MTX 5
Old 01-20-2012 | 01:07 PM
  #1621
Seisick's Avatar
this is what ive been told about the changes in the upgrade kit
Diffcase: more stabil because more material-> shorter hexagon for bake disk
Bulkhead parts: more stabil by crashing the car-> different shape of carbon part (also possible to modify the original)
Seisick is offline
Old 01-20-2012 | 04:54 PM
  #1622
KostaG's Avatar
Selling my NIB MTX5. Will stick to 1/8 with my MRX5 WC
http://www.rctech.net/forum/r-c-item...mtx-5-nib.html
Thanks.
KostaG is offline
Old 01-20-2012 | 06:35 PM
  #1623
YLLIB's Avatar
P/N Description
T2227 Diff. Gear (Steel)
T2228 Diff. Cross Shaft (Steel)
T2103L-B Rear Upper Arm Bulkhead L
T2103R-B Rear Upper Arm Bulkhead R
T2111-B Rear Upper Arm Mount Plate
T2201-B Diff Case
T2215-B Brake Disc Adaptor
H0753 Spring Cup (Steel)
YLLIB is offline
Old 01-20-2012 | 07:16 PM
  #1624
michael 1 is offline
Old 01-20-2012 | 10:23 PM
  #1625
gotmotor's Avatar
Originally Posted by michael 1
1
Get off our thread
gotmotor is offline
Old 01-21-2012 | 02:23 AM
  #1626
Thumbs up mtx5 brace
hi we have tested brace and gear prob we found gears have to be meshed a bit noisey when new to wear in we ran about 8 tanks to day and no problems ///except chassie started 2 bend again whitch we did not notice and gear mesh got a bit tight our brace has a bit of flex stragitend it out when we got home now gears sound good brace is adjustabil in length rest of car was good
greg
greg.dawn is offline
Old 01-21-2012 | 04:02 AM
  #1627
greg
set the gear mesh with the larger gear off. mesh it so it is free bro. it's possible to set gears free, but with little to no loose play, you just need to be accurate with the engine mount screws.
if the larger spur has play don't worry, this one hardly ever strips.
Noisey gears means the pinions will be worn out prematurely, and more likely to lead to strpping gears when the teeth on the pinions get pointy.
no need for the brace man, you won't stop the upwwards flex with it as it isn't connected to the baulkhead, and even if it is it isn't strong enough
TomB is offline
Old 01-21-2012 | 08:18 AM
  #1628
gotmotor's Avatar
MTX 5-img957888.jpgNo flex here All copy rights are reserved A Shing Speed Production
gotmotor is offline
Old 01-21-2012 | 08:51 AM
  #1629
YLLIB's Avatar
well gomotor, if this is your car no it's not ever going to strip gears, you don't even race, forgot 1 time a year.
YLLIB is offline
Old 01-21-2012 | 08:53 AM
  #1630
YLLIB's Avatar
do we want to stop the flex, the car was tested & designed that way....
I am not trying to stop striping gears, I just do not like that kind of flex in that area of the chassis. This car was not designed on our sort of tracks in the USA were we use more brakes because of our track layouts and traction we have here. I can not beleive we count on the chassis flex to make the car work, that's to me a incosistent because of chassis weakins..I just want it to be a little stiffer but keep the side flex rotation.
YLLIB is offline
Old 01-21-2012 | 09:08 AM
  #1631
gotmotor's Avatar
C'mon Man I'm coming to play at you track a lot this year Just running tenth scale this year
gotmotor is offline
Old 01-21-2012 | 09:17 AM
  #1632
SOLOARTIST 702's Avatar
good now i can tear that @$$ up
SOLOARTIST 702 is offline
Old 01-21-2012 | 10:29 AM
  #1633
gotmotor's Avatar
As hammer would say....cant touch this You might be able to get that @$$ on your FB wall
gotmotor is offline
Old 01-21-2012 | 10:41 AM
  #1634
like that huh aaaaawwwwwkkk
Old 01-21-2012 | 11:53 AM
  #1635
FASRICK's Avatar
Tresspasser
FASRICK is offline
