Serpent 710
Old 02-08-2004 | 09:40 PM
  #4111
InitialD's Avatar
Default Re: Re: Re: 710 shock tower
Originally posted by Sow&Steady
Or alternatively, what I did was to glue 2 of them together. Now it no longer stiff ... its really stiff!
Ummm, no wonder you guys wash out the rear shock tower stocks completely ! Not a single shock tower in town !
InitialD is offline
Old 02-08-2004 | 10:22 PM
  #4112
crashed_1's Avatar
Incidentally, all three 710 drivers qualified in A.
That must've been you, Uncle Yap and Riad...right?
Good Work to all the Snake Charmers.
crashed_1 is offline
Old 02-08-2004 | 10:34 PM
  #4113
markp27's Avatar
Talking Shopping list
Hi Guys,
Which RX unit would give the least problems in terms of fitting for the 710?
Any parts recommended which are useful in building the 710, i.e. greese, oils, items which didn't come with the kit? Not tool, though, should have plenty of those
Cheers, Mark.
markp27 is offline
Old 02-08-2004 | 10:47 PM
  #4114
Picard's Avatar
Hi Mark
I have just finished building the new kit and I use a Futaba HRS reciever and had no problems fitting it into the 710 box
Picard is offline
Old 02-08-2004 | 10:52 PM
  #4115
InitialD's Avatar
Be careful ! I believe Mark uses some analog servos. The HRS mode will burn the servos.
In any case, you need the 3PK to be able to use a HRS receiver.
Still, I agree that the HRS receiver is pretty small.
InitialD is offline
Old 02-08-2004 | 10:53 PM
  #4116
Picard's Avatar
Yes just the usual, oneway greese, axel greese, diff silicon lube,
and threadlock from memory, at the front of the manual it tells you what lubes you will need to build the kit
Picard is offline
Old 02-08-2004 | 10:58 PM
  #4117
Picard's Avatar
Sorry didn't realise you were buying a RX only and as usual ID is correct. Mark you will need two digital servos to run this receiver
Picard is offline
Old 02-08-2004 | 10:59 PM
  #4118
InitialD's Avatar
Default Re: Shopping list
Mark, given that you use the 3PJS radio, you should get the R113ip Futaba PCM receiver as per the original. I have used this same receiver on the 710 before with the 3PK and it fits well too although it's slightly bigger than the 3PK HRS receiver.
InitialD is offline
Old 02-08-2004 | 11:00 PM
  #4119
markp27's Avatar
This is true, I'll be using the Sanwa VR servos.
Chees, Mark.
markp27 is offline
Old 02-08-2004 | 11:02 PM
  #4120
markp27's Avatar
Default Re: Re: Shopping list
You know better than I do what gear I have There is a spy somewhere
markp27 is offline
Old 02-08-2004 | 11:26 PM
  #4121
Sow&Steady's Avatar
Default Re: Re: Re: Re: 710 shock tower
Of course! I have TWO cars remember?
The LHS here should also stop holding back ... I mean, they know everyone is breaking them, especially those who play at Atria.
Sow&Steady is offline
Old 02-08-2004 | 11:32 PM
  #4122
InitialD's Avatar
Default Re: Re: Re: Re: Re: 710 shock tower
Yeah right ! With lots of multiple rear shock tower spares bought !
For your information, it is not at Atria that I broke mine. Both I broke at Titi !
InitialD is offline
Old 02-08-2004 | 11:35 PM
  #4123
Sow&Steady's Avatar
Oh? Crashed ... you were there spying?
Yes, it was us three. My set-up was stock but Riad's had red springs like Uncle Yap. Definitely the springs to use as they were both a lot smoother through the looooong sweeper/straight. Uncle Yap also used 16-21 pinions which he told me to do but I left mine at home (at which point he told me not to race if I was going to leave things behind!)
Riad and I was head-to head, unbelievably enjoyable. We didn't need to push, just drive. If you were there you would have seen the "show", the only reason I overtook him was because he made a small mistake after the triangle ... otherwise he would have stayed in front of me. I think we could have easily done better if we pushed abit but we both messed up the first heat so this was our last chance.
Ah well, that heat alone was more than enough fun for me the whole day. I honestly didn't mind the rain as it was really warm and humid yesterday.
Mark Green told me once that with this car, everyone can be equal and this heat proved it.
Old 02-08-2004 | 11:39 PM
  #4124
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: 710 shock tower
Haven't built the second one yet ... that one will be the lightest car seen this side of town ... just watch!
What??? TiTi is a wide open track my friend ... you hit a mosquito or what?
  #4125
InitialD's Avatar
The thing is if you go to places like Thailand to race, the tables are turned as everybody there has a 710 !
InitialD is offline
