Old 06-18-2007, 09:13 PM   #23236
thamjk's Avatar
Originally Posted by sn4il View Post
I was using almost default 710 setup, with front diff (Serpent oil 30000) and 37's shore all over. The track has a very good grip.
Need more steering at mid and exit.
Thnx
sn4il
I usually run
: front 37 rear 40.
: front yelow spring rear red spring
Serpent 710
Nova MAX
3PK
thamjk is offline   Reply With Quote
Old 06-18-2007, 09:17 PM   #23237
thamjk's Avatar
Originally Posted by cwai101 View Post
The breakage outdrive cup n bending dogbones due to collision or somethings else?How about when braking time,will it be 4w lock?So wat is the normal set up for 710 .bcause i am start dismantle and servicing my car now>Need advise?TQ
default setup with front solid. try to run front lower shore tyre and softer spring and harder shock oil. Very good handling for all kind of track.
Serpent 710
Nova MAX
3PK
Old 06-18-2007, 09:28 PM   #23238
thamjk's Avatar
Originally Posted by Mike Schumacher View Post
Can I upgrade 710 rear suspension to 720? If so, what parts I need?
The 710 rear suspension is longer then 720. If you move 720 rear suspension (rcc shock) to 710 I am afraid you can't get your droops lesser then +9, default is +7.
710 has its own RCC shock. try to get that and its longer then 720 rcc shock.
Serpent 710
Nova MAX
3PK
Old 06-19-2007, 01:01 AM   #23239
Sow&Steady's Avatar
Originally Posted by thamjk View Post
Very smooth... you are not gonna believe it. We use a thick grease on it.
Is it consistent as the way does on? I guess the next thing is make it adjustable ... or is it already?
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-19-2007, 09:25 AM   #23240
Default setup
SO with front solid,front 40 and rear 40 shore.Yellow spring for front with 40w shock oil and rear with red springs n also 40w oil.Will it be ok?
cwai101 is offline   Reply With Quote
Old 06-19-2007, 10:07 AM   #23241
dj apolaro's Avatar
I would try 38 front with red springs in the front and yellow in rear.
DJ
dj apolaro is offline   Reply With Quote
Old 06-19-2007, 10:20 AM   #23242
Default gear ratio?
Question added.Currently using 17t and 60t 1st gear and 22t and 56t for 2nd .Any problem with that.
Old 06-19-2007, 12:03 PM   #23243
gearhead13's Avatar
I havent bent any more dogbones since i went to the diff. Yes, it brakes good with the diff, 4 wheel lock up for sure. The outdrive cup breakage might be because I had front end too wide maybe...? I just think they are weak parts. Going from the solid to the diff, I had to relearn to setup properly all over, having trouble getting the front/rear balance right
gearhead13 is offline   Reply With Quote
Old 06-19-2007, 08:49 PM   #23244
thamjk's Avatar
my setup was
front 37 and sometimes goes down to 35.
Rear either 40 or somtimes 37.
Front shock 3 holes oil is 40W serpent or 70 trinity or equal.
rear shock 4 holes.
Front yellow spring and rear red spring.
front roll center from default to higest.
Next you need to see if you like the feeling...
Serpent 710
Nova MAX
3PK
Old 06-19-2007, 08:51 PM   #23245
thamjk's Avatar
that sound good.
in fact I usually use 59/17 which is 6.5 gear ratio.
Serpent 710
Nova MAX
3PK
Old 06-20-2007, 08:27 PM   #23246
that sound good.
If want to get more on top speed ?wat is the ratio u put?It seem my rear
absorber r soft with red springs n 40w oil.or maybe i try to put thicker shock oil.TQ
Old 06-28-2007, 08:44 PM   #23247
JMGarrett's Avatar
Send a message via Yahoo to JMGarrett
Default help
Have a serpent 710 and having trouble getting the front end to hook up. Pushes coming out of corner on power, any setup advice?
JMGarrett is offline   Reply With Quote
Old 06-28-2007, 08:49 PM   #23248
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
try Art Carbonell's FT.Myers set-up it worked really good when i had my 710 a few years ago
Old 06-29-2007, 01:28 PM   #23249
Sow&Steady's Avatar
Get a Murnan engine and use the ratio mentioned above.
It seem my rear
Red with 40 should be OK, but how many holes do you have in the shocks? Try standing them up more, try harder roll-bar setting before you go to harder oil.
Old 06-29-2007, 01:30 PM   #23250
Sow&Steady's Avatar
What droop are you running in the front? What caster and also make sure the ride height is right.
Try reducing droop first, then hard rear roll-bar. I found on my 710 this worked very well.
