Serpent 710
#2956
Originally posted by Sow&Steady
On the other hand, I was once in a race where they used an old outdoor roller-skating rink and I had to use yellow in the front and while in the rear with the gold pre-tension/progressive spring set-up just to complete one lap without skidding!
So the yellow rear springs that came with the 705 are as soft as the orange Impulse springs.
With the Veteq springs, you need not use the progressive pre-tension spring setup.
#2957
Originally posted by InitialD
Talking about springs, the one that comes with the 705 are Veteq springs. Slightly longer rear springs and softer. Rene Cornella mentioned that Veteq red springs are about equal to white Impulse springs while the blue Veteq springs are equal to yellow Impulse springs !
#2959
Originally posted by rcjayy
Can someone please let me know how I can mount the reciever in this car, It just will not fit with all these wires
its really starting to upset me
I've seen various solutions. Mine, the Futaba 311 will only fit if I either fit it in with the xtal facing the tank or I cut a slot for the xtal if I want it to face outwards.
I chose the 2nd option in case I need to change xtals during a race.
No doubt, the box Serpent make is too shallow and the fit with the wires will be tight.
#2961
#2962
#2963
I assume you're using a micro receiver (eg. those from the 3PK, M8)?
Im using a 3pdf with the micro reciever and short xtal
#2964
#2967
Here is a pic that Rene Cornella posted on how he mounted his Sanwa receiver.
The problem is with the reciever I have R133f from the futaba 3pdf the inserts for the wireing and the xtal are on opposite ends
#2968
#2969
What rims/tires work with the 710? I have a bunch of Fast Tires from my MTX3 and while the rims go on there is not enough thread showing so I reverse the locknut so I get alittle grab. Are the kit Ell's the only tires to work on the Serpent 710?
#2970
