Old 10-21-2004, 11:54 AM   #17956
Sow&Steady's Avatar
Default Re: Re: Michael Salven's Car in Brazil !
Originally posted by Julius
Well there is one mystery solved....
The upper arms are flat not tilted forwards.
Ther reason the shim is on top? Because that way master Salven doesn't loose them in his pitbox!
Thanks for the clarification Julius!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 10-21-2004, 11:56 AM   #17957
Sow&Steady's Avatar
Default Editorial by Mike Meyers
UPDATE!
Folks, the full editorial and race report by Mike Meyers is now available in the Contents section of 3hobby.com!
Check it out!
Old 10-21-2004, 11:59 AM   #17958
Suspended
THOSE ARE THE PARTS I ORDERED...PLUS THAT ORANGE FUEL TUBING...CHOCO
SERPENTFREAK69 is offline   Reply With Quote
Old 10-21-2004, 01:04 PM   #17959
jag
jag's Avatar
Default Re: Re: Re: Re: Re: Re: Servo Saver
Originally posted by InitialD
Jim, are you using oneway front or a the front ball diff?
If you're using the front ball diff, then you need to change to the new 2 piece diff clamp that comes packaged together with the new servo saver (802145) for better clearance. Or you can get that part separately (802387).
I am using the oneway. I assumed that the new clamp would be required with the ball diff as they come together.
jag is offline   Reply With Quote
Old 10-21-2004, 05:22 PM   #17960
impalabob64's Avatar
Send a message via AIM to impalabob64
Default hey
LOOK ,he is not running a oneway he is using the balldiff in the frt,i found a few that run the balldiff ,an run it on big tracks also.From what i understand u get the best of both worlds.Tighten to work as a solid, adjust to act as a oneway.I,ve seen maxey of maxeysfuel. Using the diff man he was unstoppable,Also u hve brakes.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 10-21-2004, 06:10 PM   #17961
can someone post a pic of there serpent 710 with the lola bumper on it?
baller360 is offline   Reply With Quote
Old 10-21-2004, 07:43 PM   #17962
InitialD's Avatar
I see he's getting older.
Old 10-21-2004, 07:44 PM   #17963
InitialD's Avatar
Default Re: hey
Yeah impalabob64, I believe most if not all cars were on 4WD braking. I think somehow you're more consistant with a front diff on that WC track.
Old 10-21-2004, 07:45 PM   #17964
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Servo Saver
Old 10-21-2004, 07:45 PM   #17965
can anyone who has the lola upper and lower bumper for the serpent 710 post pics?
Old 10-21-2004, 07:53 PM   #17966
InitialD's Avatar
I think crashed_1 has some pics of his 710 with the Lola bumper. Don't know when he'll post it. Is there anything particular you're looking for?
Old 10-21-2004, 07:56 PM   #17967
just some pictures of it iv'e never seen it on the 710 before. ive seen it elswhere but never on the car.
Old 10-21-2004, 08:19 PM   #17968
You can use the lower bumper directly. Using the front post mounted on the lower bumper is a bit risky.
Im using upper plate from kyosho lola bumper set and mount it on the original 710 top bumper plate with some modification.
PLease find the post from Pyramid couples of pages back.
GoldFinger is offline   Reply With Quote
Old 10-21-2004, 09:20 PM   #17969
Pyramid's Avatar
I think it was couple hundred pages back
Pyramid is offline   Reply With Quote
Old 10-21-2004, 10:08 PM   #17970
spawn's Avatar
Will we see spring steel dogbones and outdrives soon?
spawn is offline   Reply With Quote
