Serpent 710
Originally posted by FW05R
your body is going to hit the asphalt you need to trim the sides down more
you may also note there isn't a wing on the car - this can also be pretty useful.
Originally posted by fmolzer
Mark, you can cut out my wheelwells any time you want to...
I think I've mounted it a bit too far foward - tried for the +2mm trick, but think I've got more like +3mm
Originally posted by Sow&Steady
Yeah but I think he was shivering from the cold snowy night in DE judging by the lower trimmings!
Originally posted by markp27
You should have a closer look, before you say that Fmolzer
Not yet finished, but here's a sneak preivew of my Winternats shell. Kept it simple and bright :yes:
Mark, trim the wheel wells bigger. You will definitely have problems during race with the wheels getting stuck under the bodyshell.
