Old 02-08-2004, 05:49 PM   #4096
Thumbs up T1-R tower
I'm going too try the X-Ray T1-R tower.
With little modification, it fit's nicely and seems too be stronger.
It also is only $5.00 compared too $20.00 for the carbon tower.
dncmeloni is offline   Reply With Quote
Old 02-08-2004, 07:37 PM   #4097
kitracer's Avatar
nice option parts from 3 racing.
kitracer is offline   Reply With Quote
Old 02-08-2004, 07:44 PM   #4098
InitialD's Avatar
kitracer, has any of these options shown up in HK? Any idea what's the difference between woven and SSG graphite?
Old 02-08-2004, 08:26 PM   #4099
Pyramid's Avatar
finally, someone think of a better idea.. I think serpent should let go on 3rd party option parts in order to grow bigger on market share
Pyramid is offline   Reply With Quote
Old 02-08-2004, 08:27 PM   #4100
Sow&Steady's Avatar
Originally posted by evlhdlts
for those guys who don't burn their thrust bearing for the centax..
share your maintenance techniques.
what grease do you use?
what kind of maintenance do you do?
Make sure the orientation is correct and use thick auto grease on it. Also, the clutch bell gap should not be too large because everytime the centax engages you will be putting an enormous "bang" on the system hence the same too on the thrust bearing!
Sow&Steady is offline   Reply With Quote
Old 02-08-2004, 08:34 PM   #4101
Sow&Steady's Avatar
D! I didn't see you at the race at TT yesterday!
Old 02-08-2004, 08:35 PM   #4102
InitialD's Avatar
You use normal auto grease? I would have thought you would use some aerospace kinda grease !
Well, Julius mentioned to me that having a larger gap in between the clutchbell and shoes is OK so long as you make the end play very minimal by shimming the bearings in step 8.7 on page 28 of the 710 manual.
Hey, I hear that you already got hold of the front ball diff? Have you tried it yet?
Old 02-08-2004, 08:37 PM   #4103
InitialD's Avatar
Been busy at work lately. Had to be outstation on Sunday for work ! Was only back about 3 in the afternoon to drop by at Atria...
So how did the race go? How did you fare?
Old 02-08-2004, 08:44 PM   #4104
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
no shock towers broken by anyone today at winternats.
none issue saw plenty of cars upside down and smashed by 1/8 scales wide open..
front shock shafts.. problem, mount the front shock on the back side of the tower this took care of that issue, totally solved the problem.. none broken after that.
put pictures on our site.
current setup 3 deg rear toe, red spring all around, 2nd hole front tower, 2nd hole rear tower, 40 shore all around, 3 deg camber, 5mm ride ht, with 61.5mm tire dia,
front droop 1 front, rear 8
front sway 45 deg.
track very loose still hope for a better track tommorrow.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 02-08-2004, 09:05 PM   #4105
Trader Rating: 2 (75%+)
Lightbulb Re: 710 shock tower
Originally posted by dncmeloni
This is the two broken shock towers.
David,
You’re not the first person that I've heard that the rear shock tower is prone to breakage. Doug Darby mentioned on RCfiles that he has gone through 2 as well!! I'm guessing it's that S.A. on-road track that yall are running on! LOL
Anyway, I think the mod you did on the X-ray shock tower would be a very good replacement.
Mike
PUNISHER is offline   Reply With Quote
Old 02-08-2004, 09:05 PM   #4106
InitialD's Avatar
Mounting the front shock at the backside of the tower needs the tower to be pushed forward or use some spacers / long grub screw to space the lower arm shock mounting forward, right?
Have you tried playing around with the rear / front roll centers and the rear upper arms? I suggest you try it out. Very good and easy way to tune the car to the track.
Old 02-08-2004, 10:10 PM   #4107
Sow&Steady's Avatar
I was looking for some but the NASA on-line shop was closed yesterday!
Actually that's what I meant ... end-play.
Yes, its somehow a lot smoother once built ... even without the aerospace kinda grease. Not tried it yet as I just built it the night before the race. Besides, all three of us were using solids and posting good enough times for the A. I was going to use the one-way for the final but it rained
Old 02-08-2004, 10:17 PM   #4108
Sow&Steady's Avatar
That's a shame ... it was one of the best races I've been to in terms of driving quality. Despite using the unfamiliar full size track, no one "planted" their car on the far fence!
Most racers were even going in full-throttle (they were after all RCAC's top 40 drivers) but since I did not have enough practise, I was playing safe. Besides we were only given 2 heats so after messing up the first heat I did not want to take chances.
Not bad ... qualified A-7 and as I mentioned earlier I was looking forward to doing the finals with the one-way. You can do that when you're in A or B because the drivers are not only better but they understand race etiquette so if you're faster no-one is going to block you and mess up your race. Pity it rained. I was confident with the set-up enough to use the one-way and could maybe climb up one or two spots if I got a lucky start!
Incidentally, all three 710 drivers qualified in A.
Old 02-08-2004, 10:19 PM   #4109
Sow&Steady's Avatar
Default Re: Re: 710 shock tower
Mike
Or alternatively, what I did was to glue 2 of them together. Now it no longer stiff ... its really stiff!
Old 02-08-2004, 10:39 PM   #4110
InitialD's Avatar
Not bad ! Good showing of the 710. Let the good times roll.
