Serpent 710
Old 04-03-2007 | 01:28 AM
  #23206
Originally Posted by thamjk
With this little inovation here, finally we got a ball diff runing with oil. You need 100k above gear diff oil or a high temp grease to get a good resistance, smoothness and consistance.
That looks cool, but why did you build it?
_cyclops_ is offline
Old 04-23-2007 | 09:18 PM
  #23207
gearhead13's Avatar
I am looking for a header/pipe setup for my 710 that can be adjusted for length to tune the powerband for different conditions. I have heard/seen of these setups before but can't find out where I can get one.
Does anyone know where?
Does anyone use such a setup?
gearhead13 is offline
Old 04-24-2007 | 05:55 AM
  #23208
B4's Avatar
B4
Novarossi 2630 pipe is good depending on the motor you use. It also has a number of different header lengths available. Check RC-Mushroom this link will take you to the correct section of the site.
B4 is offline
Old 04-24-2007 | 01:00 PM
  #23209
gearhead13's Avatar
I already checked there, they are out of stock
I am wondering if Novarossi is still making them....
Old 04-24-2007 | 01:51 PM
  #23210
rcpanama's Avatar
Go to de following address
http://murnanmodified.com/index.php?...b2bd29aedd9663
RCPANAMA
rcpanama is offline
Old 04-24-2007 | 03:45 PM
  #23211
gearhead13's Avatar
RCPANAMA
I see the short header, but not the medium and long versions....
Old 05-12-2007 | 06:34 PM
  #23212
gearhead13's Avatar
I just started racing a 710. Im using the suggested default setup.
Can somebody tell me why I should set droop at 0 when the springs dont push the arm down that low?
Old 05-13-2007 | 03:10 AM
  #23213
Sow&Steady's Avatar
Just found this part selling in RC-mushroom. Its for 720.
Need to know if this part can be use in 710
Are you sure that's for the 720? It looks like the front ball-diff for the 710 or maybe my eyesight is failing me.
Sow&Steady is offline
Old 05-13-2007 | 03:13 AM
  #23214
Sow&Steady's Avatar
Wow! Where did you get this? Who makes it?
Old 05-13-2007 | 03:14 AM
  #23215
Sow&Steady's Avatar
Just use the threaded ring on the shock body to reposition the spring.
You can set the droop to another setting but try the default set-up first.
Old 05-13-2007 | 05:34 AM
  #23216
gearhead13's Avatar
I had the front sway bar set up wrong
Old 05-13-2007 | 03:04 PM
  #23217
Dirt-Racer's Avatar
Guys, got a 710 and i'd like to know whether it'll still be competitive and how different is this to the 720.
Also how is the spares backup for this car?
Thanks for any help and pointers
Dirt-Racer is offline
Old 05-13-2007 | 06:08 PM
  #23218
Pat Clark's Avatar
I just picked up a used 710 myself.. The car is still very fast.. I have laid down some really fast qual. runs setting TQ for the past 3 weeks.. The car is a bit twichy, i think this is why the got away from the rear steer on the 720.. The main differences are the front and rear suspension.. As for parts still VERY easy to get.. If you need a good starting point for set-up PM me and ill give ya what i run on med grip asphalt..Great place for parts in the US.. www.ashfordhobby.com
Pat Clark is offline
Old 05-13-2007 | 06:33 PM
  #23219
thamjk's Avatar
the car still competitive, its just the driver give enought maintanance on the car and the setup. 710 and 720 which is faster I would say its on the driver, setup and engine.
thamjk is offline
Old 05-13-2007 | 09:44 PM
  #23220
Dirt-Racer's Avatar
Hey thanks for the heads up guys and ill be sure to keep an eye on your progress with the 710 should you post more about it here and ill take you up on the offer once i get wheeling with it..
