Serpent 710
Old 01-06-2004 | 10:31 PM
  #2731
Just got a used Xray Evo2 with loads of hopups
Now I have 2 cars to play!
Soon enough I'll be getting the Xray M18, and maybe a HPI pro 4 and maybe even the Losi Mini-T...
Another still in the look out for another GP, just not the 710 or the MTX3. LD3 seems nice, but not sure about parts support....
G4 also looks promising, again worry about parts support...
Oh no!! What is this hobby doing to ma wallet!!??
lawndoggie is offline
Old 01-06-2004 | 10:34 PM
  #2732
clmbia45's Avatar
Originally posted by InitialD
I have mine set at 1 mm as in the manual. The acceleration is fantastic !
Since the clutchbell already can spin freely, I would still add some more shims as per step 8.7 to take out most of the end play. Mine virtually does not have any but a very slight end play. This will give a longer thrust bearing life.
SORRY, I meant 0.1 to 0.2 mm end play. I didn't measure, I put too many shims in and removed them until it was right. I'll correct other post.
clmbia45 is offline
Old 01-06-2004 | 11:02 PM
  #2733
Default hudy / serpent
My Hudy tools break all the time
What's Hudy Spring ? Hudy is not a material or is it ?
so what's so special about Hudy spring/metal/steel ?
and what's Hudy material ?
coolracing is offline
Old 01-06-2004 | 11:06 PM
  #2734
clmbia45's Avatar
Thumbs up Serpent Corporate Field Support
It is clear that THIS Forum is the most productive forum I have ever seen. Comments are 98% constructive and appropriate, and occasionally brilliant. Contrast this to the vetek one where it quickly became a bitch session.
This group is POSITIVE, AND DESERVES TO BE RECOGNIZED AS SUCH.
SERPENT should throw a party for the Serpent 710 rctechers who attend the Winter Nats.
We should all meet one another and spread this aura of good will around the globe when we go home...with our
SERPENT 710 RCTECHER T-SHIRTS!!!
clmbia45 is offline
Old 01-06-2004 | 11:08 PM
  #2735
InitialD's Avatar
Default Re: hudy / serpent
Hudy makes a special spring steel material. You can see the tools that are made of Hudy spring steel when the colour of the steel itself is brownish. The glowplug wrench comes to mind. There are other tools like the Hudy socket wrenches that are made of spring steel as well but I believe the allen wrenches are not made from spring steel.
InitialD is offline
Old 01-06-2004 | 11:10 PM
  #2736
InitialD's Avatar
Default Re: Serpent Corporate Field Support
So what happened to the 2%?
Ummm, somebody should come up with a design of the T shirt first, right?
InitialD is offline
Old 01-06-2004 | 11:19 PM
  #2737
Default Re: Re: hudy / serpent
InitialD,
Do you want me to take pictures of all the other "hudy spring steel" materials and post it here ?
Or just attach my whole list of complains I sent to Hudy and post it here ?
Old 01-06-2004 | 11:41 PM
  #2738
InitialD's Avatar
Default Re: Re: Re: hudy / serpent
I cannot comment on anything. Perhaps it could faulty material or perhaps it's misuse. But please don't get me wrong. I merely answered your questions about Hudy spring steel and did not know that you wanted to be sarcarstic about it ! I neither work for Hudy nor for Serpent, remember?
InitialD is offline
Old 01-07-2004 | 12:05 AM
  #2739
Arun's Avatar
Fastharry,
I'm not sure if anyone answered your earlier question about the ease of removing the 710 diffs that you had a while ago. I didn't see an answer on the first readthrough. This is what I have observed.
In the rear, you must remove the six screws from the bearing caps (remember: two are behind through the shock tower) and the two back screws beneath the chassis. This allows you to pull the rear "cover" completely off to expose the area above the diff to pull it straight out. All in all, eight screws and pull it out.
In the front, you must remove the four screws from the bearing caps (which are attached to the shock tower) and unscrew one shock. Then, pop one ball cup from the steering knuckle to allow the knuckle to turn far enough to remove one dogbone from the outdrive. The front axle then comes out at an angle. All in all, five screws and one ball cup.
It is basically as easy to remove the diffs as it is in a Tc3.
Arun is offline
Old 01-07-2004 | 12:14 AM
  #2740
Sow&Steady's Avatar
I think panties have a different meaning in US and in UK...
Aha! So what do the Americans and Brits understand by "panties"?
Sow&Steady is offline
Old 01-07-2004 | 12:19 AM
  #2741
Sow&Steady's Avatar
InitialD,
Man! You (Coolracing) must have an arm as big as the Hulk's! That's true Hudy material you just broke.
Old 01-07-2004 | 12:22 AM
  #2742
Default Re: Re: Re: Re: hudy / serpent
You don't work for them but you seem to talk about and/or recommend their products more than their staffs.
Hate to say it here but It's people like you giving the wrong recommendations to fellow racers misleading them into victims of marketing gimmicks.
Yes it's sacarstic, I paid good money and it's for a lousy product. A fraction of the price could have got me a great wrench from my Walmart store and it's just as good if not better.
Old 01-07-2004 | 12:25 AM
  #2743
Yeah I have a big dick too.
It's always the users' fault not the "hudy springgy super steel" as advertised.
I will show you a couple more pictures when I get that damn d.cam back.
Old 01-07-2004 | 12:51 AM
  #2744
InitialD's Avatar
Default Re: Re: Re: Re: Re: hudy / serpent
Ummm, so saying a lot about them can automatically make me work for Serpent? Hey Pieter, where's my blank check?
Marketing gimmicks... Where have I heard that before? Ok, you win.
From now on, PLEASE everybody DO NOT listen to anything what I have to say because I have a forked out tongue that's going to deceive people into buying lousy products. I also get commission out of any recommendations I make. Heck and I haven't seen any single cent from Serpent !!
You said your peace... If you can, sell whatever Hudy tools you still have. Get the money and buy Walmart tools and you can still save I believe.
InitialD is offline
Old 01-07-2004 | 01:06 AM
  #2745
InitialD's Avatar
Americans: Panties as in Pants.
British: Panties as in underwear !
I hope I did not get it the other way around... This was what I was told !
InitialD is offline
