Serpent 710
Old 02-16-2004 | 07:10 AM
  #4456
cyba888's Avatar
After runing my car last night I notice my rear tires worn out much faster than my fronts which is normal. So now my ride height in the rear is lower due to tire wear. Is it ok to raise the rear ride height, even tho the rear tire's profile is lower than the front? Even if I get new rear tires my tire tread would still be thicker than my fronts so im guessing it should be fine as long as the ride height is the same?
cyba888 is offline
Old 02-16-2004 | 07:23 AM
  #4457
cyba888's Avatar
cyba888 is offline
Old 02-16-2004 | 07:26 AM
  #4458
cyba888's Avatar
Is it safe to charge my tx batteries if I connect the wires to my Tekin charger while its in the remote socket? Look at attached files. Usually when the charger is NOT connected to the wall I get a volt reading when its connected to the batteries. But when I tested this method out I didnt get a reading. Do I need to charge it first to see if it will actually charge without damaging my radio?
cyba888 is offline
Old 02-16-2004 | 07:37 AM
  #4459
Picard's Avatar
Originally posted by Schrijver99
This is the old filter. Sorry but i can't show you the new tank.
Looks like I have the new one
Picard is offline
Old 02-16-2004 | 07:38 AM
  #4460
Picard's Avatar
Default Filter
The filter
Picard is offline
Old 02-16-2004 | 07:42 AM
  #4461
ammdrew's Avatar
Company Representative
never ran a filter on the old tank,never had any issues.. never saw a factory guy with a filter on at any of the big shows with the 705.. would recommend you just not even worry about it..
must of put 10 or 15 gallons of fuel through the old tanks without any dirt/ motor issues...
ammdrew is offline
Old 02-16-2004 | 07:46 AM
  #4462
cyba888's Avatar
I hate you j/k!
I guess im going to get a fuel filter anyways since its so cheap and my car is under weight too!
cyba888 is offline
Old 02-16-2004 | 07:53 AM
  #4463
Picard's Avatar
Andrew
Agreed, I have had the same experience, I had engine problems and removed the inline filter. My engines have run perfectly and i have not run one since and am also yet to have any engine issues
Picard is offline
Old 02-16-2004 | 07:57 AM
  #4464
Picard's Avatar
I have always had a filter in the tank though
Picard is offline
Old 02-16-2004 | 08:35 AM
  #4465
Marcos.J's Avatar
Super Moderator
your gear ratio will change with the tire wear (your back tires will rotate more than the front)
Marcos.J is offline
Old 02-16-2004 | 08:46 AM
  #4466
cyba888's Avatar
Should I get new tires for the rear and then swap my old rear tires in later when my front tires are around the same diameter?
cyba888 is offline
Old 02-16-2004 | 08:47 AM
  #4467
cyba888's Avatar
Can someone also reply to my post aboce regarding charging my tx batteries? Thanks!
cyba888 is offline
Old 02-16-2004 | 09:01 AM
  #4468
Marcos.J's Avatar
Super Moderator
i used 37shore in the front and 40 shore in the rear, then i cut the tire downs to 61 mm in the front and 62 mm in the rear and after running the car for about 5 minutes the tires are wearing the same and keeping the 1 mm difference from front to rear
Marcos.J is offline
Old 02-16-2004 | 09:17 AM
  #4469
cyba888's Avatar
Im guessing higher shore means harder tires since the rear wears out faster. Are you saying that once the rear starts to wear out again(smaller diameter than the fronts) you should cut the front tires?
cyba888 is offline
Old 02-16-2004 | 09:26 AM
  #4470
Marcos.J's Avatar
Super Moderator
correct on both
Marcos.J is offline
