge to set the rear toe in. Make the car stand on it's rear with it's rear shock towers supporting the car as it stands vertically upwards on a flat surface. Then the toe in of the rear wheels can be measured with the camber gauge.
For the front toe in / out, no idea...
#7157
I wouldn't use a camber gauge in preference to the Hudy system!!
#7158
Originally posted by InitialD
Ambient temps where I run are about the same as yours. But I would think we have more humidity here than where you are.
I run a No. 6TF on my NovaMax engine with 25% nitro. I add 0.1 mm copper shim to stock aluminum one (total is 0.4 mm). Sings very well. You could take a peek at Motorman's engine tuning guide. Use a plug which gives you the best performance.
#7159
Marcos...
I've checked yer setup for FULL THROTTLE SPEEDWAY, yer rear toe-in was at +1.0 deg...isn't it too loose at the rear? im just curious
(the setup quite like mine, except the rear toe-in, engine, fuel & body)
#7161
"...You adjust clutch gap by placing shims (medium size) on the thrustbearing holder, in front of the thrustbearing assembly.
When properly shimmed, there should be approximately 0.7mm of clutch gap. ..."
do i have to always set it at .7? is it wrong to set this at .5mm to make the engagement smoother? no right?
#7162
At the end of the day, it all depends on the driver's liking and style of driving.
#7164
My friend runs off road and told me about a dry lubricant that is just awesome. So I ordered some up and it finally came today. I had my car sitting there all assembled. Moved the suspension up and down and it felt very smooth without any lubricant at all!(Good job Serpent!)
The stuff I ordered comes in a bottle with a long needle type tip on it, makes it really easy to reach those hard to reach areas.
So I applied this stuff to all the joints in the control arms, all the ball ends for the steering and sway bars and the dog bones. All I can say is HOLY CRAP!!!!!
I thought my suspension was smooth. It is soo smooth now is is unbelievable!
It uses Moly and has a psi rating of100,00psi. It comes out like WD40 and flows through all the crevices and then dries up completely. It also cleans the part as its flowing.
Its solvent action dissolves old grease, sludge and grime.(A quote from there instructions) The stuff is just awesome, I highly recommend this over any other product I have ever tried. And I've tried quite a few running off road over the years.
The US Army used this product in there weapons during Desert Storm to keep them from jamming from all the sand and grit. The product is there Multi-Purpose lubricant and its from Dri Slide. Check out there website at www.drislide.com
#7166
Where did you get that stuff from? which one did you get, there is a 4oz bottle with needle, and a 5.25oz Aerosol. For those who use metric like me, 4oz is ~113grams and 5.25oz is ~143grams...
#7167
#7168
OOOpppss...I am a Tech Master now.
Now i gonna race markp27 to the 2000 posts.
#7169
Julius just use 16% fuel...now isn't that great!!
Tell me that others were using up to 30%..if its so, i wanna use back my 16% fuel to race. I wanna try and show my friends that using 16% also can make u a winner.
#7170
