Serpent 710
#4517
Originally posted by InitialD
I would not know or have not personally seen how these inserts look like. You should be looking at part number 801159.
#4518
Originally posted by cyba888
What bodies was used for the winternats? Which bodies were being used for the top 3 drivers?
http://www.forgas.org:1089/0/FILE/19...7/DSC_0012.JPG
1. protoform alpha
2. i think its the chevron model Infiniti G350GT
3. Mazda 6
Regarding the fuel tank. Most 710's were barely passing tech. 75cc goes right up to the brim. My tank has the mount for the insert, but I didn't bother putting anything in it because it had passed tech each time.
#4520
Thank you all regrading my 2-speed PIN question....and I should thought about the left pulley can be adjust....afterall, I think I am still a rookie....at least a rookie for the 710 (man, this thing is not as easy as the previous version............Serpent should mention "PHD" degree in rocket science enginneering required on their setup manuals....LOL)
#4521
That's a nice ride Pit !
Give them hell !
p/s: Are you using Power tires? YGPM.
Give them hell !
#4523
Is it possbile to charge 2 rx batteries at once with a Tekin charger? I plan to have a wire that splits with two adapters to charge 2 packs at once. I think the only problem is how would it know when it is fully charged if one pack peaks first? Would I have to set it on a timer? Im sure some of you charge both your starter batteries together at once correct?
#4524
#4525
Originally posted by markp27
Probably not worth it. Current will be divided between the two packs (as you'll be charging them in parallel) and will therefore take twice as long. No free lunch.
Maybe if I keep checking the temperatures of the batteries?
#4526
Well usually I charge them at 3-4 amps, since you mentioned it will take double the time then what if I raise the amp to 7-8amps?
Cheers, Mark.
#4528
Originally posted by rcjayy
Does anyone have or know of a place to see video footage of the 710 in action, I have a 710 but its so Freakin cold out here I can't run it yet. Just wanted to see it in action
MAn I feel you, I had that itch for the longest time when I just got my 710 and it rained for almost a month. Actually I dont know if there are any videos of the 710, maybe you can check out this site later if they will have the winternats race. But by the time its out im sure it wont be as cold
http://www.raywoodrcvideos.com/site3/home.htm
That stuff aint cheap!
