Old 03-15-2004, 07:33 PM   #6016
InitialD's Avatar
Default Re: Re: 710 SSG
Originally posted by Sow&Steady
I know it has been posted before but the titanium shafts get me going!
Here is 3 Racing's website !
Old 03-15-2004, 07:48 PM   #6017
spawn's Avatar
Default Re: 710 SSG
Originally posted by JABRONI
This SSG Graphite is way cool !!!!!!!!!
wow! amazingly good looking!
spawn is offline   Reply With Quote
Old 03-15-2004, 07:51 PM   #6018
JABRONI's Avatar
Default 3Racing Parts
Originally posted by rodrigo1508
well got my first problem one of the dogbones was defective nothing a hammer cant solve, but I will have to buy those cvds asap
I sell these as well and with the Euro dollar the way it is, I am selling them for a very reasonable price here in the states !!!!
I brought some of the products out this weekend to the race and I must say that everyone loved the parts and every SSG part they/I sell is cheaper in price than the standard
Serpent price and really is great quality.
http://www.swrc.biz
JABRONI is offline   Reply With Quote
Old 03-15-2004, 08:04 PM   #6019
JABRONI's Avatar
Originally posted by InitialD
How is the quality of the Titanium shafts? Have you tried running the car with CVDs?
Can you let us know what hop ups that give you those weight and performance advantage and what does not or the ones that just serve as eye candy?
BTW JABRONI, the pics look really cool.
About SSG graphite, I was told that usually since this type of graphite is softer (more flex), they are made thicker. Don't know how true this is. Anybody can shed some light?
As far as the CVD's go, I did not try them out, however, two persons did. One took a big hit and tweaked the CVD in the middle the other gentelman wants more.
The Titanium shafts look really good and that is were most of the weight savings is. Althought this is a very small rotational mass, it does reduce some weight as well as the engine mounts. All in all it appears to be approx 1/2 an ounce. My pictures of the scale didnt turn out so well, so I will get some more info when I get a chance sometime tommorow.
As far as the Graphite goes, it feels real good and a guy was using a caliper and said they were slightly thicker, however when I weighed it all out, I didnt notice a weight difference and another guy said he felt it was stiffer ?? who knows ??
All in all I got about half of the products that are available and alot of interest is being centered around the Titanium pivot balls as well. I do not have those yet with the delrin retainers.
Time will tell, but the SSG does look sweet and appears to be pretty good quality .
I think the best option is the front upper bumper plate that has an aluminum peice that stays attached to the blocks with the droop grubscrews installed, and the bumper can be removed when needed.
Old 03-15-2004, 08:12 PM   #6020
InitialD's Avatar
JABRONI, thanks for the short feedback. Let us know from time to time and keep it up serving the Serpent racers over at your track.
Old 03-15-2004, 08:47 PM   #6021
Send a message via AIM to Profoxcg
Thumbs up
hey guys my car takes forever to take off.. I have to rev it up pretty hi.. I was told to use spring #909518 and will solve my problem.. currently I have a distance of .5mm on the clutch nut.
or should i stay with the normal spring that came in the kit?
which one is softer? i want my car to be very responsive... HELP HELP PLEASE
Profoxcg is offline   Reply With Quote
Old 03-15-2004, 08:55 PM   #6022
Arun's Avatar
I believe Proficar403 mentioned earlier back that he saw what he thought to be a revised 710 kit with the thick rear shock towers. Don't know about the quality of the plastics have improved though...
Nope, unfortunately we have not seen any kits here with revised shock towers yet. I had mentioned that the new kits here included new black flywheels and brown first gears. No one here has the new shock towers yet.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 03-15-2004, 09:17 PM   #6023
Pay more attention when installing the new brown gear.
Seems the mesh/module slight difference with the black(previous)one or maybe just thicker coating.
GoldFinger is offline   Reply With Quote
Old 03-15-2004, 09:52 PM   #6024
SupermaxxRich's Avatar
Just wondering, once you guys have your cars all together, how do you disconnect your rear and front sway bars? For the rear do you unscrew the ball or pop the plastic link off of the ball? For the front, do you just go from under the car and pry the sway bars from each other?? Probably a stupid question but just want to make sure. Thanks.
SupermaxxRich is offline   Reply With Quote
Old 03-15-2004, 10:25 PM   #6025
InitialD's Avatar
Originally posted by BaxterC
Hi guys, please would you tell me the difference between ceramic bearing and normal, and also why one would want titanium screws on a cal? Have any of you actually bent or broken a screw? I am a little confused as to why one would want such strong screws...
Like Herbie mentioned, we want light cars ! We are weight freaks !
Ceramic bearings are lighter and will last longer.
All the above are not to say that the 710 is heavy or that the ball bearings are faulty and all. Just that sometimes, people find strange things to do with their cars when there is nothing else that you can do to it !
Old 03-15-2004, 10:35 PM   #6026
2 years ago, when I come to serious in this hobby, I realize that "the sky is the limit", pretty scary.. but its true
Old 03-15-2004, 10:36 PM   #6027
BaxterC's Avatar
Originally posted by Marcos.S710
you should come and check out our track here in florida its Full Throttle Speedway here are some pics
or click on this link
Thank you Marco, I have put it on my list, thank you again... Looks like a lovely track.
BaxterC is offline   Reply With Quote
Old 03-15-2004, 10:39 PM   #6028
Avoid to pop the balls out of (plastic) ball end, I just release the 1.5 set screw in rear.
In front, unscrew the bar holder then slide back so it wont touches.
Old 03-15-2004, 10:39 PM   #6029
InitialD's Avatar
Rich, that's not a stupid question. When I put the car on the Hudy board to check tweak or droop settings, I unscrew the ball of the linkage connected at the rear bottom arm with a 3 mm ball tip allen (great when accessing at an angle). The same way too for the shocks. Popping out the plastic ball cups off the ball will wear it out.
As for the front sway bars, just loosen one side of the H9 (3 x 4mm) grub screw (refer to Step 1.3 on page 4 of the manual) on one of the arms. Not necessary to do it on both sides. Take a nose plier to grip and push / slide that loosened sway bar to the side to "disconnect" the ball and cup assembly. That's all to it !
When you want to connect the front sway bars back again, push the sway bar back in to form and connect the sway bar ball and cup assembly.
Old 03-15-2004, 10:43 PM   #6030
BaxterC's Avatar
Well I have just got back from my LHS with a snake under my arm, I am still a little unsure of my decision (you are welcome to give support) of getting rid of my r40 and buy a 710.
Well I will start building and see what happens.
I can tell you one thing... consider yourself supported, CONGRATULATIONS on your decision, you will not be disappointed. there is something about a snake under the arm that tends to make people scared and stand clear...
