Serpent 710
Re: Re: Re: Re: Re: Re: Diff building
Originally posted by markp27
More like 20 I blame D
Originally posted by Sow&Steady
C'est moi?
C'est moi?
Personal transponder
Being new to the 710, I would like to know where is the best place to put a personal transponder, any picture would be nice.
Re: Personal transponder
http://www.mytsn.com/forums/forum.as...exp=57198&sm=0
there he goes showing off his language skills again
Short Update...
Just yesterday, when it was a bright, sunny and blue skies on the track with 35 degree C temp, I tested out my 710.
I am currently still running with a front solid axle setup. But this is what I arrived at and I was pretty happy with it on a technical track with lots of tight corners and fast S chicanes;
Suspension geometry Front:
Downstops: 1mm
Set-up ride height: 5mm (Actual ride height !)
Camber Left: -2.5 degree
Camber Right: -2.5 degree
Track-width: 200mm
Toe-in: -1.5 degree (Toe-out)
Caster setting (mm in front): 5mm (with wheelbase shortened 2 mm)
Roll-center position upper arm (mm): 0mm under
Upstop (mm): None
Suspension geometry Rear:
Downstops: 8mm
Set-up ride height: 6mm (Actual ride height !)
Camber Left: -4.0 degree
Camber Right: -3.5 degree
Toe-in: +2.0 degree
Track-width: 200mm
Roll-center position upper: inner (UTI)
Roll-center position lower: up (LT)
DRS arm position (low-mid-up): mid
Shockabsorbers Front:
Springs: yellow
Oil: 40W
Holes: 4 x 1.2 mm
Cilinder type: composite
Membrane: Red
Shock-tower position: 2nd hole
Shockabsorbers Rear:
Springs: Red
Oil: 40W
Holes: 4 x 1.2 mm
Membrane: Red
Shock-tower position: 3rd hole
Lower shock position: outside
Anti-roll bar front:
Thickness: Adjustable blade
Position: 80 degree
Anti-roll bar rear:
Thickness: 2.5 mm
Position: 11.5 mm from the end of bar
Position on lower arm: Inside
Tires Front:
Make: New Serpent Ellegi
Hardness Left: 37 shore
Hardness Right: 37 shore
Diameter: 60mm
Wear in 5 min. Left:
Wear in 5 min. Right:
Tires Rear:
Diameter: 61mm
Transmission:
Pinion 1st: 17T
Pinion 2nd: 23T
Gear 1st: 61T
Gear 2nd: 55T
Front axle:
Type: Locked oneway
Diff. setting: Locked to solid axle
Rear axle:
Type: adjustable diff
Diff. setting: medium soft (when hot)
Aerodynamics:
Body: Protoform Mazda 6
Wing: Standard level to the body roof
Gurney strip: -
Engine and pipe:
Engine: Novarossi RR12L5
Version: -
Head shims: 0.2mm
Glowplug: 7TF
Pipe: Novarossi 52607 inline
Header: -
Length: -
Fuel: 25% Model Technic
Car turns very well and easy off power on tight technical tracks. Was using UTI / LB on the rear roll center before this. After changing to UTI / LT, the car rotates better and easier with a solid front axle. Will try out a more horizontal rear shock on the shock tower. Dual rate is set 75% on Tx steering. More and the rear tends to throw. Steering travel at 100% dual rate on Tx is set at max full throw steering travel (just touching front bulkhead) on the 710.
Downstops: 1mm
Track-width: 200mm
Upstop (mm): None
Downstops: 8mm
Toe-in: +2.0 degree
Track-width: 200mm
Springs: yellow
Oil: 40W
Holes: 4 x 1.2 mm
Membrane: Red
Springs: Red
Oil: 40W
Holes: 4 x 1.2 mm
Membrane: Red
Position: 80 degree
Anti-roll bar rear:
Thickness: 2.5 mm
Tires Front:
Diameter: 60mm
Tires Rear:
Diameter: 61mm
Transmission:
Pinion 1st: 17T
Pinion 2nd: 23T
Gear 1st: 61T
Gear 2nd: 55T
Front axle:
Type: Locked oneway
Rear axle:
Aerodynamics:
Gurney strip: -
Engine and pipe:
Version: -
Head shims: 0.2mm
Glowplug: 7TF
Header: -
Length: -
Location: The Milkyway/Planet Earth/Europe/Sweden/Skåne/Malmö
I'm placing an order from Mushroom today that among other 710 parts will contain some tires, but what shores are you recommending for a pretty fast large track with arount 10-20 C track temp?
But then again, look for 37 to 42 shores for front and rear tires. Most probably 40 would be mostly used. Get the new Ellegi tires. Better performance.
Hi D,,,
long time no write in this lands, ,, but trying to keep in touch with everything you guys write in here,,,, recently I adquire my 710 Kit,, with the new Mega Picco engine,, , I have a few questions , first about Centax ,, the coil spring that I received in my Kit was the Gold one, my manual says 909518 , is that OK, so should I replace it with the silver one Ser6586??,,
another question, I see that in your last setup , you're running locked front diff, did you locked the one way or the ball diff??,, and what did you do to lock it???
One more question, sorry but the UT and LT thing, I don't understand the terminology already,, due to my little experience with the car,, can you please make a drawing or take a pic. about this concern,,, BTW, thanks for the setting , that was I'm looking for ,, I'm running technical tracks around here!,,
I know that it's no Friday night, but here some pics of my lovely ride,
I know sometimes it seems easier if we can just put the car in the washing machine to give it a good cleaning...
